ILS critical area when the tower is closed?
Old November 20th 05, 07:28 PM posted to rec.aviation.ifr
Default ILS critical area when the tower is closed?
In this month's AOPA Flight Training magazine, I read an article
which implied there was still some requirement to remain clear of
the ILS critical area even when the tower was closed.
I've been looking through the AIM, and can't find anything like
this. It does say that when the tower is open, it will keep the
area clear when there is an aircraft past the FAF and the weather
is below 800/2.
Is there a rule which states that the ILS critical area must be
kept clear at any time when the tower is not in operation?
Can you please provide a reference?
Thanks,
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old November 20th 05, 07:34 PM posted to rec.aviation.ifr
Rule or not, if keeping clear of the ILS critical area is very important
when the tower is open, wouldn't you agree that it probably is just as
important when the tower is closed?
Peter
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old November 20th 05, 07:35 PM posted to rec.aviation.ifr
(sent too fast)
Assuming, of course, that ceilings and/or visibility were low and an
aircraft were on an ILS approach.
Peter
Old November 20th 05, 08:41 PM posted to rec.aviation.ifr
I don't see what the tower being open or closed has to do with it. They
don't shut down the ILS when the last controller goes home, and a plane in
the restricted area distorting the glideslope signal is not a good thing.
Bob Gardner
"Mark Hansen" wrote in message
is below 800/2.
Thanks,
Sacramento, CA
Old November 20th 05, 08:55 PM posted to rec.aviation.ifr
Sure. But the tower is the controlling authority which is instructing
planes to hold clear of the ILS critical area.
If the tower is not in operation, who gives the order?
If the pilot on the ground is supposed to know when to hold clear,
how does he know? He may not even know a plane is using the
ILS. And besides, the tower only needs to keep it clear when the
weather is below 800/2, so does this go for the non-towered airport
as well?
Where is this defined?
Bob Gardner
is below 800/2.
Thanks,
Sacramento, CA
Sacramento, CA
The reason you're supposed to keep clear of the ILS critical area is
because your airplane can affect the glide slope beam. The presence or
absence of somebody in the tower doesn't change the physics of how
microwaves interact with metallic bodies.
Old November 20th 05, 09:20 PM posted to rec.aviation.ifr
Thanks, but that wasn't my question. In fact, you snipped my question
out of the 'quote' which you included in your response.
Sacramento, CA
Old November 20th 05, 09:25 PM posted to rec.aviation.ifr
Nobody.
as well?
Well, if it's only a problem when an aircraft is on the ILS and it's below
800/2, and given that ATC isn't going to release an IFR departure if an
aircraft is on the ILS, then it doesn't appear to be a problem.
I don't believe it's defined anywhere.
Old November 20th 05, 09:39 PM posted to rec.aviation.ifr
Nobody.
as well?
I'm not sure that's the only time it's a problem. It just the minimum
that the tower is required to keep the area clear. I would expect that
ILS can be interfered with regardless of the current weather.
Thanks,
Sacramento, CA
Old November 20th 05, 09:55 PM posted to rec.aviation.ifr
I think the idea is that even a distorted GS will be accurate enough to get
you to within 800/2 of the runway.
comment period reopened on DC area "ADIZ" Bob Noel Piloting 3 November 15th 05 04:39 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
