Primary nav source
Old December 1st 05, 04:03 AM posted to rec.aviation.ifr
Default Primary nav source
The recent GPS/IFR discussions here got me to thinking. I generally fly an
Arrow, equipped with a Garmin 430, 2 VORs, Loran, my handheld GPS, my
sectionals, low enroute charts, and since I got my IFR ticket, I try to fly
under ATC control as often as possible to keep my comm skills up.
On cross county flights, I fiddle with the VORs and cross check my location,
I set the Loran (if it's working that day), etc. In other words, for
navigation, I use everything inside and out the cockpit that is operational.
Which one is considered primary?
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old December 1st 05, 04:25 AM posted to rec.aviation.ifr
In article m,
Your brain.
Old December 1st 05, 04:33 AM posted to rec.aviation.ifr
I fly an Arrow that is equipped with a Garmin 430, King KX-155 nav-com, ADF and
a DME that's crapped out at the moment. I use the GPS as my primary nav radio
for enroute segments and the King for approaches. I generally have the GPS
showing the moving map and feeding one of the OBSs as well. If the GPS were to
go tango uniform on me, I'd just use the King to get myself on an established
victor airway and go from there.
Mortimer Schnerd, RN
VE
Old December 1st 05, 03:09 PM posted to rec.aviation.ifr
Seems to me the primary is related to the route you filed. If you're
flying direct, likely the GPS is primary. If you filed airways,
technically the VOR is primary because the airway is defined by
radials. Even though my 2 VOR's usually agree within 1 degree, The GPS
doesn't give me exactly the same course. Even so, I tend to use the
GPS as primary and use the VORs to check cross bearings. Part of the
reason is that I can enter the flight plan into the GPS and let the
STEC do the work while I monitor traffic and communications.
Old December 1st 05, 11:55 PM posted to rec.aviation.ifr
Ham Sandwich
Old December 2nd 05, 12:36 AM posted to rec.aviation.ifr
In article m,
How about this: primary is the one(s) used to meet the requirements
for the particular navigation (a VOR for a VOR approach, the ADF when
flying an NDB approach, IFR GPS when etc etc). Everything else is used for
situational awareness.
Bob Noel
New NHL? what a joke
Old December 2nd 05, 02:36 PM posted to rec.aviation.ifr
On Wed, 30 Nov 2005 23:03:15 -0500, Wizard of Draws
What do *you* mean by "primary"?
I don't see "primary" defined in either 1.1 or the P/CG in the sense of
navigation equipment. However, there is this quote from the AIM which may
be applicable to your situation. Note that the use of GPS as "primary"
(from an FAA point of view) depends on where you are using it:
"...The FAA has granted approval for U.S. civil operators to use properly
certified GPS equipment as a primary means of navigation in oceanic
airspace and certain remote areas. Properly certified GPS equipment may be
used as a supplemental means of IFR navigation for domestic en route,
terminal operations, and certain instrument approach procedures (IAPs). "
Also:
"VFR and hand-held GPS systems are not authorized for IFR navigation,
instrument approaches, or as a primary instrument flight reference. During
IFR operations they may be considered only an aid to situational
awareness."
Old December 3rd 05, 01:59 AM posted to rec.aviation.ifr
On 12/2/05 9:36 AM, in article ,
Also:
awareness."
Enroute, I can't always be sure what would be considered my primary nav
source "from an FAA point of view" since I'm using more than one, that's
why I started this thread.
I can file direct, but that isn't always immediately given me by ATC upon
takeoff. It seems I'm usually given vectors and my "primary" navigation is
the guy looking at me with the radar, I'm just looking at my DG, following
instructions and cross-checking my position with everything I've got on
hand. Once I get to a certain point, then I'm given "direct to XYX" and I
"resume own navigation" from there and the Garmin 430 is most likely my
primary.
Old December 3rd 05, 03:21 AM posted to rec.aviation.ifr
fly
location,
operational.
The one providing course guidance on your HSI. If you're not HSI equipped,
its the CDI somewhere in the cockpit that you use for course guidance. If
you use a bunch of stuff at the same time, then the question doesn't mean
anything.
Old December 3rd 05, 01:07 PM posted to rec.aviation.ifr
On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws
As I wrote, the FAA doesn't define "primary" in the PC/G and it's not
defined in 14 CFR 1.1.
If there is a need for you to have a definitive answer, you could try
writing the FAA Chief Counsel. But there may be no answer forthcoming
unless there is some operational reason to come up with one.
And, in the case of a non-commercial Part 91 small aircraft flight, such as
it seems you are describing, I don't see an operational reason to answer
that question.
A Remote Compass- java source [email protected] General Aviation 0 July 3rd 04 06:39 PM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
Are handheld GPSes becoming a defacto primary nav source? Paul Tomblin Instrument Flight Rules 44 September 13th 03 10:36 PM
OT- north korean nuke weapon plutonium - source? patrick mitchel Military Aviation 11 August 31st 03 04:01 AM
Source for copper crush gaskets??? Jim Owning 0 August 22nd 03 06:31 PM
