I think "relay" is the correct terminology for this component. I
thought they were referred to as "relay switches", but all sites I have seen do refer to them as "relays". I'll have to go in and take a closer look to see if there are any other numbers on this panel to be able to respond more accurately. My last trip up to the airport, I tried to document names and model numbers of all avionics in the panel so I could provide better data. The audio panel didn't have a name on it that I could decipher... All I could recall getting from it was the info off the relay, including the manufacturer and part number. I don't recall if there was any additional information??? I also don't have any idea how old it is? I was surprised, however to find that the relay for a second COM and marker beacon components were removed. That's what I get for buying used and having it installed sight-unseen! I'm learning some valuable lessons, the hard way! If anyone cares, I will post an update after I've had a chance to get up and look at the audio panel again... May be a few days... Thanks again for the feedback! Todd |
three-eight-hotel wrote:
: I also don't have any idea how old it is? I was surprised, however to : find that the relay for a second COM and marker beacon components were : removed. That's what I get for buying used and having it installed : sight-unseen! I'm learning some valuable lessons, the hard way! If it is a Cessna audio panel many came without hookups for 2nd com, makers, etc. I flew many C-152's with single com and Cessna audio panel. The audio panel has switch holes for more radios, but no switches in said holes. The PCB has spaces for relays, resistors, etc. but no components installed. If, indeed, it is a Cessna audio panel, you can get another one from Airwich Avionics. Or, you could toss it and get a better audio panel. -- Aaron C. |
Robet Coffey wrote:
relays are commonly called relay switches. soda = soda pop = pop = cokes In what part of the world? I've been an EE for 20 years and I've never heard of a device called a relay switch. Maybe it is common somewhere in the world, but not in the USA. Matt |
makers, etc. I flew many C-152's with single com and Cessna audio panel. The audio panel has switch holes for more radios, but no switches in said holes. The PCB has spaces for relays, resistors, etc. but no components installed. That seems to be the case, however, I was told that it included marker beacon indicators... All word of mouth/he-said-she-said, so I guess going down that road is a lost cause (I've had the audio panel for nearly a year now) If, indeed, it is a Cessna audio panel, you can get another one from Airwich Avionics. Or, you could toss it and get a better audio panel. I checked out this site, and they didn't seem to have any audio panels. Believe me... a new audio panel has crossed my mind, several times, but I would be looking at a re-wire to accomodate the new audio panel, and remove my intercom (since it would likely be built into a newer audio panel). When all is said and done, I would probably be looking at $1500 -$2000 (just a guess). If I can get away with what I've got, and potentially get away with a ~$20 relay fix, I would be happy with that, until I can really afford to go in and upgrade the entire panel. Thanks for the input! Todd |
RST Engineering wrote:
Excuse me, "Robet", but after 46 years in the biz you'd think I would know of whence I speak. Because I like to give advice that is correct, I ask for confirmation of things I don't understand. I don't understand "relay switch" because I've never heard of it. It is neither common nor conventional. If you can't add anything to the problem/solution except pedantry, butt the hell out. Jim "Robet Coffey" wrote in message news:5W1cf.6689$Bx.5092@trnddc01... RST Engineering wrote: What is a relay switch? relays are commonly called relay switches. soda = soda pop = pop = cokes RST Engineering wrote: What is a relay switch? I've never seen one. I've seen relays. I've seen switches. I've never seen a relay switch. you knew what the poster meant by relay switch, you were just being a asshole trying to embarrass a layperson for calling it a relay switch instead of simply a relay- pompous ass. nontechnical persons like myself, the poster incorrectly use the term from time to time....deal with it. |
Matt Whiting wrote:
Robet Coffey wrote: relays are commonly called relay switches. soda = soda pop = pop = cokes In what part of the world? I've been an EE for 20 years and I've never heard of a device called a relay switch. Maybe it is common somewhere in the world, but not in the USA. Matt Matt I doubt many EE would call it a relay switch. I live in the southeast (coalfields) and have heard non-technical people (myself included) use the term "relay" and "relay switch" interchangeably most of my life. Incorrectly so, I take it. I don't know where the poster is from so I can't speak for him/her. I do want to stress that I am layperson in electronics and have heard the term only used by like persons. Come visit the coalfields... we likely have many words you won't hear anywhere else in the U.S.! |
Robet Coffey wrote:
Matt Whiting wrote: In what part of the world? I've been an EE for 20 years and I've never heard of a device called a relay switch. Maybe it is common somewhere in the world, but not in the USA. Matt I doubt many EE would call it a relay switch. I live in the southeast (coalfields) and have heard non-technical people (myself included) use the term "relay" and "relay switch" interchangeably most of my life. Incorrectly so, I take it. I don't know where the poster is from so I can't speak for him/her. I do want to stress that I am layperson in electronics and have heard the term only used by like persons. I've got less years than Jim but more than Matt in the gulf states oilfield onshore/offshore (Texas to Florida and the Caribbean) as a tech. This was the first time I've heard the term "relay switch" by even "non-technical people"... http://en.wikipedia.org/wiki/Special...y+switch&go=Go http://dictionary.reference.com/search?q=relay%20switch http://www.m-w.com/dictionary/relay%20switch |
Okay... so non-technical doesn't even begin to describe me, when it
comes to electronics. I also thought my original problem was due to a malfunctioning fetzer value and thought some gauze and ball-bearings might do the trick (Fletch reference) :-) In my defense, I looked at several sites for the part that matched that part number, including some searches that included the words relay and switch. A simple google search on "relay switch" comes up with an entire page of which "relay switch" is used in the title or brief description for every hit. I didn't look into the details of any one link, but may have made a sub-conscious conclusion that the terminology was valid. Putting the relay vs. relay switch discussion aside, these groups are an incredible source for someone to get assistance in an area they are not comfortable. Even though I may come across as a moron at times, I have gained a substantial amount of knowledge and most importantly have decided to stop looking at my plane as a black-box, which reponds to power and control inputs. I will humbly listen to anyone who has taken the time to respond to my posts and make a decision whether that feedback is worthy of follow-up effort on my part or not. Respond as condescendingly or as humbly as you want, just respond! ;-) Advice on these newsgroups is free, but taking my plane in to an avionics shop, I don't trust, to troubleshoot a problem that could require significant hours of labor is not! I'll take what I can get! Thanks to all and best regards! Todd |
Darrel Toepfer wrote:
Robet Coffey wrote: Matt Whiting wrote: In what part of the world? I've been an EE for 20 years and I've never heard of a device called a relay switch. Maybe it is common somewhere in the world, but not in the USA. Matt I doubt many EE would call it a relay switch. I live in the southeast (coalfields) and have heard non-technical people (myself included) use the term "relay" and "relay switch" interchangeably most of my life. Incorrectly so, I take it. I don't know where the poster is from so I can't speak for him/her. I do want to stress that I am layperson in electronics and have heard the term only used by like persons. I've got less years than Jim but more than Matt in the gulf states oilfield onshore/offshore (Texas to Florida and the Caribbean) as a tech. This was the first time I've heard the term "relay switch" by even "non-technical people"... http://en.wikipedia.org/wiki/Special...y+switch&go=Go http://dictionary.reference.com/search?q=relay%20switch http://www.m-w.com/dictionary/relay%20switch It could be slang, but I'm not making it up. Google search actually turned up a few. http://www.nema.org/prod/be/enclosur.../relay-switch/ http://www.extensivemods.com/modules...howpage&pid=74 - 16k - http://www.quasarelectronics.com/3126.htm and here are some harvard doods that designs them: Optimal Design of a MEMS Relay Switch Authors: M.P. Brenner, J. Lang, J. Li, J. Qiu and A. Slocum Affilation: Harvard University, USA Pages: 214 - 217 They are for microelectromechanical devices, so I guess it's used (by us)a little out of context. |
Robert Coffey wrote:
It could be slang, but I'm not making it up. Google search actually turned up a few. I avoid Google and Yahoo, just because... http://www.nema.org/prod/be/enclosur.../relay-switch/ Has links that loop. I surmise that they have enclosures for relays and switches from the listed manufacturers... http://www.extensivemods.com/modules...howpage&pid=74 - 16k - Switches 12 volts, has a 2 amp limit... No relay is visible... http://www.quasarelectronics.com/3126.htm Looks to be a SPDT Relay... All relays "switch" between NO and/or NC contacts... A switch does just that between Open & Closed states... |
MX385 Radio removal | Marty from Florida | Owning | 3 | May 24th 13 08:26 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
(sorta OT) Free Ham Radio Course | RST Engineering | Home Built | 51 | January 24th 05 08:05 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
