VW Redrive Mounted on the Case's Generator Pad?
Old November 26th 05, 08:15 AM posted to rec.aviation.homebuilt
Default VW Redrive Mounted on the Case's Generator Pad?
On Fri, 25 Nov 2005 23:16:20 -0500, "Morgans" wrote:
"Ron Wanttaja" wrote
In either case, he swapped it for a VW with the Valley Engineering PSRU
and is
now turning a 96 inch diameter prop with 60 inches of pitch. He claims it
provides 70% more thrust than the old engine. Hmmm, lengthen the gear
legs on
the Fly Baby.... :-)
Wow! It is hard for me to get my brain wrapped around the fact that a VW
could be stronger than an A-75, even with a redrive!
OX-5 engine: 90 HP
O-200 engine: 100 HP
Pull the OX-5 out of a Jenny, install an O-200, and try flying.
Back in the '60s, Boeing decided to build a replica of their first aircraft, the
B&W (Boeing and Westervelt) for the 50th anniversary of the company. The
original was a great big biplane and had a 125hp Hall-Scott A-5 engine with a
long, wide-chord prop.
http://www.centennialofflight.gov/es...y/Aero17G2.htm
The replica was ALSO a great big biplane. They used a geared GO-435 engine with
twice the horsepower and a leetle-bitty propeller.
http://1000aircraftphotos.com/Biplanes/BoeingB-W.htm
I've heard that the replica, even with twice the horsepower, can barely get out
of its own way. Big draggy airplanes want big, slow-turning props, and
apparently half the HP is OK if it's being pushed into a big prop.
Old November 28th 05, 05:15 PM posted to rec.aviation.homebuilt
On Sat, 26 Nov 2005 00:15:29 -0800, Ron Wanttaja
That's the basic formula all WWI era aircraft used. All the pics of
them show these monster props with very little ground clearance.
Since they didn't fly very fast, it didn't matter that the props were
slow spinners.
Corky Scott
Fin Mounted TE Prob vs fuselage mounted TE prob [email protected] Soaring 8 June 4th 05 10:39 PM
WTB Tall Redrive Rotax 503 Jean-Paul Roy Aviation Marketplace 1 February 29th 04 10:44 AM
WTB Tall Redrive 503 Rotax Jean-Paul Roy Piloting 1 February 29th 04 10:41 AM
WTB Redrive 503 Rotax Jean-Paul Roy Restoration 1 February 29th 04 10:38 AM
WTB Tall Redrive 503 Rotax Jean-Paul Roy Home Built 0 February 17th 04 03:02 PM
