ILS critical area when the tower is closed?
Old November 21st 05, 04:10 AM posted to rec.aviation.ifr
Default ILS critical area when the tower is closed?
People may be taxiing around the airport with no intention of taking off,
for example, to fuel up, to do maintanance, or to more the aircraft.
With all that activity it's a wonder the tower is closed.
One aircraft is sufficient.
Jose
He who laughs, lasts.
  #52
Old November 21st 05, 04:12 AM posted to rec.aviation.ifr
With weather below 800/2, the only people in the vicinity of the
ILS critical area would be IFR departures, right?
I don't know. Therefore I wouldn't count on it. I suspect it depends
on the specific geography of the airport.
Jose
  #53
"Matt Whiting" wrote in message
I believe ELM switches the ILS from 6 to 24 depending on the wind
direction.
Both localizers are on 109.1, only one can be selected at any time.
I've never landed after midnight when the tower closes, but I wonder if
they leave the ILS on and leave an ATIS message as to which runway is ILS
active?
Possibly, but all they'd have to do is advise New York Center which ILS is
up.
Never thought about it before this thread. I guess I always assumed they
would turn off the approach when the controllers go home, but maybe not.
These things are turned off for maintenance or runway closures, that's
pretty much it.
  #54
Old November 21st 05, 04:14 AM posted to rec.aviation.ifr
"Jose" wrote in message
It's typically not enough to keep the fuel vendor open.
  #55
Jose
Doesn't even have to be an aircraft. A car or truck would disrupt the
signal too. Some uncontrolled airports have some pretty strange stuff
going on.
  #56
Old November 21st 05, 04:34 AM posted to rec.aviation.ifr
On Sun, 20 Nov 2005 21:13:54 -0600, A Lieberman
On Sun, 20 Nov 2005 21:36:38 -0500, Ron Rosenfeld wrote:
Does HKS have an ILS critical area?
I don't see an ILS hold line on my charts.
Ron,
You had me pull out my NACO charts. I can't say about HKS as I am not
intimately familiar with their airport, but I know KJAN has an critical ILS
hold short line, but I don't see it depicted on the chart.
Nor do I see any symbols on the airport diagram / airport sketch legend on
page K1 of the MS / LA terminal procedures.
Does NACO depict ILS hold lines on the airport diagrams would be my
question.
Don't forget, the premise of this particular sub-thread is that making the
GS unusable when the tower is closed is a method of protecting the ILS
critical area. But if the GS is unusable for some other reason, then ...
Of course the chart doesn't say why the GS is unusable, just that it is
WHEN tower is closed.
Allen
Both Jepp and NACO depict something they call ILS Hold Lines at some
airports. Jepp does not define anything on their airport view with the
term "ILS Critical Area" so I don't know if these ILS hold lines have
anything to do with the ILS Critical area.
  #57
Old November 21st 05, 04:53 AM posted to rec.aviation.ifr
Sure it is. The fuel vendor is a machine. It doesn't sleep, and never
leaves the airport.
The fuel vendor is typically a person.
  #58
Old November 21st 05, 04:56 AM posted to rec.aviation.ifr
The fuel vendor is typically a machine.
Jose
  #59
Old November 21st 05, 06:40 AM posted to rec.aviation.ifr
Up until 2 months ago, there was an ILS critical area at an untowered
field.. KGLS Galveston, TX, and it had been there since i started flying
in 2000.
Galveston now has a part time tower.
Dave
Steven P. McNicoll wrote:
"Bob Gardner" wrote in message
news
How many fields are there where this is a concern? I would expect
most fields with the congestion to require marked ILS critical areas
to have full-time towers.
I can't provide a cite, but I was told recently that there are ILS
critical areas at part-time towered airports.
  #60
Old November 21st 05, 03:02 PM posted to rec.aviation.ifr
wrote in message news:CX9gf.1261$pF.1153@fed1read04...
It's a problem during a coupled approach especially if the pilot is
planning to do an autoland.
It's not a problem if the weather is good.
Not so, Steve. It can cause control problems and certainly adversely
affect an autoland. That is why your handbook contains a caveat about
such approaches.
Approach couplers and autoland systems are weather independent.~
comment period reopened on DC area "ADIZ" Bob Noel Piloting 3 November 15th 05 04:39 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
