Had a strange one today..
While squawking IDENT , our "ident" stuck "on" ATC confirmed we were continuously "identing" Cycling the transponder to off then on again cleared the ident fault. Pressing the button again locks the ident light on again until the power is cycled.. Any thoughts? Switch appears mechanically OK, (clicks when pressed, clicks when released).. It is a King KT78 "KT76TSO" Dave |
Take it to an avionics shop, it isn't airworthy until you
fix it. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm "Dave" wrote in message ... | Had a strange one today.. | | While squawking IDENT , our "ident" stuck "on" | | ATC confirmed we were continuously "identing" | | Cycling the transponder to off then on again cleared the | ident fault. | | Pressing the button again locks the ident light on again | until the power is cycled.. | | Any thoughts? | | Switch appears mechanically OK, (clicks when pressed, clicks | when released).. | | It is a King KT78 "KT76TSO" | | Dave |
On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin"
wrote in 4qSdf.1063$QW2.860@dukeread08:: James H. Macklin ATP,CFI,A&P Welcome back to rec.aviation.piloting. Has it been almost five years? |
Since 9/11 when I lost the cable Internet. Glad you
remember me. Just renewed my CFI for another cycle, good until Jan 2008. I plan to win the lottery before Christmas and buy myself a Legacy Cub. Maybe I'll put half a Garmin 1000 in it ![]() -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm "Larry Dighera" wrote in message ... | On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin" | wrote in | 4qSdf.1063$QW2.860@dukeread08:: | | James H. Macklin | ATP,CFI,A&P | | Welcome back to rec.aviation.piloting. | | Has it been almost five years? | |
Already gone!
Dave On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin" wrote: Take it to an avionics shop, it isn't airworthy until you fix it. -- James H. Macklin ATP,CFI,A&P |
On it's way back, should have it tomorrow....
Including taxes, .219 AMU's.. (CDN $"s) Suprisingly, they could not reproduce the fault on the bench, so they replaced the IC, some caps etc, all the parts in the timing circuit, ($35 in parts).. They did a full alignment, centered it to fac specs, and are sending it home.. I am dissappointed the fault cleared on the bench, that still leaves some doubt, but they heated it, froze it several times, then did what they could. How long should this timer cycle for? (How long should the "ident" signal tx on one push of the switch?) Dave On Mon, 14 Nov 2005 18:21:05 -0400, Dave wrote: Already gone! Dave On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin" wrote: Take it to an avionics shop, it isn't airworthy until you fix it. -- James H. Macklin ATP,CFI,A&P |
20-30 seconds
"Dave" wrote in message ... On it's way back, should have it tomorrow.... Including taxes, .219 AMU's.. (CDN $"s) Suprisingly, they could not reproduce the fault on the bench, so they replaced the IC, some caps etc, all the parts in the timing circuit, ($35 in parts).. They did a full alignment, centered it to fac specs, and are sending it home.. I am dissappointed the fault cleared on the bench, that still leaves some doubt, but they heated it, froze it several times, then did what they could. How long should this timer cycle for? (How long should the "ident" signal tx on one push of the switch?) Dave On Mon, 14 Nov 2005 18:21:05 -0400, Dave wrote: Already gone! Dave On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin" wrote: Take it to an avionics shop, it isn't airworthy until you fix it. -- James H. Macklin ATP,CFI,A&P |
Hmmm... that seems like a long time... tech said mine is suposed to
be set for 15 secs, and I thought that was very long time. Can anyone direct me to a resource that explains how the "ident" sys works? - what happens when the button is pushed, to how it appears on the controllers radar.. I understant WHAT happens in basic fashon, I need some more details. I have a background in electronics, so I understand the technology, but never any training on avionics.. Thanks ! Dave On Thu, 17 Nov 2005 01:10:44 GMT, "Michael Ware" wrote: 20-30 seconds "Dave" wrote in message .. . On it's way back, should have it tomorrow.... Including taxes, .219 AMU's.. (CDN $"s) Suprisingly, they could not reproduce the fault on the bench, so they replaced the IC, some caps etc, all the parts in the timing circuit, ($35 in parts).. They did a full alignment, centered it to fac specs, and are sending it home.. I am dissappointed the fault cleared on the bench, that still leaves some doubt, but they heated it, froze it several times, then did what they could. How long should this timer cycle for? (How long should the "ident" signal tx on one push of the switch?) Dave On Mon, 14 Nov 2005 18:21:05 -0400, Dave wrote: Already gone! Dave On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin" wrote: Take it to an avionics shop, it isn't airworthy until you fix it. -- James H. Macklin ATP,CFI,A&P |
"Ident" times...
Garmin GTX 330 = 18 seconds Microair T2000 = 20 seconds As per their manuals... "Dave" wrote in message ... Hmmm... that seems like a long time... tech said mine is suposed to be set for 15 secs, and I thought that was very long time. Can anyone direct me to a resource that explains how the "ident" sys works? - what happens when the button is pushed, to how it appears on the controllers radar.. I understant WHAT happens in basic fashon, I need some more details. I have a background in electronics, so I understand the technology, but never any training on avionics.. Thanks ! Dave On Thu, 17 Nov 2005 01:10:44 GMT, "Michael Ware" wrote: 20-30 seconds "Dave" wrote in message .. . On it's way back, should have it tomorrow.... Including taxes, .219 AMU's.. (CDN $"s) Suprisingly, they could not reproduce the fault on the bench, so they replaced the IC, some caps etc, all the parts in the timing circuit, ($35 in parts).. They did a full alignment, centered it to fac specs, and are sending it home.. I am dissappointed the fault cleared on the bench, that still leaves some doubt, but they heated it, froze it several times, then did what they could. How long should this timer cycle for? (How long should the "ident" signal tx on one push of the switch?) Dave On Mon, 14 Nov 2005 18:21:05 -0400, Dave wrote: Already gone! Dave On Sun, 13 Nov 2005 20:12:43 -0600, "Jim Macklin" wrote: Take it to an avionics shop, it isn't airworthy until you fix it. -- James H. Macklin ATP,CFI,A&P |
Dave wrote:
Hmmm... that seems like a long time... tech said mine is suposed to be set for 15 secs, and I thought that was very long time. Can anyone direct me to a resource that explains how the "ident" sys works? - what happens when the button is pushed, to how it appears on the controllers radar.. I understant WHAT happens in basic fashon, I need some more details. I have a background in electronics, so I understand the technology, but never any training on avionics.. When you push the transponder ident button, for the next 15-20 seconds any reply the transponder receives has an additional pulse (called in transponder terms the "Special Position Identification Pulse") added to the end of the reply. Pressing the IDENT button does nothing if you aren't being radar interrogated. How this is displayed to the controller depends on what radar they are using. Either the little splat on the screen that corresponds to your aircraft changes appearance (the slash doubles) or the word IDENT appears in your data block (knowing the hacked nature of ATC radars there are probably more options). |
Transmittion Noise - High Power Settings | Paul Smedshammer | Owning | 6 | August 20th 05 06:17 PM |
Operation without a transponder | flyer | Piloting | 11 | September 14th 04 08:48 AM |
A Cheap and Dirty Transponder Tool | John P | Owning | 3 | June 15th 04 05:30 AM |
Another Cirrus BRS deployment: | Dan Luke | Piloting | 111 | April 19th 04 04:34 AM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
