Turbine Duke or turbine Baron?
Old December 12th 05, 04:10 AM posted to rec.aviation.piloting
Default Turbine Duke or turbine Baron?
For the same money, you could buy a Mitsubishi Solitaire and go faster with
a larger cabin and (probably) more reliable systems
How much faster are we talking here? Never flown in an MU-2, but I've
heard they can be a handful and there are plenty of NTSB reports on
Mitsu accidents. I read recently about the FAA looking into the recent
accidents with these planes. May very well be related to training
issues but the plane seems to have a rep, kinda like the Aerostar did
years back IIRC. I think I'd feel more comfortable with a conventional
aileron/flap than the spoiler. As far as systems reliability, not sure
why you think there'd be an appreciable difference(?)
Wooly
Old December 12th 05, 05:51 AM posted to rec.aviation.piloting
with
Wooly
The Solitair will go 315kts and has a Vmo of 250KTIAS. What is the
accident record on turbine Baron's and Dukes? They are going to have the
same problems as other high-performance-owner-flown aircraft. The problem
is pilots that fly ~100hrs/yr when fatigued and in bad weather and often
don't get enough training. I think the TBM 700 actually has the worst
accident record of any turboprop. How many pilots who just paid over $2
million for their TBM get failed in initial training (zero). They get
signed off and then go crash. If the same pilots could try flying Learjets
single pilot, they would crash even more. Give them F104s and they would
all be dead. I suspect that when the big training centers lose a few more
lawsuits this may change (hopefully).
There is no difference in handling between ailerons and spoilers except that
spoilers are more effective at low speeds. Two pilot crews of Beachjets
aren't crashing or complaining about the spoilers on their airplanes. The
MU-2 does have a bad rep even though its accident record is middle of the
turboprop pack.. The current investigation is political (the FAA
acknowledges this) and includes several CFIT, gear up landings and even a
crash into a ground vehicle on the runway. The whole notion that an 18
month spike in accidents with no common cause could be attributed to the
design of an airplane that has been flying over 35yrs is crazy since the
design of the airplane didn't change! The conclusion will be (again) that
the pilots who do not undergo frequent recurent simulator training have
accident rates 10x the pilots who do. I wish that my government wouldn't
waste my money tilting at windmills. Almost all the accidents whether
Skyhawk, MU-2, Super Cub or anything else are pilot error. The more capable
airplanes get flown into more weather over longer distances and are often
flown for business where there is pressure to get there and back on time.
The high-performance-owner-flown aircraft gets all these increased risks but
no two-pilot professional crew. The lower performance aircraft don't get
flown halfway across the country in large thunderstorm complexes by tired
business people at the end of a long day. My own situation is that every
flight in the MU-2 is over mountains, at night in the PNW where the weather
is often bad. In contrast, I have never flown the Helio at night and only
once in IMC because there are no Helio flight where I *have* to get there.
Generally, you will find that aircraft originally designed for turbines will
have better *everything* from structure to avionics to systems like heated
glass windshields (instead of narrow "hot plates), full dual-bus systems,
remote electric gyros, bearings instead of bushings ect.. It isn't just the
engine that make a TBM cost more than a Malibu, it is a whole host of
improvements.. They can incorporated these things because the airplane has
so much more power that some weight can be traded for better, higher
reliability, systems. When you do a conversion you get a piston airplane
with turbine engines. I am certainly not against conversions, I am
contemplating a turbine in my Helio but the reason I am thinking about it is
that there is no aircraft with comparable performance. If there where, I
would prefer to buy the proven, tested, solution.
BTW The most effective turbine conversions tend to be radial engined
airplanes like Otters, Beavers, the various Grumman flying boats and DC3s.
The greatly improved aerodynamics from getting rid of the draggy radial
overcome the thirsty turbine engines. Of course they don't sound as
good....
Mike
MU-2
Old December 12th 05, 07:06 AM posted to rec.aviation.piloting
"Mike Rapoport" wrote in message
k.net...
Idaho.
Who-dah-ho?
Sorry! g
Jim in NC
Old December 12th 05, 07:10 AM posted to rec.aviation.piloting
So a trucker picks up a couple o' broad driving past in Nevada,
"So... are you girls Navahos?"
"Ah... no, we're Chicago hoes."
Old December 12th 05, 09:39 AM posted to rec.aviation.piloting
There's also a guy in Germany working on a conversion of the Duke to
twin Thielert diesels - the big ones doing 350 HP. He's got one flying.
See
http://info.thielert.com/centurion/m...php?newsid=340
Thomas Borchert (EDDH)
Old December 12th 05, 10:36 AM posted to rec.aviation.piloting
So a trucker picks up a couple o' broads driving past in Nevada,
Old December 12th 05, 02:04 PM posted to rec.aviation.piloting
The Duke does have a dual bus system, a real hot windshield
and plenty of room in the panel. The control systems were
designed for operation at altitude and there is a lot more
cabin room. The Duke's biggest failing is that it is heavy
and the big Lycoming engines are easy to abuse. But doing a
conversion when there are a number of "better" turboprops on
the market seems a waste of money. Seems more sensible to
buy a decent airplane, such as a King Air and refurb it with
interior, avionics and new paint. The Duke is old, will be
as expensive to operate as a King Air and is one of the best
looking Beech aircraft built.
nk.net...
| wrote in message
| with
MU-2, but I've
reports on
into the recent
training
Aerostar did
a conventional
| Wooly
What is the
going to have the
weather and often
has the worst
just paid over $2
(zero). They get
try flying Learjets
and they would
lose a few more
crews of Beachjets
airplanes. The
is middle of the
(the FAA
landings and even a
notion that an 18
attributed to the
crazy since the
be (again) that
training have
government wouldn't
accidents whether
The more capable
and back on time.
increased risks but
aircraft don't get
complexes by tired
where the weather
at night and only
for turbines will
systems like heated
dual-bus systems,
It isn't just the
whole host of
the airplane has
better, higher
piston airplane
conversions, I am
there where, I
radial engined
boats and DC3s.
draggy radial
don't sound as
| good....
| Mike
| MU-2
Old December 12th 05, 03:41 PM posted to rec.aviation.piloting
Everything I have heard about the Duke is consistant with your statements
and certainly a turbine Duke is better than a piston Duke. Piston twins
have some of the high reliability systems of the turboprops, but the factory
turboprops have *all* of them. I would even go so far as to say that the
factory turboprops that started as pistons (King Air 90, Conquest, Cheyenne
and Meridian) are inferior in a number of ways to the airplanes that were
designed for turbine power from the beginning. Ultimately airplanes are
flying sets of compromises between cost, weight, robustness and utility and
designers choose different compromises when the airplanes are powered by
turbines instead of pistons.
Mike
MU-2
"Jim Macklin" wrote in message
newszfnf.28446$QW2.15610@dukeread08...
nk.net...
| wrote in message
| with
MU-2, but I've
reports on
into the recent
training
Aerostar did
a conventional
| Wooly
What is the
going to have the
weather and often
has the worst
just paid over $2
(zero). They get
try flying Learjets
and they would
lose a few more
crews of Beachjets
airplanes. The
is middle of the
(the FAA
landings and even a
notion that an 18
attributed to the
crazy since the
be (again) that
training have
government wouldn't
accidents whether
The more capable
and back on time.
increased risks but
aircraft don't get
complexes by tired
where the weather
at night and only
for turbines will
systems like heated
dual-bus systems,
It isn't just the
whole host of
the airplane has
better, higher
piston airplane
conversions, I am
there where, I
radial engined
boats and DC3s.
draggy radial
don't sound as
| good....
| Mike
| MU-2
Old December 12th 05, 04:02 PM posted to rec.aviation.piloting
flying.
I read the article - wow that's a huuuuge bump in range over the
gassers eh? Didn't know Lyc wasn't supporting the TIO-541 anymore (I
think the P-Navajo has the same engine?) but doesn't surprise me as
I've heard they're quite finicky and must be babied more than most high
HP turbo'd piston engines.
Old December 12th 05, 04:17 PM posted to rec.aviation.piloting
What is the accident record on turbine Baron's and Dukes?
The obvious answer is there is no record as the first one is still
finishing the STC process.
Your point about training was well made, I kinda figured that factored
into many if not most accidents in owner-flown turbine aircraft. I
didn't realize the TBM was so high up on the list though - it's
reminiscent of a local guy I know of who recently traded back down to a
Bonanza after crunching his Malibu Jetprop twice as the result of two
completely boneheaded manuevers.
The greatly improved aerodynamics from getting rid of the draggy radial overcome the thirsty turbine engines. Of course they don't sound as good...
There's a lot to be said for round engines that leak oil and smoke on
startup - Character, I think it's called G
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit TurbineMini Richard Rotorcraft 2 January 24th 04 01:15 AM
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit TurbineMini Richard Rotorcraft 0 January 15th 04 11:48 PM
TRUTH OF THE MINI-500 TURBINE CONVERSION Dennis Chitwood Rotorcraft 10 January 7th 04 05:33 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
