Garmin GPSmap 196 on 172 Yoke
Old February 16th 04, 07:19 AM
Otto Braasch
Default Garmin GPSmap 196 on 172 Yoke
Hi,
Planning to put a GPSmap 196 for backup in my Cessna 172 I
would appreciate to learn whether somebody has mounted a 196 on a
172 yoke? May I learn about the mounting gear used - original
Garmin or OEM hardware like RAM?
How about drawbacks or pros experienced with either gear?
Otto Braasch (EDML)
Old February 16th 04, 04:38 PM
C J Campbell
The original Garmin mount works fine as such things go.
There are some problems with mounting things on the yoke:
1) The yoke feels funny. It takes some getting used to.
2) Either the instrument is mounted so low as to be difficult to see or it
is high enough to obscure more important instruments.
3) If you have a big tummy like mine, a GPS mounted on the yoke is even
harder to see and makes it hard to use full travel on the yoke.
4) Newer Cessnas have a built-in yoke clip that either interferes with yoke
mounts or can't be used with the mount in place.
I do not like yoke mounts. I do not like kneeboards, either. In fact, I have
not found anyplace to put a handheld GPS where it is not more trouble than
it is worth, though I have found setting it on a beanbag on the dash to be
less offensive than most locations. Even there it is hard to reach the
controls of the GPS and it interferes with the compass and obscures part of
your view.
Old February 16th 04, 06:16 PM
David B. Cole
I've used the Garmin yoke mount on the 172 several times. No big deal
as far as the ease of mounting it. Of course with a yoke mount the
GPS moves whenever the yoke moves, it's not directly in your field of
view as it would be mounted on top of the panel, and you may not get
as much yoke travel on the flare unless you remove it prior to
landing. I'm trying to figure out how I'll mount it when I have a
yoke clip attached when flying IFR in a plane without a panel mount
GPS.
Dave
Otto Braasch wrote in message ...
Hi,
Otto Braasch (EDML)
Old February 17th 04, 09:09 PM
Tom Fleischman
In article , David B.
landing.
How would it affect the yoke travel when pulling back during the flare?
It would be mounted on thge yoke shaft just forward of the yoke itself.
I could see how it might affect the yoke travel if you had to push it
all the way in and dive, but how often would have to do that in a 172?
GPS.
Put the GPS on the yoke and the approach plate on your kneeboard (one
of the few real uses for a small kneeboard).
Old February 18th 04, 12:04 AM
C J Campbell
"Tom Fleischman" wrote in message
rthlink.net...
landing.
GPS.
I don't like the idea of an approach plate on a kneeboard because it forces
you to look down and increases the chance of disorientation and causes you
to interrupt your scan for longer than necessary.
The way the 196 and 295 yoke mounts work is they have an arm that puts the
GPS over the top of the yoke and down in the front and center. I doubt if
you could mount it entirely behind the yoke without severely restricting
travel. The GPS does not restrict yoke travel in the flare or even when
practicing stalls and spins unless you are obese, like me. (And I worked
hard to get that way, too. However, I am tired of being so cramped in the
airplane so I am slowly losing weight now.)
Old February 18th 04, 02:38 AM
Doug
None of the handhelds are as good as having a panel mount.
But if you are going to have a handheld, the most satisfactory
solution is to mount a Garmin III above the glareshield (or beanbag
it).
I have a 195 as a backup to my panel mount and I just put it on my
knee, (when I use it at all, which is occasionally as it has better
maps of Class B airspace and has ground feature information (roads
rivers etc).
Old February 18th 04, 03:42 AM
Wyatt Emmerich
I have a 196 yoke mount. Works great. Also have a 530. Use them both. The
Garmin 196 is a great battery backup and the yoke is a fine place to mount
it. Near the hands and the eyes.Properly installed, there is no restriction
issues at all.
"Otto Braasch" wrote in message
Hi,
Otto Braasch (EDML)
Old February 18th 04, 04:12 AM
Craig Prouse
issues at all.
I bought a Garmin 195 several years ago, and a few months later I
unexpectedly acquired an airplane with an IFR panel mount GPS. I tried
a couple times to use the handheld on its yoke mount (as the moving map
is clearly better than that on the panel mount) but I much prefer
keeping that space available for approach plates and my timer, and
frankly I prefer that space to be empty whenever possible. So
unfortunately, my handheld GPS has become a very expensive toy and
electronic flight planner. I use it on the ground to mark waypoints
that I wish to overfly later, like relatives' houses.
I even tried mounting the handheld on the copilot's yoke for backup, but
it's difficult to see the screen and nearly impossible to push the
buttons. But I have a dream, and I'll tell you exactly what it would
take to get me using the thing routinely as a backup: it would be some
sort of articulated arm that mounts to the inside of my seat mechanism.
Sort of like the adjustable neck on an iMac, so I could raise, lower,
and swing the thing in and out of my field of view as required. I think
police cars sometimes have their mobile display terminals mounted like
that? Yeah, that would be pretty cool and it would probably cost
hundreds.
Where do people keep their approach plates when there's a handheld GPS
on the yoke, anyway? I always use my yoke clip in day conditions, but
due to lighting considerations I have to move the plate to my lapboard
at night. It's not optimal due to distance and required head movement,
but at least there's a light shining on it.
Old February 18th 04, 05:03 AM
Dan Truesdell
---------- Snip -----------
I usually mount my Magellan 315 on the panel in the corner (secured by a
bent piece of cookie sheet). I, too, like to keep my yoke mount for
approach plates. As for night, I have a small red led light velcroed to
my headset (one of those inch-long flat thingies). It's easy to turn on
when needed, and can be kept on if necessary in the event of an
electrical failure. (I carry a flashlight, too.)
Remove "2PLANES" to reply.
Old February 21st 04, 09:28 AM
Otto Braasch
On Mon, 16 Feb 2004 "C J Campbell" wrote:
Subject: Garmin GPSmap 196 on 172 Yoke
Date: Mon, 16 Feb 2004 08:38:16 -0800
your view.
Christopher,
Thanks for pointing to the facts and drawbacks of having a GPS on the yoke. My 196
and a RAM mount arrived yesterday. I will report on the installation - it may take a
weeks however before I get into the plane again.
Used to kneeboards from the military I have not problem with that.
Cheers - Otto
Garmin Price Fixing Post from other newsgroup TripodBill Home Built 17 August 4th 04 10:42 AM
Garmin fixes moving waypoint problem -- almost Jon Woellhaf Instrument Flight Rules 6 November 28th 03 05:29 PM
who moved SAV, forgot to tell Jepp? Dave Butler Instrument Flight Rules 15 November 9th 03 02:16 AM
CH Product Yoke with IP Trainer 6.5 Sanjay Kumar Instrument Flight Rules 2 October 10th 03 07:47 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
