![]() "Maule Driver" wrote in message news ![]() I've put over 1,000 of the 1,100 hours on this new O-360-C4f. Changed the oil religiously. I didn't baby the engine but didn't abuse it either. Always hangered etc. My last oil analysis showed a doubling of iron 47.9ppm to 101.0ppm with 36 hours on the oil. Everything else normal. We did the filter and we found very fine iron filings or dust with a magnet. How much - hard to tell. No chunks though. We're thinking cam and lifter. My mechanic is playing it safe - called Signature and Mattituch who recommended no more flying, split the case, and fix or overhaul. I want some second opinions. I could fly 10 more hours and take another look. We could pull a cylinder and check the cam I'm told. I've read about Second OilPINION and Howard Felton - a knowledgeable analysis of the metal seems like money well spent. Is he still in business? Anyone know anyone else who can do this? Any other factors? My exhaust manifold/heat exchanger broke and I flew for 10 to 36 hours with it broken. Parts 'banging' around under the cowling etc. Discovered it during oil change. I did let it sit without running for 60+ days - a first for this aircraft. Thoughts? Maulesitter. Since you let the aircraft sit for 60 days, is it possible (likely?) that the metal you are seeing is simply the layer of rust that formed on your cylinder bores? KB |
It does have mushroom lifters - my mechanic seemed to be very aware of
that fact but I didn't understand the ramifications. wrote: On Fri, 16 Dec 2005 23:24:45 GMT, Michelle P wrote: Maulesitter, You do not need to pull a cylider to look at the cam. Just pull the rocker arms, push rods, tubes and lifters. You can peer in the hole with a flash light and mirrow. Michelle Unless it's one of the few Lycomings running around with automotive-style barrel lifter bodies, the engine has mushroom lifter bodies. The portion that rides on the cam lobe has a larger o.d. than the rest of the body (and the corresponding hole in the crankcase). TC |
Denny wrote:
Another airplane on our field with 360 just lost the cam and lifter last month and it caused big time damage while they piddled around with, "well, lets fly it a while and look at the filter again."... The lifter spalled off chunks shortly after that decision and the pistons picked the debries up on the skirts and scored the cylinders... His 'repair' on a 700 hour engine is now $10K.... Pull a cylinder and borescope the cam... Not a lot of bucks or downtime to do this and you can make an informed decision, not a guess... That seems to be the most rational move to make at this point. |
Kyle Boatright wrote:
Since you let the aircraft sit for 60 days, is it possible (likely?) that the metal you are seeing is simply the layer of rust that formed on your cylinder bores? Possible? I certainly hope so. Likely? I don't know. Does anyone doing regular oil analysis see this when their a/c sits idle for 60 days? I realize that if I have a jug pulled and find nothing then I really have a problem. What is it? Rust in the cylinder bores would be a Christmas present. |
![]() Quote:
frank |
Ouch,
Sorry. Guess pulling a cylinder is in order. Michelle Maule Driver wrote: It does have mushroom lifters - my mechanic seemed to be very aware of that fact but I didn't understand the ramifications. wrote: On Fri, 16 Dec 2005 23:24:45 GMT, Michelle P wrote: Maulesitter, You do not need to pull a cylider to look at the cam. Just pull the rocker arms, push rods, tubes and lifters. You can peer in the hole with a flash light and mirrow. Michelle Unless it's one of the few Lycomings running around with automotive-style barrel lifter bodies, the engine has mushroom lifter bodies. The portion that rides on the cam lobe has a larger o.d. than the rest of the body (and the corresponding hole in the crankcase). TC |
![]() "Maule Driver" wrote in message ... Kyle Boatright wrote: Since you let the aircraft sit for 60 days, is it possible (likely?) that the metal you are seeing is simply the layer of rust that formed on your cylinder bores? Possible? I certainly hope so. Likely? I don't know. Does anyone doing regular oil analysis see this when their a/c sits idle for 60 days? I realize that if I have a jug pulled and find nothing then I really have a problem. What is it? Rust in the cylinder bores would be a Christmas present. 210% increase in iron after sitting for 60 days? That doesn't sound very likely to me, but then again I am not Howard Fenton. How many hours did you fly after it sat for that long before you changed the oil and did the analysis? Did you change the oil again after that? Try putting some rare earth magnets on the filter housing, that will help collect any more of the iron as well, give you another point of reference... |
As others have stated, you are free to pursue whatever path you like. On
one extreme, tear the engine apart and overhaul before further flight. On the other side, fly for a few more hours, take another sample to the lab, and cut open the filter to see if you have any more "goodies" lurking. One course is known to be expensive up front. The other may be just as expensive in the long run. If something major breaks in the air, the outcome may be more expensive. No way to know until it happens. It sat for 60 days prior to the bad oil analysis? Some say that could do it while another camp says that ain't it. Really? Show me the testing data either way. What we get out of the engine manufacturers and oil companies suggest that anything other than almost daily flight of 1 hour risks corrosion buildup at some rate. Seems to suggest that, under the right conditions, you could be seeing 2 months of inactivity that ended up in the oil sump. Then again, they sell oil and engines (and have nervous lawyers and insurance companies). I don't expect them to say "leave the engine idle for long periods and it will probably be O.K.". I have seen a Lycoming 360 locally that ground a cam lobe to 1/2 its original height. It ran fine and idled O.K. It made what felt to the owner as full power. No way to know how long it was in that condition. Some suggest that once the hardened layer is ground off a surface, it will "go quickly". Have any of the engine manufacturers or oil companies done any testing in this area to see how quickly this may happen? There are those who say that flying further risks "more" damage. Well, if you split the case at 1100 hours, you may want to strongly consider a major anyway. So, other than an off-airport excursion, I'm not sure what would be different in several hours as far as the overhaul. Maybe some crank scuffing? As you said, if you pull a jug and see nothing, then what? The only way to "know" you are O.K. in that case is a major. The thing that irks me when I get in this situation (like a cylinder that might be going South) is that I cannot FLY the thing anywhere with confidence except a local hop. Until the problem is resolved, the plane is "down" as far as I'm concerned. No freedom to take a 400 mile jaunt whenever I want is as good as no plane at all. Worse, in fact. I have a potential financial liability simmering on the ramp that I cannot use. Good Luck, Mike |
might be going South) is that I cannot FLY the thing anywhere with confidence except a local hop. Until the problem is resolved, the plane is "down" as far as I'm concerned. No freedom to take a 400 mile jaunt whenever I want is as good as no plane at all. Worse, in fact. I have a potential financial liability simmering on the ramp that I cannot use. Well put, Mike. This is an aspect of ownership that is not often discussed. Nagging little problems that, as a renter, don't even enter you mind, become HUGE deals as an owner. Right now I'm still chasing the "mystery oil leak" that leaves a little puddle under my plane over time. Although it's not stopped me from flying (the weather, on the other hand, *has*), it grates on me every time I open the hangar door. It just isn't *right* -- even though everyone (including my A&P) has told me that air-cooled engines just do this from time to time, and you can spend $10K chasing it down, or you can live with it. In the past, I've had alternator problems (will everything in the panel suddenly die?), nose-wheel shimmy problems (will it get worse?), crunched aileron sheet-metal (will it suddenly flutter without warning?), and a plethora of smaller nits that drove me (more) nuts. The only solution is to keep on top of them as they occur and fix them, one by one. Maule Driver's case is, of course, far more critical. It'll be interesting to hear what the inspections turn up. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay,
I had an mystery oil leak as well. It took me several weeks and wash downs to find it. When the engine was "cold" it did not leak. When it heated up it did. Mine turned out to be a crack in the oil filter adapter housing. (you and I have the same basic case design) Specificly the vernatherm housing. When cold and retracted the crack was closed. When hot, the vernatherm extended pushed the crack open. I followed the oil up as far as I could. The problem was the oil was coming out under pressure and going everywhere! I found it be looking with a mirror. What I saw was missing paint in a area that did not have anything rubbing on it. I was about to fully clean the engine have some one run the engine while I looked for spraying oil. I replaced it with a remote filter housing.... Michelle Jay Honeck wrote: The thing that irks me when I get in this situation (like a cylinder that might be going South) is that I cannot FLY the thing anywhere with confidence except a local hop. Until the problem is resolved, the plane is "down" as far as I'm concerned. No freedom to take a 400 mile jaunt whenever I want is as good as no plane at all. Worse, in fact. I have a potential financial liability simmering on the ramp that I cannot use. Well put, Mike. This is an aspect of ownership that is not often discussed. Nagging little problems that, as a renter, don't even enter you mind, become HUGE deals as an owner. Right now I'm still chasing the "mystery oil leak" that leaves a little puddle under my plane over time. Although it's not stopped me from flying (the weather, on the other hand, *has*), it grates on me every time I open the hangar door. It just isn't *right* -- even though everyone (including my A&P) has told me that air-cooled engines just do this from time to time, and you can spend $10K chasing it down, or you can live with it. In the past, I've had alternator problems (will everything in the panel suddenly die?), nose-wheel shimmy problems (will it get worse?), crunched aileron sheet-metal (will it suddenly flutter without warning?), and a plethora of smaller nits that drove me (more) nuts. The only solution is to keep on top of them as they occur and fix them, one by one. Maule Driver's case is, of course, far more critical. It'll be interesting to hear what the inspections turn up. |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
First 2 1/2 hours PPL(H) today! | Simon Robbins | Rotorcraft | 42 | September 25th 05 12:54 AM |
KA6E and Foka 4 comparable metal ships - Laister Nugget LP15 | Matthieu | Soaring | 18 | June 7th 05 01:20 AM |
Metal fatigue in Lycoming engines limiting its TBO? | Wolfgang | Home Built | 11 | November 7th 04 01:46 PM |
