I'm currently flying VFR in a vfr equipped plane. What would be the lowest
cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit |
tom pettit tompetatpeak wrote:
I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? Maybe something in the Apollo GX50/55/60/65 series? You'll find, though, that the cost of installation is a big part of making it IFR, so if you're going to spend a lot on installation, it seems a shame to waste it on a cheap unit. |
On 11/18/2005 13:28, tom pettit tompetatpeak wrote:
I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit Keep in mind that it takes a specific unit (a TSO one forty something rather than the TSO 129... I'm not sure I have those number correct) for the GPS unit to be used as the sole means of IFR navigation. I mention this, because you said your plane is not currently IFR capable. In order to use one of the TSO 129 certified GPS units for IFR flight, the plane must still have the navigation equipment on board for the ground based navigation aids along the route of flight. Does any of this apply to you? If not, sorry if I misunderstood your situation. -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
On Fri, 18 Nov 2005 13:28:32 -0800, tom pettitpeak wrote:
I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? Wow, low cost and IFR equipment in the same sentence just doesn't compute. With that in mind, I came across a Garmin dealer who was not making their quota and managed to get a hold of a GNS 430 radio for 6K with brand new warranty. My ILS nor localizer will not work for this 430 so I now have to get a new indicator. which is another 1.5K. Installation will be about 40 hours of work which equates to 2.8K or so. This is just for one radio, one indicator! My second radio will not be replaced at this time, to keep costs down. So..... if you only have a VFR equiped plane, this should get you a baseline for what is ahead of you. Allen |
Dave Butler wrote On 11/18/05 13:57,:
tom pettit tompetatpeak wrote: I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? Maybe something in the Apollo GX50/55/60/65 series? You'll find, though, that the cost of installation is a big part of making it IFR, so if you're going to spend a lot on installation, it seems a shame to waste it on a cheap unit. I went through this calculation way back in 2000 or so. I even had the advantage of having a loran that would have had an upgradable pinout to the Apollo. I went 430 and am happy with that decision. I doubt it would have saved any real money in any case. |
I don't currently have any navigation equipment. I was hoping that a
single, certified, gps unit could be used as primary, with an uncertified unit as back up. I was hoping I didn't need anything else. Reading the FARS it isn't very specific, or more likely, I just don't know enough about this stuff yet. thanks, tom "Mark Hansen" wrote in message ... On 11/18/2005 13:28, tom pettit tompetatpeak wrote: I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit Keep in mind that it takes a specific unit (a TSO one forty something rather than the TSO 129... I'm not sure I have those number correct) for the GPS unit to be used as the sole means of IFR navigation. I mention this, because you said your plane is not currently IFR capable. In order to use one of the TSO 129 certified GPS units for IFR flight, the plane must still have the navigation equipment on board for the ground based navigation aids along the route of flight. Does any of this apply to you? If not, sorry if I misunderstood your situation. -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
I have the GX55 in my Bonanza. They are approx $2K plus install. You
can install it either VFR only or IFR terminal/enroute. To be legal to accept a direct clearance you will have to get it legal for terminal/enroute. The GPS can be finnicky and it might cost hardly anything up to a couple thousand to get it IFR legal. There are some tests that the shop will run to make it legal, call any avionics shop and they will tell you what is involved. tom pettit tompetatpeak wrote: I'm currently flying VFR in a vfr equipped plane. What would be the lowest cost GPS based instrument system I could install and be legal for IFR flying? I looked through the last six months of this newsgroup, but didn't see a FAQ or the answer to the above, so I hope it won't be something that was just hashed out. thanks, tom pettit |
![]() tom pettit tompetatpeak wrote: I don't currently have any navigation equipment. I was hoping that a single, certified, gps unit could be used as primary, with an uncertified unit as back up. I was hoping I didn't need anything else. Reading the FARS it isn't very specific, or more likely, I just don't know enough about this stuff yet. Any real IFR work without a navcomm isn't practical. |
Since the bulk of the cost is installation the actual GPS unit you
select will not have a dramatic effect on end price. A GNS430 is about $11,000 installed here. Any other GPS is + or - $1000 or so. |
![]() Quote:
the king 90B (or 89B) comes with a generic STC - so you can save yourself the cost of the LSTC. there's usually a few of those for sale on e-bay as well. an IFR certified installation probably can't be done much under $3,500 by the time you add labour, paperwork, and required accessories such as a CDI or annunciator. i hope that helps, francois |
The frustrating economics of aviation | C J Campbell | Piloting | 96 | July 21st 04 04:41 PM |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Lowest Cost GPS Tracking System on the Market | Johann Blake | Soaring | 1 | November 19th 03 04:50 PM |
Lowest Cost GPS Tracking System on the Market | Johann Blake | Piloting | 0 | November 19th 03 04:06 PM |
Lowest cost per mile flown motor- 2 stroke | Bruce A. Frank | Home Built | 0 | July 2nd 03 06:25 AM |
