Looking for a sub-100hp engine with long TBO time.
Old November 10th 05, 10:17 PM
tffy
Default Looking for a sub-100hp engine with long TBO time.
This is for a hypothetical ultralight design, so just looking for
suggestions here of where to look at... hopefully a 4-stroke, purchase
price doesn't matter much, certification status doesn't matter either.
Long time before overhaul matters A LOT... so, the longer the better.
Is there anything out there in the 80-hp range? How about a motorcycle
engine conversion - how long can those go before needing to be
overhauled?
Thanks!
Old November 10th 05, 10:28 PM
Anthony W
Check out the Honda four stroke personal watercraft engines. They're
powerful and designed to run at full load for extended lengths of time.
However, you'd have to use a reduction unit to get the RPM down low
enough to drive a prop.
Tony
overhauled?
Thanks!
Old November 10th 05, 10:39 PM
Lakeview Bill
Why not just go with a Jabiru 2200?
A TBO of 2000 hours currently applies, with a top end TBO of 1000 hours. A
Air cooled + no redrive = simple.
Reasonably priced.
"tffy" wrote in message
overhauled?
Thanks!
Old November 10th 05, 10:40 PM
Anthony W
I was wrong about those four stroke personal watercraft engines. The
Honda engine is rated at 137HP and the Yamaha engines are rated at 110
to 160HP. All of these are much bigger than you were looking for.
Tony
overhauled?
Thanks!
Old November 10th 05, 10:46 PM
Rob Turk
"Lakeview Bill" wrote in message
Reasonably priced.
Good suggestion! Should do very well for an ultralight.
Rob
(Ouch, someone mentioned Jabiru... I'm waiting in suspense for the response
of Bret L...)
Old November 10th 05, 11:41 PM
tffy
Thanks for that suggestion, will check it out. Still looking for other
options out there though!
Old November 11th 05, 12:09 AM
tom pettit
You should check out the Rotax 912. It is 80hp, four stroke, and weighs
about 125 pounds. It has a TBO of 1500 hours.
tom pettit
overhauled?
Thanks!
Old November 11th 05, 12:13 AM
tffy
Thanks! There isn't anything 2-cylinder available in this power range
(or perhaps less, all the way down to 60hp), is there? The a/c
performance can afford to be somewhat anemic, while mounting space is
at a premium.
Old November 11th 05, 12:16 AM
Vaughn
overhauled?
Beemer? http://www.microlightsport.co.uk/Cat.../bmwengine.htm I have
spent thousands of hours riding on top of my BMW engine, and often thought that
I wouldn't mind flying behind one. That said, they have never been terribly
popular with homebuilders for some reason.
Vaughn
Old November 11th 05, 12:19 AM
Jim Carriere
at a premium.
The most popular 2-cylinder in this range is the 65hp Rotax 582 (and its
big brother the 75hp 618), but these are two strokes with relatively
short TBO, two things you are trying to avoid. Besides, I don't think
the aircraft 618 is made anymore.
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
making the transition from renter to owner part 1 (long) Journeyman Piloting 0 April 13th 04 02:40 PM
Emergency Procedures RD Piloting 13 April 11th 04 08:25 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
