KX 175/195 tech support
Old November 18th 05, 05:54 AM posted to rec.aviation.homebuilt
Default KX 175/195 tech support
I want to ask the group, particularly the avionics guys in the group,
regarding installation of the King KX 175 and KY 195 radios.
I have the applicable pinouts loaded to my EAA chapter's website
http://www.eaa12.org/images/175-195outs.pdf for quick reference
I am using Jim Weirs Audio Panel/Intercom model 564/5 but that is likely
not a major factor in the questions
Item 1)
On the com side of things, there are aux audio 1-4 listed, (on pins 36,
37, 15 and 16). I am presuming these are audio OUTPUTS, want to verify
that (seems intuitive but I am not assuming ANYTHING). A notation on the
pinouts page indicates that "auxiliary audio #2" (pin 37) is intercom
mic input for these models. That conflicts with the presumption that i
WANT to make regarding these aux audios.
Jim's intercom/audio panel has two audio inputs from the respective
radios (phone in and speaker in, I am presuming speaker in doesnt have
sidetone)
Given this, I want to confirm on the 175 (or 195) com portion, that pin
41 "Speaker output" goes to the intercom "com# speaker input" and then
also confirm or determine if its Pin 37 "aux audio 2" that goes to the
intercom "com# phones in" (presumably with sidetone) If not, what is the
purpose of the aux audios?
Item 2)
Pin 34 is a COMM 500 Ohm output. What exactly is this used for? Is THIS
the headset output to the intercom?
Item 3)
Confirming that pins 17 and 18 remain bridged in 14V operation, and that
a transformer is inserted between 17 and 18 for 28V operation.
Item 4)
In the vicinity of pins 21,39 and 40, there is a dashed rectangle on the
schematic that appears tied to the speaker return and power ground, but
the dashed area crosses over/under/around the mike audio and key "lines"
on the schematic. Can someone clarify exactly what that dashed box
signifies?
Sorry if I am asking about things that I "should" know but I want to do
it right, while still doing it myself. Any help would be appreciated.
Dave Staten
Old November 18th 05, 07:37 AM posted to rec.aviation.homebuilt
"Dave S" wrote in message
nk.net...
Item 1)
pinouts page indicates that "auxiliary audio #2" (pin 37) is intercom mic
input for these models. That conflicts with the presumption that i WANT to
The Aux Audio pins are INPUT pins for those too cheap to buy an audio panel
yet want multiple inputs to a single phones/speaker output.
Jim's intercom/audio panel has two audio inputs from the respective radios
(phone in and speaker in, I am presuming speaker in doesnt have sidetone)
That is correct.
Given this, I want to confirm on the 175 (or 195) com portion, that pin 41
That is correct.
and then
No, the headphone output goes to the phones input on the audio panel
Item 2)
That is correct. That is the headphone output of this particular radio.
Item 3)
Confirming that pins 17 and 18 remain bridged in 14V operation, and that a
I have absolutely no idea other than to say that a transformer is never used
in a DC application.
Item 4)
signifies?
That signifies that all the wires contained within the dashed line are
shielded wires tied to the power ground.
Old November 18th 05, 06:39 PM posted to rec.aviation.homebuilt
Jim,
Thank you very much
Dave
35th's Life Support Section named best in the Air Force Otis Willie Military Aviation 0 July 17th 04 12:08 AM
24/7 computer tech support [email protected] Home Built 0 May 5th 04 04:32 AM
GPSMAP 296 - a bit of info from tech support ... Cockpit Colin Piloting 1 March 26th 04 08:36 PM
LONG DEPLOYMENTS, BENEFIT CUTS ERODE SUPPORT FOR PRESIDENT Ewe n0 who Naval Aviation 0 March 17th 04 08:57 PM
