Propeller thrust question
Old November 24th 05, 09:12 PM posted to rec.aviation.piloting
Default Propeller thrust question
"Dave Doe" wrote in message
. nz...
Ahhh yeah. Just realised you'd never hit the zero thrust speed. Woops!
And PS: yep, all of us light a/c folk have hit that. I think we've all
flown flat out, level flight. Quite a few light a/c are approved to run
continuous full throttle
That's not the "zero thrust speed".
Old November 25th 05, 03:12 AM posted to rec.aviation.piloting
xerj wrote:
If so, is it a case of the speed very slightly and imperceptibly dipping
below the zero thrust speed, getting a little thrust to bring it back to the
zero-thrust condition and doing this over and over again?
Nope, all things being maintained constant, the aircraft maintains a
steady state equilibrium.
Dave
Static thrust for Sonex with 54" prop Mel Home Built 3 November 2nd 05 12:31 AM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
turbine propeller sebastian Home Built 19 March 21st 04 12:47 AM
