#41
![]() wrote in message news:CX9gf.1261$pF.1153@fed1read04... It's a problem during a coupled approach especially if the pilot is planning to do an autoland. It's not a problem if the weather is good. |
#42
![]() "Jose" wrote in message . .. People may be taxiing around the airport with no intention of taking off, for example, to fuel up, to do maintanance, or to more the aircraft. With all that activity it's a wonder the tower is closed. |
#43
On Sun, 20 Nov 2005 21:36:38 -0500, Ron Rosenfeld wrote:
Does HKS have an ILS critical area? I don't see an ILS hold line on my charts. Ron, You had me pull out my NACO charts. I can't say about HKS as I am not intimately familiar with their airport, but I know KJAN has an critical ILS hold short line, but I don't see it depicted on the chart. Nor do I see any symbols on the airport diagram / airport sketch legend on page K1 of the MS / LA terminal procedures. Does NACO depict ILS hold lines on the airport diagrams would be my question. Don't forget, the premise of this particular sub-thread is that making the GS unusable when the tower is closed is a method of protecting the ILS critical area. But if the GS is unusable for some other reason, then ... Of course the chart doesn't say why the GS is unusable, just that it is WHEN tower is closed. Allen |
#44
![]() "A Lieberman" wrote in message ... I've seen it myself. One that comes to mind is HKS. On the approach plate, says when tower closed, GS unusable. Any idea why the GS is unusable when the tower is closed? I'd expect to find the GS on the east side of the runway, is that where it is? |
#45
On 11/20/2005 5:51 PM, Bob Gardner wrote:
Good point about the 'hold short' transmission. Brain fart. Seems to me that at one point you wondered how a pilot was expected to know that there was an ILS critical area without being told by the tower...that is why I referred to the taxiway markings. No, I was asking how the pilot would know to hold clear of the ILS critical area, not where it was located on the airport. But anyway, I think I have my answer. Thanks for your help. Bob "Mark Hansen" wrote in message ... On 11/20/2005 2:54 PM, Bob Gardner wrote: AIM Figure 2-3-16? Sorry I wasn't clear, Bob. I wasn't asking where the hold short or ILS markings were or how they were depicted at the airport. If there are taxiway markings for an ILS critical area, and the departing pilot knows that the weather is even close to 800-2, s/he doesn't have to depend on a controller for instructions. The controlling authority (in the absence of a controller) knows what the situation with regards to inbounds is and can advise the departing pilot if there is someone on the way in. "Hold short of runway 16, traffic on two mile final." Just who is going to say "Hold short" when the tower is closed? Perhaps the only time you have to worry about the ILS critical area is when the weather is below 800/2, in which case only IFR departures will be of concern, and they won't get their clearance unless the airspace is clear. Assuming the weather is above VFR minimums, VFR arrivals and departures could interfere with the ILS system, and there appears to be no protocol to prevent that, since any airplane using the system isn't depending on it to get to minimums anyway? Well, I guess I have my answer. Bob Gardner "Mark Hansen" wrote in message ... On 11/20/2005 12:41 PM, Bob Gardner wrote: I don't see what the tower being open or closed has to do with it. They don't shut down the ILS when the last controller goes home, and a plane in the restricted area distorting the glideslope signal is not a good thing. Sure. But the tower is the controlling authority which is instructing planes to hold clear of the ILS critical area. If the tower is not in operation, who gives the order? If the pilot on the ground is supposed to know when to hold clear, how does he know? He may not even know a plane is using the ILS. And besides, the tower only needs to keep it clear when the weather is below 800/2, so does this go for the non-towered airport as well? Where is this defined? Bob Gardner "Mark Hansen" wrote in message ... In this month's AOPA Flight Training magazine, I read an article which implied there was still some requirement to remain clear of the ILS critical area even when the tower was closed. I've been looking through the AIM, and can't find anything like this. It does say that when the tower is open, it will keep the area clear when there is an aircraft past the FAF and the weather is below 800/2. Is there a rule which states that the ILS critical area must be kept clear at any time when the tower is not in operation? Can you please provide a reference? Thanks, -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
#46
On 11/20/2005 6:38 PM, Jose wrote:
the weather is below 800/2, in which case only IFR departures will be of concern People may be taxiing around the airport with no intention of taking off, for example, to fuel up, to do maintanance, or to more the aircraft. I suppose such an aircraft could call departure first, to ensure that such operation will not interfere with anybody on approach. Jose With weather below 800/2, the only people in the vicinity of the ILS critical area would be IFR departures, right? I can't think of any reason to be taxiing to the departure end of a runway unless you're taking off (or just landed). In either case, the flight would be IFR due to the weather. I was really thinking more of the case during VFR conditions where the ILS system is being used more for practice. I think the bottom line is, if you're using an ILS during VFR conditions, you should expect some interference in the signal whether or not the tower is in operation - since even if it is in operation, it doesn't have to keep the ILS critical area clear unless weather is below 800/2. Thanks, -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
#47
#48
![]() "Mark Hansen" wrote in message ... How would a VFR departure know that there might be another airplane on a 10 mile final using the ILS system at a non-towered field? By monitoring CTAF? But what is the problem here for a VFR departure? |
#49
Steven P. McNicoll wrote:
"A Lieberman" wrote in message ... I've seen it myself. One that comes to mind is HKS. On the approach plate, says when tower closed, GS unusable. Any idea why the GS is unusable when the tower is closed? I'd expect to find the GS on the east side of the runway, is that where it is? I believe ELM switches the ILS from 6 to 24 depending on the wind direction. I've never landed after midnight when the tower closes, but I wonder if they leave the ILS on and leave an ATIS message as to which runway is ILS active? Never thought about it before this thread. I guess I always assumed they would turn off the approach when the controllers go home, but maybe not. Matt |
#50
Matt Whiting wrote:
I believe ELM switches the ILS from 6 to 24 depending on the wind direction. I've never landed after midnight when the tower closes, but I wonder if they leave the ILS on and leave an ATIS message as to which runway is ILS active? That's exactly what they do at HPN. |
comment period reopened on DC area "ADIZ" | Bob Noel | Piloting | 3 | November 15th 05 04:39 PM |
Los Angeles radio tower crash kills 2 | Paul Hirose | Piloting | 178 | August 6th 05 03:46 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
ILS Critical Area signage: Localizer or Glideslope? | Adam K. | Instrument Flight Rules | 4 | October 30th 03 10:09 PM |
Patrick AFB Area Log, Monday 30 June 2003 | AllanStern | Military Aviation | 0 | July 1st 03 06:37 AM |
