ILS critical area when the tower is closed?
Old November 21st 05, 03:01 AM posted to rec.aviation.ifr
Default ILS critical area when the tower is closed?
wrote in message news:CX9gf.1261$pF.1153@fed1read04...
It's a problem during a coupled approach especially if the pilot is
planning to do an autoland.
It's not a problem if the weather is good.
  #42
Old November 21st 05, 03:07 AM posted to rec.aviation.ifr
"Jose" wrote in message
People may be taxiing around the airport with no intention of taking off,
for example, to fuel up, to do maintanance, or to more the aircraft.
With all that activity it's a wonder the tower is closed.
  #43
Old November 21st 05, 03:13 AM posted to rec.aviation.ifr
On Sun, 20 Nov 2005 21:36:38 -0500, Ron Rosenfeld wrote:
Does HKS have an ILS critical area?
I don't see an ILS hold line on my charts.
Ron,
You had me pull out my NACO charts. I can't say about HKS as I am not
intimately familiar with their airport, but I know KJAN has an critical ILS
hold short line, but I don't see it depicted on the chart.
Nor do I see any symbols on the airport diagram / airport sketch legend on
page K1 of the MS / LA terminal procedures.
Does NACO depict ILS hold lines on the airport diagrams would be my
question.
Don't forget, the premise of this particular sub-thread is that making the
GS unusable when the tower is closed is a method of protecting the ILS
critical area. But if the GS is unusable for some other reason, then ...
Of course the chart doesn't say why the GS is unusable, just that it is
WHEN tower is closed.
Allen
  #44
Old November 21st 05, 03:19 AM posted to rec.aviation.ifr
"A Lieberman" wrote in message
I've seen it myself. One that comes to mind is HKS.
On the approach plate, says when tower closed, GS unusable.
Any idea why the GS is unusable when the tower is closed? I'd expect to
find the GS on the east side of the runway, is that where it is?
  #45
Old November 21st 05, 03:28 AM posted to rec.aviation.ifr
On 11/20/2005 5:51 PM, Bob Gardner wrote:
Good point about the 'hold short' transmission. Brain fart.
Seems to me that at one point you wondered how a pilot was expected to know
that there was an ILS critical area without being told by the tower...that
is why I referred to the taxiway markings.
No, I was asking how the pilot would know to hold clear of the ILS
critical area, not where it was located on the airport.
But anyway, I think I have my answer. Thanks for your help.
Bob
"Mark Hansen" wrote in message
On 11/20/2005 2:54 PM, Bob Gardner wrote:
AIM Figure 2-3-16?
Sorry I wasn't clear, Bob. I wasn't asking where the hold short
or ILS markings were or how they were depicted at the airport.
If there are taxiway markings for an ILS critical
area,
and the departing pilot knows that the weather is even close to 800-2,
s/he doesn't have to depend on a controller for instructions. The
controlling authority (in the absence of a controller) knows what the
situation with regards to inbounds is and can advise the departing pilot
if there is someone on the way in. "Hold short of runway 16, traffic on
two mile final."
Just who is going to say "Hold short" when the tower is closed?
Perhaps the only time you have to worry about the ILS critical area
is when the weather is below 800/2, in which case only IFR departures
will be of concern, and they won't get their clearance unless the
airspace is clear.
Assuming the weather is above VFR minimums, VFR arrivals and departures
could interfere with the ILS system, and there appears to be no protocol
to prevent that, since any airplane using the system isn't depending on it
to get to minimums anyway?
Well, I guess I have my answer.
Bob Gardner
On 11/20/2005 12:41 PM, Bob Gardner wrote:
I don't see what the tower being open or closed has to do with it. They
don't shut down the ILS when the last controller goes home, and a plane
in the restricted area distorting the glideslope signal is not a good
thing.
Sure. But the tower is the controlling authority which is instructing
planes to hold clear of the ILS critical area.
If the tower is not in operation, who gives the order?
If the pilot on the ground is supposed to know when to hold clear,
how does he know? He may not even know a plane is using the
ILS. And besides, the tower only needs to keep it clear when the
weather is below 800/2, so does this go for the non-towered airport
as well?
Where is this defined?
Bob Gardner
In this month's AOPA Flight Training magazine, I read an article
which implied there was still some requirement to remain clear of
the ILS critical area even when the tower was closed.
I've been looking through the AIM, and can't find anything like
this. It does say that when the tower is open, it will keep the
area clear when there is an aircraft past the FAF and the weather
is below 800/2.
Is there a rule which states that the ILS critical area must be
kept clear at any time when the tower is not in operation?
Can you please provide a reference?
Thanks,
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Sacramento, CA
Sacramento, CA
Sacramento, CA
  #46
Old November 21st 05, 03:32 AM posted to rec.aviation.ifr
will be of concern
off, for example, to fuel up, to do maintanance, or to more the aircraft.
I suppose such an aircraft could call departure first, to ensure that
such operation will not interfere with anybody on approach.
Jose
With weather below 800/2, the only people in the vicinity of the
ILS critical area would be IFR departures, right? I can't think
of any reason to be taxiing to the departure end of a runway unless
you're taking off (or just landed). In either case, the flight would
be IFR due to the weather.
I was really thinking more of the case during VFR conditions where
the ILS system is being used more for practice. I think the bottom
line is, if you're using an ILS during VFR conditions, you should
expect some interference in the signal whether or not the tower is
in operation - since even if it is in operation, it doesn't have to
keep the ILS critical area clear unless weather is below 800/2.
Thanks,
Sacramento, CA
  #48
Old November 21st 05, 03:42 AM posted to rec.aviation.ifr
How would a VFR departure know
that there might be another airplane on a 10 mile final using the ILS
system at a non-towered field?
By monitoring CTAF? But what is the problem here for a VFR departure?
  #49
Old November 21st 05, 03:55 AM posted to rec.aviation.ifr
I believe ELM switches the ILS from 6 to 24 depending on the wind
direction. I've never landed after midnight when the tower closes, but
I wonder if they leave the ILS on and leave an ATIS message as to which
runway is ILS active? Never thought about it before this thread. I
guess I always assumed they would turn off the approach when the
controllers go home, but maybe not.
Matt
  #50
Old November 21st 05, 03:59 AM posted to rec.aviation.ifr
That's exactly what they do at HPN.
comment period reopened on DC area "ADIZ" Bob Noel Piloting 3 November 15th 05 04:39 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
