I don't know what to do about this . . . hoping the collective wisdom
here might have some ideas. For the last 3 months or so, after every flight, there are small streaks of oil on the inside of the lower cowling on my 67 'Hawk . . . if I don't wipe them up, they drip down on the tire of my nose gear. My mechanics have replaced all 6 rocker box covers and gaskets, and re-flared the push rod tubes. I have spent almost $1000.00 so far and it's still leaking. It holds pressure just fine . . . my mechanics are now suggesting replacing all the push rod tubes, but I get the feeling they are just guessing. Any ideas? www.Rosspilot.com |
On 30 Nov 2005 17:07:17 -0800, "
wrote: I don't know what to do about this . . . hoping the collective wisdom here might have some ideas. For the last 3 months or so, after every flight, there are small streaks of oil on the inside of the lower cowling on my 67 'Hawk . . . if I don't wipe them up, they drip down on the tire of my nose gear. My mechanics have replaced all 6 rocker box covers and gaskets, and re-flared the push rod tubes. I have spent almost $1000.00 so far and it's still leaking. It holds pressure just fine . . . my mechanics are now suggesting replacing all the push rod tubes, but I get the feeling they are just guessing. Any ideas? www.Rosspilot.com Give the engine a real good cleaning then run it up shut down pull the cowl and check with an ultraviolet light to spot the source of the oil |
What gaskets did they use on the rocker covers?
We replaced with the orange silicone gaskets, and torqued them to specs. Make sure the dipstick isn't leaking and how much oil are you carrying? Its definitely not the dipstick, and I carry between 6-7 qts. Last Aug, during annual, I installed an Airwolf Separator . . . because I was blowing out all but 6 and I wanted to maintain at least 7. That definitely isn't the problem, either (according to mechanics). Thanks for input. www.Rosspilot.com |
the cowl and check with an ultraviolet light to spot the source of the oil OK--will try the UV light . . . we didn't use that. They just used a flashlight for visual inspection and fingers to feel for the wet spots .. . . www.Rosspilot.com |
![]() I don't know what to do about this . . . hoping the collective wisdom here might have some ideas. For the last 3 months or so, after every flight, there are small streaks of oil on the inside of the lower Has a similar problem when the oil leak seem impossible to find or fix. It turned out that the crankcase vent tube had been repositioned so that it pressurized the crankcase in flight. Once moved---no more leak. |
Small streaks? SMALL STREAKS??? Man, you got one of the tight engines.
Most O300s drip more than they burn. The only reason Continental never got into the computer business is that they couldn't figure out how to make the computers leak oil. I had a '64 for the better part of 15 years and never COULD completely tighten that sucker up, even after I did a down-to-the-ground overhaul on it. Jim wrote in message oups.com... I don't know what to do about this . . . hoping the collective wisdom here might have some ideas. For the last 3 months or so, after every flight, there are small streaks of oil on the inside of the lower cowling on my 67 'Hawk |
![]() wrote: I don't know what to do about this . . . hoping the collective wisdom here might have some ideas. For the last 3 months or so, after every flight, there are small streaks of oil on the inside of the lower cowling on my 67 'Hawk . . . if I don't wipe them up, they drip down on the tire of my nose gear. My mechanics have replaced all 6 rocker box covers and gaskets, and re-flared the push rod tubes. I have spent almost $1000.00 so far and it's still leaking. It holds pressure just fine . . . my mechanics are now suggesting replacing all the push rod tubes, but I get the feeling they are just guessing. Any ideas? www.Rosspilot.com After our overhaul and complete cylinder replacement we had a tiny dent in one of the crush gaskets on the screw-on oil filter adapter that produced a small leak. Replaced the gasket and have had a squeaky clean O-300D since. Knock on wood! |
tubes, but I get the feeling they are just guessing. Any ideas? crack in the crankcase, leaking at the through-bolts are options. Kobra |
At my most recent annual a few weeks ago, we tightened up the through bolts.
BIG diff in the quantity of oil drips. Still have 'em, but drastically reduced. "Kobra" wrote in message ... . my mechanics are now suggesting replacing all the push rod tubes, but I get the feeling they are just guessing. Any ideas? crack in the crankcase, leaking at the through-bolts are options. Kobra |
Ignition problem? | nauga | Home Built | 10 | July 1st 04 02:15 AM |
A problem in the Military ? | Nick Jade | Military Aviation | 54 | March 15th 04 07:59 PM |
Fiberglass Cowl Problem | Boelkowj | Home Built | 6 | December 20th 03 02:08 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
