Logging approaches
Old January 31st 04, 07:11 PM
sn
I believe the requirement for logging the time is conditional upon the
following phrase. "...maneuvering the aircraft solely by reference to
instruments..." If you have ever had an experience flying over water or in
the mountains with a high overcast, moonless night, there might be a
reported visibility from stations of 50 miles. Trust me, your maneuvering
soley by reference to your instruments, and every bit of it is loggable as
actual.
"Peter R." wrote in message
Gary Drescher ) wrote:
Seeing the ground doesn't necessarily mean you're operating the aircraft
by
reference to the ground at all. You could fly an approach with
visibility
of, say, 0.5 sm (and therefore be solidly in IMC), and still see be able
to
the ground the whole time. But you wouldn't necessarily be using that
view
to aviate or navigate.
I agree. Last week I was practicing approaches in moderate lake effect
snow where the RVR fluctuated between 1800 and 5000, yet I could see the
ground directly below the aircraft.
Not sure how seeing the ground below is relevant to logging an approach,
unless, of course, I am flying in that direction.
Peter
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet
News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000
Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption
Old January 31st 04, 07:28 PM
Steven P. McNicoll
"sn" wrote in message ...
actual.
Fine, but the complete phrase is "A person may log instrument time only for
that flight time when the person operates the aircraft solely by reference
to instruments under actual or simulated instrument flight conditions." If
you're not in actual instrument flight conditions or using a vision
restricting device, how can you log any instrument time?
Old January 31st 04, 08:40 PM
Teacherjh
actual.
Even if you are on a VFR flight plan and are not instrument rated?
Jose
Old February 1st 04, 06:29 AM
Hilton
actual.
The FARs do not specify 'must be on an IFR flight plan', nor do they specify
that you need to be instrument rated to log actual.
Hilton
Old February 1st 04, 03:23 PM
Andrew Sarangan
I am quite familiar with the situation you are describing. I used to
encounter it all the time in New Mexico. But I do not believe that
such flights were loggable instrument flights. If you are flying
solely by reference to instruments who is keeping you separated from
other aircraft? I agree that those flights require greater use of
instruments than a normal VFR flight, but I don't see how it qualifies
as sole reference to instruments. Sole implies 100% use of instruments
without any outside visuals.
actual.
by
visibility
to
view
Peter
News==----
Newsgroups
Old February 1st 04, 03:34 PM
Steven P. McNicoll
"Andrew Sarangan" wrote in message
om...
other aircraft?
You are. See and avoid.
Old February 1st 04, 06:26 PM
John R Weiss
"Hilton" wrote...
Indeed, you can legally fly under VFR (even without any flight plan at all) as
long as the weather is as prescribed in 91.155. There is no mention of a
visible horizon...
OTOH, you may find yourself at odds with 91.13(a) or 91.113(b) if you have not
sufficiently prepared for the flight or don't have enough experience to safely
fly in the conditions...
Old February 1st 04, 07:47 PM
John R. Copeland
Similarly if you are in uncontrolled airspace.
There's less of that than there used to be, though.
---JRC---
"John R Weiss" wrote in message =
news:OxbTb.72923$U%5.402002@attbi_s03...
=20
=20
Indeed, you can legally fly under VFR (even without any flight plan at =
all) as
long as the weather is as prescribed in 91.155. =20
=20
Old February 1st 04, 09:35 PM
Barry
as long as the weather is as prescribed in 91.155.
Even in uncontrolled (Class G) airspace, VFR is permitted only if the weather
meets the requirements of 91.155. If the weather is below VFR minimums, you
can fly IFR without a clearance, but this is still IFR and must be in
accordance with the appropriate rules of Part 91, including fuel reserve,
cruising altitude, etc.
Barry
What approaches are in a database? Ross Instrument Flight Rules 11 January 4th 04 07:57 PM
GPS approaches with Center Dan Luke Instrument Flight Rules 104 October 22nd 03 09:42 PM
Logging instrument approaches Slav Inger Instrument Flight Rules 33 July 27th 03 11:00 PM
Suppose We Really Do Have Only GPS Approaches Richard Kaplan Instrument Flight Rules 10 July 20th 03 05:10 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
