Primary nav source
Old December 3rd 05, 06:05 PM posted to rec.aviation.ifr
Default Primary nav source
Ham Sandwich
I can't comment on the legality but I would like to point out from a
historical perspective that the sandwich envisaged in the classic
Travis-Noel 1998 debate (which I believe was its first occurence on
rec.aviation.ifr) was in fact, tuna.
Julian
Old December 3rd 05, 08:12 PM posted to rec.aviation.ifr
If it was Charlie the Tuna, wouldn't it be a ham?
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old December 3rd 05, 08:21 PM posted to rec.aviation.ifr
Ham Sandwich
Julian
We used to use tuna, but then we discovered that the mercury content
interferes with the GPS signal.
Old December 3rd 05, 09:12 PM posted to rec.aviation.ifr
On Sat, 03 Dec 2005 10:20:32 -0500, Wizard of Draws
... I guess I'm expecting logic from a government agency.
Ah -- there's your error sigh!!
"We're from the FAA, and we're not happy until you're not happy!"
Old December 6th 05, 06:41 PM posted to rec.aviation.ifr
Ron Rosenfeld wrote:
On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws
Enroute, I can't always be sure what would be considered my primary nav
source "from an FAA point of view" since I'm using more than one, that's
why I started this thread.
As I wrote, the FAA doesn't define "primary" in the PC/G and it's not
defined in 14 CFR 1.1.
If there is a need for you to have a definitive answer, you could try
writing the FAA Chief Counsel. But there may be no answer forthcoming
unless there is some operational reason to come up with one.
And, in the case of a non-commercial Part 91 small aircraft flight, such as
it seems you are describing, I don't see an operational reason to answer
that question.
The FAA doesn't need a regultion to set forth policy. The FAA policy
remains that VOR is the primary method for domestic en route IFR
navigation. This is related to the ICAO definitions of Class I and
Class II navigation.
Old December 20th 05, 02:35 AM posted to rec.aviation.ifr
Y'all,
Consider the latest out of date sectional
Gene Whitt
Old December 21st 05, 07:11 AM posted to rec.aviation.ifr
On Tue, 20 Dec 2005 02:35:41 GMT, "Gene Whitt"
Y'all,
You have them that new?
www.rogerhalstead.com
Gene Whitt
A Remote Compass- java source [email protected] General Aviation 0 July 3rd 04 06:39 PM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
Are handheld GPSes becoming a defacto primary nav source? Paul Tomblin Instrument Flight Rules 44 September 13th 03 10:36 PM
OT- north korean nuke weapon plutonium - source? patrick mitchel Military Aviation 11 August 31st 03 04:01 AM
Source for copper crush gaskets??? Jim Owning 0 August 22nd 03 06:31 PM
