Prop strike effect on resale value?
Old November 21st 05, 07:42 PM posted to rec.aviation.owning
Default Prop strike effect on resale value?
Got a general question for the group:
If a used plane is for sale on the market, what effect is a prior prop
strike going to have on it's resale value?
I haven't found anything on any of the valuation services like Vref that
talk about any kind of previous damage.
I know it's all in the eye of the beholder, but I'm wondering if there is
any presidence in devaluation based on previous damage history.
Thanks.
Old November 21st 05, 08:17 PM posted to rec.aviation.owning
None if the engine was torn down and repaired as necessary. If not then
I wouldn't buy it except as a run out.
Previous damage history is airplane dependent. For example there's
practically no such thing as a Cub that hasn't been rolled up into a
ball and rebuilt. They are the most expensive Cubs out there. Same
goes for 182's. Everybody knows they are nose heavy and will land on
the nosewheel if you let it, causing a wrinkled firewall. That's damage
history but if it's fixed right there's no hit on value. I sold my 182
in August and there was no negotiating down for the third firewall my
plane had. Take a Cherokee on the other hand and back an elevator or
flap or aileron into a hangar and buyers will want a price break.
Old November 21st 05, 08:19 PM posted to rec.aviation.owning
It depends. How long ago? Was the prop overhauled? Replaced? Engine overhauled?
I don't think you'll find a cut-and-dried answer. It just comes down to what
else is available, at what price, and what the seller and buyer are willing to do.
For something like that, skip the freebie evaluation services. Pay ~$20 and get
a valuation from http://www.aeroprice.com
Whether there are any precedents?
Old November 21st 05, 08:55 PM posted to rec.aviation.owning
Seems like the value changes for 5 years. After that, no effect.
Old November 21st 05, 11:01 PM posted to rec.aviation.owning
"Newps" wrote in message
None if the engine was torn down and repaired as necessary. If not then I
practically no such thing as a Cub that hasn't been rolled up into a ball
and rebuilt. They are the most expensive Cubs out there. Same goes for
182's. Everybody knows they are nose heavy and will land on the nosewheel
if you let it, causing a wrinkled firewall. That's damage history but if
it's fixed right there's no hit on value. I sold my 182 in August and
there was no negotiating down for the third firewall my plane had. Take a
Cherokee on the other hand and back an elevator or flap or aileron into a
http://tinyurl.com/b7zlc
The comparable aircraft are $40K or so higher.
Old November 22nd 05, 03:26 AM posted to rec.aviation.owning
I'd be concerned about what else was damaged. If there was a prop
strike, was there firewall damage. If so, was it repaired correctly.
Also, field rebuilds are a bit iffy. Repairs completed by Steve's
Aircraft. Who is Steve? Just what did he really do? How many hours
since the rebuild. Is all well?
If all is well and everything checks out (COMPRESSION check), oil burn,
filter clean, then yeah, ok.
Like the others say, after a bit of time, the devaluation goes away.
Old November 22nd 05, 01:42 PM posted to rec.aviation.owning
As others have stated, you need to follow the engine manufacturer's
instructions following a prop strike or "sudden engine stoppage".
Usually this calls for inspection of the crank runout at a minimum. Some
call for engine teardown and magnafluxing parts. Still other engines
require replacement of certain parts like counterweights, camshaft
gears/bolts and other timing gears. I believe it depends on the make and
model of the engine, although others more familiar with this can chime in.
As the fleet ages, trainers especially can be expected to have SOME
damage SOMEWHERE in their history. Proper repairs (as evidenced through
documentation and inspection) and time appear to mitigate any devaluation.
My '74 Cherokee 140 did a ground loop in 1975 at 398 hours since new.
Tore down engine, inspected/replaced all the necessary stuff, replaced
the flaps, stabilitor, and an outer wing skin. Spars checked O.K. All
replacements and skin work flawless (as inspected by several wrenches
over the years). I now have 2600 hours on it.
Will I take one penny off for a 30 year old repair that is invisible,
one whole engine ago, and has withstood the test of time. Nope. And I
will have PLENTY of other buyers who will snap it up if someone insists
on a lower price for the damage history.
Now, a recent prop strike, that is another matter. The opportunity for
hidden or latent damage is quite a bit greater. Eliminate the engine
(via overhaul or replacement), overhaul/inspect the prop, and inspect
the rest of the bird and you probably won't care as much. Don't do those
things and I would personally consider the engine and prop as trash. I
would still insist on a careful inspection of the rest of the bird.
Others may disagree, but it is your money and risk.
Good Luck,
Mike
Old November 22nd 05, 03:23 PM posted to rec.aviation.owning
Seems odd that for an aircraft in that price range, where the market is national
and not local, if the owner knew the plane would go on the market, he would
choose to have the repairs done by a shop without a national reputation. [Sorry
for that tortured sentence. Where's my editor?]
Old November 22nd 05, 03:42 PM posted to rec.aviation.owning
"Some" includes both Lycoming and Continental.
Old November 22nd 05, 03:56 PM posted to rec.aviation.owning
A recent AD forces the owners of Lycomings to take any sort of
propstrike seriously, as the bolt that holds the gear on the back end
of the crank tends to fail or loosen during a sudden RPM drop. I wonder
if Lycoming will design the next engine with some different means of
retaining that gear...
Here's the AD text. Note Lycoming's definition of "prop
strike."
Dan
2004-10-14 Lycoming Engines (formerly Textron Lycoming): Amendment
39-13644. Docket No. 89-ANE-10-AD. Supersedes AD 91-14-22, Amendment
39-6916.
Effective Date
(a) This AD becomes effective June 25, 2004.
Affected ADs
(b) This AD supersedes AD 91-14-22.
Applicability
(c) This AD applies to
Lycoming Engines (formerly Textron Lycoming),
direct-drive reciprocating engines
(except O-145, O-320H, O-360E, LO-360E, LTO-360E, TO-360-E, O-435, and
TIO-541 series engines).
Unsafe Condition
(d) This AD results from a change to the definition of a propeller
strike or sudden stoppage. The actions specified in this AD are
intended to prevent loosening or failure of the crankshaft gear
retaining bolt, which may cause sudden engine failure.
Compliance
(e) Compliance with this AD is required as indicated before further
flight if the engine experiences a propeller strike after the effective
date of this AD, as defined in paragraphs (i) and (j) of this AD.
(f) Inspect, and if necessary repair, the crankshaft counter bored
recess, the alignment dowel, the bolt hole threads, and the crankshaft
gear for wear, galling, corrosion, and fretting in accordance with
steps 1 through 5 of Lycoming Mandatory Service Bulletin (MSB) No.
475C, dated January 30, 2003.
(g) Remove the existing gear retaining bolt and lockplate from
service, and install a new bolt and lockplate, in accordance with steps
6 and 7 of Lycoming MSB No. 475C, dated January 30, 2003.
Prohibition of Retaining Bolt and Lockplate
(h) Do not install the gear retaining bolt and lockplate that were
removed in paragraph (g) of this AD, into any engine.
Definition of Propeller Strike
(i) For the purposes of this AD, a propeller strike is defined as
follows:
(1) Any incident, whether or not the engine is operating, that
requires repair to the propeller other than minor dressing of the
blades.
(2) Any incident during engine operation in which the propeller
impacts a solid object that causes a drop in revolutions per minute
(RPM) and also requires structural repair of the propeller (incidents
requiring only paint touch-up are not included). This is not restricted
to propeller strikes against the ground.
(3) A sudden RPM drop while impacting water, tall grass, or similar
yielding medium, where propeller damage is not normally incurred.
(j) The preceding definitions include situations where an aircraft
is stationary and the landing gear collapses causing one or more blades
to be substantially bent, or where a hanger door (or other object)
strikes the propeller blade. These cases should be handled as sudden
stoppages because of potentially severe side loading on the crankshaft
flange, front bearing, and seal.
Why does a prop ice up so apparently readily? Mike Rapoport Piloting 2 November 8th 05 02:52 PM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Prop Strike Query Dick Home Built 12 November 16th 04 02:20 AM
Prop Strike in Milwaukee Ben Smith Piloting 9 October 1st 04 11:21 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
