IFR with a VFR GPS
Old November 14th 05, 10:41 PM
Bob Noel
Default IFR with a VFR GPS
In article et,
"Steven P. McNicoll" wrote:
Do you see any hazard in the use of a handheld GPS during enroute IFR
flight?
Increased risk of hazardously misleading information.
I'll leave it to the safety experts to determine or estimate the
increased risk.
Bob Noel
no one likes an educated mule
  #172
Old November 14th 05, 10:56 PM
Steven P. McNicoll
"Bob Noel" wrote in message
What hazardously misleading information?
increased risk.
I posed a similar question to the safety experts some years ago, none could
identify any risk.
  #173
Old November 15th 05, 12:17 AM
Ron Lee
identify any risk.
Steven, if you have other sources that will alert you to GPS HMI then
you can make the assertion that from an overall system view you are
protected. If not, then you are at risk. FACT!
Of course the risk may be smaller than running out of gas and dying
but it is quantifiable at the rate of about 10E-4 per hour.
Ron Lee
  #174
Old November 15th 05, 12:24 AM
Bob Noel
In article et,
A navigation solution that is incorrect.
increased risk.
identify any risk.
If those safety experts were unable to identify any risk, then they didn't knew
the subject area. I suggest that you find some real safety experts with actual
knowledge of aviation.
Bob Noel
  #175
Old November 15th 05, 02:16 AM
Steven P. McNicoll
"Ron Lee" wrote in message
Well, then, since there are other sources that will alert to GPS "HMI", we
are protected.
  #176
Old November 15th 05, 02:20 AM
Steven P. McNicoll
What is the hazard?
knew
actual
There is no risk. Anyone that says there is a risk in the use of a handheld
GPS for IFR enroute navigation in US controlled airspace is not a real
safety expert with actual knowledge of aviation.
  #178
Old November 15th 05, 06:02 AM
Jose
What is the hazard?
Cumulo Granite.
Jose
He who laughs, lasts.
  #179
Old November 15th 05, 08:04 AM
Tauno Voipio
Steven P. McNicoll wrote:
"Tauno Voipio" wrote in message
There is one fundamental difference to other means
of IFR navigation: It is impossible to test and
approve the GPS signal. For the other NAVAIDs the
station can be measured on ground and fly the measuring
flights and compare the results with the specs in
ICAO Annex 10, and that's it.
Been there - done that.
Why is it impossible to test the GPS signal?
It is possible to measure the signal, but it does
not tell anything of the signals of the rest of the
constellation.
We can be pretty sure that an on-ground navaid
station will preform quite like how it did when
measuring it. There is no similar guarantee of
a satellite system controlled by a foreign
authority.
Also, there are no internationally accepted
standards of the GPS signal. For the other
navaids, there are technical performance
requirements in ICAO Annex 10 which is agreed
to be legally binding to all member states.
Tauno Voipio
tauno voipio (at) iki fi
  #180
Old November 15th 05, 01:33 PM
Steven P. McNicoll
"Jose" wrote in message
Cumulo Granite.
Explain.
