'Speed Pants'...
Old December 9th 05, 01:57 PM posted to rec.aviation.homebuilt
Default 'Speed Pants'...
....originally for BD-4, but available for all. A little more speed for that RV?
http://www.bedecorp.com/images/price...peed_pants.pdf
Dan DeVillers
http://www.ameritech.net/users/ddevillers/start.html
Old December 9th 05, 03:47 PM posted to rec.aviation.homebuilt
It's likely the 12 mph speed increase is in comparison to an airplane that has no wheel pants at all. You might get 2 mph out of the closing doors.
I was thinking the same thing. Doesn't justify the cost nor the
complexity and upkeep, unless you bought it for the WOW factor.
Old December 9th 05, 10:05 PM posted to rec.aviation.homebuilt
"karel" wrote in message
Sounds reasonable, yes, but they DO look cool!
Wouldn't want the complication of an extra (belden?) cable, though.
If some clever one could find a way to maken them open
automagically, now that would be great!
Curb feelers?
Rich S.
Old December 9th 05, 11:08 PM posted to rec.aviation.homebuilt
KA
I think one of my normal landings would automagically open them without any intervention what so ever. Might not be
able to close 'em again, though.
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old December 9th 05, 11:40 PM posted to rec.aviation.homebuilt
"Flyingmonk" wrote in message
doors.
OTOH, they might be an interesting work-around for LSA... (smirk)
Peter
Old December 9th 05, 11:51 PM posted to rec.aviation.homebuilt
"JJS" jschneider@remove socks cebridge.net wrote in message
You know, that is probably part of the design. If you forget to open them,
they just shatter.
Old December 10th 05, 12:54 AM posted to rec.aviation.homebuilt
"C.D.Damron" wrote in message
news:aMomf.616786$_o.32250@attbi_s71...
them,
they just shatter.
You are probably right. Which might also explain why they are only on the
mains and not on the (fully castering) nosewheel.
Peter
Old December 10th 05, 01:56 AM posted to rec.aviation.homebuilt
"Morgans" wrote in message
How about using ram pressure to keep them closed, via a pneumatic
cylinder,
then when ram pressure is less, like slowing for landings, they open up,
probably spring assisted.
Jim in NC
You could also use something similar to a Piper stall vane, where at some
predetermined AOA, the vane operates a switch that opens the doors.
Alternately, you could plumb a pressure sensitive switch into the
pitot/static line.
You'd need to have the thing rigged to fail in the "open" position, or an
electrical glitch could result in a landing that went crunch, instead of
chirp (or bounce, bounce, thud.)
KB
Old December 10th 05, 02:03 AM posted to rec.aviation.homebuilt
What kind of work around is needed for LSA? The biggest problem for LSA is
going to be going too fast.
Even then, what good would be getting an extra two knots or so?
Anyway, IMHO, I would think the powers that be would consider it a
retractable landing gear if there are doors that close, sealing the wheel.
It would make little difference if the doors are on the fuselage, or on some
fairings.
Jim in NC
Old December 10th 05, 02:06 AM posted to rec.aviation.homebuilt
How about using ram pressure to keep them closed, via a pneumatic cylinder,
Jim in NC
Archer wheel pants on a Cherokee [email protected] Owning 8 November 23rd 05 02:43 AM
Repairing fiberglass wheel pants Jay Honeck Owning 18 September 25th 04 03:55 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Speed Astir Guy Acheson Soaring 0 December 11th 03 02:24 AM
