Had a strange one today..
While squawking IDENT , our "ident" stuck "on" ATC confirmed we were continuously "identing" Cycling the transponder to off then on again cleared the ident fault. Pressing the button again locks the ident light on again until the power is cycled.. Any thoughts? Switch appears mechanically OK, (clicks when pressed, clicks when released).. It is a King KT78 "KT76TSO" Dave |
"Dave" wrote:
While squawking IDENT , our "ident" stuck "on" ATC confirmed we were continuously "identing" Cycling the transponder to off then on again cleared the ident fault. The service manual sheds little light on the fault. So we start at the switch, and then if OK note when that momentary switch is closed, a pin on the big IC chip labeled IDENT is grounded. Could be the chip, or the capacitor which sets the timing for the indent to be on. It says this time is variable, suggesting a timing capacitor somewhere (manual silent on this though). Will be expensive to fix if the chip is bad, unless jiggling it in the chip socket fixes it (if socketed). Fred F. |
Yup... more info.. tech here says there is a timing circuit that
gets initialized when switched is closed. I can hear the switch "click" off when released.. He suspects the IC or something associated with it... It is out and off to him now, will report results here when I get the final result.. Here go more AMU's ![]() Dave On Sun, 13 Nov 2005 21:57:42 -0500, "TaxSrv" wrote: "Dave" wrote: While squawking IDENT , our "ident" stuck "on" ATC confirmed we were continuously "identing" Cycling the transponder to off then on again cleared the ident fault. The service manual sheds little light on the fault. So we start at the switch, and then if OK note when that momentary switch is closed, a pin on the big IC chip labeled IDENT is grounded. Could be the chip, or the capacitor which sets the timing for the indent to be on. It says this time is variable, suggesting a timing capacitor somewhere (manual silent on this though). Will be expensive to fix if the chip is bad, unless jiggling it in the chip socket fixes it (if socketed). Fred F. |
"Dave" wrote:
Yup... more info.. tech here says there is a timing circuit that gets initialized when switched is closed. I can hear the switch "click" off when released.. He suspects the IC or something associated with it... The bummer about that the King VLSI chip is absolutely nothing in function like the 3 gigahertz Pentium CPU in our now cheapie damn computer, enormous heat sink now and all that. The service manuals always say to suspect the big IC last. Disheartening, when you see King's pricing on a 20-cent, common transistor. I was in an avionics shop once, and spotted a bin of them common transistors. Does FAA actually allow them to use those? And do they like just bill $$ that way per invoice? Oh, the joys of owning airplanes when it comes to genuine proprietary parts, the VLSI, in avionics boxes we think are all that complicated, but to a good tech guy really ain't. Fred F. |
You can buy a cheap multimeter at radio shack for about 10 bucks. Put it on
continuity and you are good to go. I know it is not as fun as building it yourself. Just think of it as a kit with one part. "TaxSrv" wrote in message ... "Dave" wrote: Yup... more info.. tech here says there is a timing circuit that gets initialized when switched is closed. I can hear the switch "click" off when released.. He suspects the IC or something associated with it... The bummer about that the King VLSI chip is absolutely nothing in function like the 3 gigahertz Pentium CPU in our now cheapie damn computer, enormous heat sink now and all that. The service manuals always say to suspect the big IC last. Disheartening, when you see King's pricing on a 20-cent, common transistor. I was in an avionics shop once, and spotted a bin of them common transistors. Does FAA actually allow them to use those? And do they like just bill $$ that way per invoice? Oh, the joys of owning airplanes when it comes to genuine proprietary parts, the VLSI, in avionics boxes we think are all that complicated, but to a good tech guy really ain't. Fred F. |
Well....
Operational check today.. xponder working fine, Ident working properly Hopefully the whole thing certed next week Ah.. joys of aircraft ownership... Flew 3 hrs today...smooth air, working trip, 2 hrs flying instead of 5 hrs driving...Cher on the CD player.... Makes working on the weekend almost fun! Dave On Mon, 14 Nov 2005 18:23:10 -0500, "TaxSrv" wrote: "Dave" wrote: Yup... more info.. tech here says there is a timing circuit that gets initialized when switched is closed. I can hear the switch "click" off when released.. He suspects the IC or something associated with it... The bummer about that the King VLSI chip is absolutely nothing in function like the 3 gigahertz Pentium CPU in our now cheapie damn computer, enormous heat sink now and all that. The service manuals always say to suspect the big IC last. Disheartening, when you see King's pricing on a 20-cent, common transistor. I was in an avionics shop once, and spotted a bin of them common transistors. Does FAA actually allow them to use those? And do they like just bill $$ that way per invoice? Oh, the joys of owning airplanes when it comes to genuine proprietary parts, the VLSI, in avionics boxes we think are all that complicated, but to a good tech guy really ain't. Fred F. |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Operation without a transponder | flyer | Piloting | 11 | September 14th 04 09:48 AM |
| Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 04:09 PM |
| Transponder petition | Ian Cant | Soaring | 11 | February 28th 04 07:38 AM |
| More on transponder petition | Ian Cant | Soaring | 1 | February 27th 04 07:37 PM |
