Some bad controllers
Old March 8th 04, 06:46 PM
Jeff
but its high clouds for the most part, you dont get the clouds covering the mountains like you had
this last week or so.
Doug Rinks wrote:
Not exactly.. Phoenix gets monsoons nearly every night during the
summer. That surely counts as IMC.
Doug
Jeff wrote in message ...
ya he was so busy he almost let someone fly into me.
no matter how you dice it, that should not have happened. Phoenix does not get much IMC, its
sunny about 350 days a year there.
  #42
Old March 8th 04, 06:50 PM
Mike Rapoport
Did you write the following?
"I chose VFR the first part of the flight so I could have the latitude to
dodge clouds to prevent icing."
"so here I am now down from my safe altitude above the clouds"
"then here I am in these nasty clouds, outside temp about -2"
"then he does not want me to do the ILS, he tells me to decend to 2700 ft
and to be prepared for the visual. man what a crappy flight"
Mike
MU-2
"Jeff" wrote in message
when did I complain about flying in the clouds?
who complained about not getting the ILS in VMC
who said I was not comfortable with flying in the clouds?
I think you misread some things.
Mike Rapoport wrote:
Maybe prepared is not the right word but you make a point of saying that
you:flew most of the trip VFR to aviod ice and yet you filed IFR into
class
B airspace and complained about flying in clouds. You accepted the
descent
to 7000 (amongst the clouds) while VFR. So basically you seem to be
complaining about not getting your clearance right away, having to fly
IFR
in clouds and not getting the ILS in VMC. You also complain that he
made
you descend for traffic, separating traffic is the controllers primary
job.
If you are not comfortable flying in icing clouds then don't file IFR in
class B airspace when the temp is below freezing. Most of your issues
where
of your own making and you should accept responsibilty for them instead
of
blaming someone else. It is odd that the controller said that he was
busy
on a quiet freq.
Mike
MU-2
and how was I not prepared ?
If you are not prepared to fly in "nasty clouds" then you have no
business
filing, requesting or flying IFR.
Mike
MU-2
Just a quick note to any of you guys flying IFR into the phoenix
area.
I just got back from a trip to phoenix from vegas, I had filed a
composit flgiht plan, VFR untill I was by phoenix then I would
request
my IFR if it was needed since FSS reported overcast at 2700 and
few at
600.
freezing level was 7000-8000, MEA was 9000 in some parts and
10,000
during other parts of route. I chose VFR the first part of the
flight
so
I could have the latitude to dodge clouds to prevent icing.
all went fine, I got handed off to phoenix approach, I was at
12,000
ft
on top of the layer, no way into phoenix except through that mess
either. So I asked phoenix for my IFR and he said I was cleared
into
class B and to decend to 7000 and he would look for my clearence.
I
start my decent, between some clouds and he comes back and says to
turn
toward carefree if I want to pick up my IFR because he was to
busy.
no
one was talking except me.
then he told me to stay clear of class B. so here I am now down
from
my
safe altitude above the clouds, a nitwit controller, I zig zag
between
some clouds and call him again, he says he cant see me on radar
and to
turn towards carefree, so I figured I would follow the valley
under
some
clouds, then my wife says dont turn that way, that mountain is
covered
by clouds, so I get back on the radio and tell the controller he
got
me
down here, I amnow stuck and I needed my clearence or I would be
in
trouble. He finally said, ok, and gave it to me. man that guy
****ed
me
off. there was another guy trying to do the same thing as me in a
cessna, right after I got my clearence, and the controller told
him to
stay at 2500 ft and turn towards carefree because he was
"saturated"
with IFR departures. Yet no one else was talking. then here I am
in
these nasty clouds, outside temp about -2, he gives me to decend
to
6000, then right after that screams at me traffic alert decend to
5000
...so I am in total IMC diving down to 5000 ft.. then he does not
want
me to do the ILS, he tells me to decend to 2700 ft and to be
prepared
for the visual. man what a crappy flight - and I didnt even tell
you
about the 1500 fpm downdraft or when my engine started losing
power.
that controller still has me ****ed off and its 2 days later.
  #43
Old March 8th 04, 06:56 PM
Jeff
I had no problems when he gave me my clearance, was it nasty, yes it was, but it
was not uncomfortable nor did I ever feel like I was in danger, the problems I had
that were weather related only lasted long enough for me to take corrective
action.
We dont see much weather like that and when we do not many people fly in it
because of the chance of icing. Did I have a good plan yes I did, did I have
options, yes I did, could I have gotten out and went to one of my 2 alternates,
yes I could have. Did I want to ..no, my car reservation was at the airport I
intended to land at and all I needed was my clearance so I could go through the
clouds and get to my destination.
Could the controller have been a little bit better, knowing the weather was what
it was and since I had a flight plan on file and gave me the clearance..yes he
could have.
If you are not prepared to fly in "nasty clouds" then you have no business
Mike
MU-2
I think Mike meant you should never be cutting it so close that some
sort of an ATC screwup makes it uncomfortable, or even dangerous. I am
not saying that's what you did (flying a single in the Pacific NW, I
know the on-top/slamdunk game well), but he does have a valid point,
even if it sounds smug from the flightdeck of a deiced turboprop ;-)
I would only add that in my (admitedly limited) experience, it helps
to be forthright with ATC about why you want something, if milling
around in icy tops is a concern, let them know.
Martin
  #44
Old March 8th 04, 07:02 PM
Jeff
I was not dependent on them granting my every wish nor was I dependent on
anything except being able to land.
I guess my problem was decending in the first place when he said he was
looking for my clearance and told to do so assuming he would pull it up.
He damn sure pulled it up quick when I made my last call to him, he didnt even
need to ask my tail number again or any other information, so it appears to me
had had access to it the entire time and just did not want to mess with it.
To expand on Martin's correct interpretation of what I meant (but perhaps
didn't express well), you shouldn't be dependent on ATC being able to
accommodate your every wish, particularly in class B airspace. If you
really can't fly in clouds because of icing, then remain VFR. It isn't a
"screwup" on ATC's part that they can't let a pilot fly any heading and
altitude that he wishes, it is the pilots"screwup" that he is dependent on
them doing so.
Mike
MU-2
"Martin Kosina" wrote in message
om...
business
Mike
MU-2
Martin
  #45
Old March 8th 04, 07:04 PM
Jeff
and how do you know it was busy ?
were you sitting next to the controller - or is this just another assumption
on your part?
Fine, but while flying above the nasty icing clouds, don't ask for IFR to
descend to your destination in busy class B airspace!
Mike
MU-2
"Matthew S. Whiting" wrote in message
business
Depends on your definition of nasty. I consider t-storm, funnel clouds,
and clouds with temps below freezing to be nasty and I won't fly into
them, at least not intentionally. I hardly think that means I have no
business flying IFR.
Not sure what the OPs definition of nasty is, but that is mine.
Matt
  #47
Old March 8th 04, 07:23 PM
Mike Rapoport
Yeah, I was sitting right next to him when you called. Visiting the ATC
center ya know? Saw the whole thing. He wanted to finish the game of
solitaire that he was playing on the radar scope and didn't want to be
bothered issuing a clearance, so he made up the whole part about being busy.
There really were't any airliners departing PHX that night, no military or
other GA traffic either.
Mike
MU-2
assumption
on your part?
to
Mike
MU-2
business
clouds,
Matt
  #49
Old March 8th 04, 08:36 PM
Snowbird
"Steven P. McNicoll" wrote in message link.net...
"Snowbird" wrote in message
om...
Jeff, with regard to "no one was talking except me". Be aware
that a controller can be handling 2 or even 3 frequencies, and
also depending upon how his airspace is set up he may need to be
doing a lot of coordination by phone.
So he might not be talking to anyone else on your freq, but he
still could be busier than a 1 armed paper hanger.
If he's got aircraft on other frequencies you'll hear his transmissions to
those other aircraft on your frequency, you just won't hear the other
aircraft.
Is that always true? I know I hear this pattern sometimes, but I thought
it wasn't necessarily true.
In any event, if he's spending time on the 'phone coordinating, we
won't hear that.
Cheers,
Sydney
  #50
Old March 8th 04, 08:43 PM
Ditch
Not i my experience. I have actually heard the controller's transmission stop
midway thru as he was talking to an airplane on another freq....switched to the
freq he was talking to the other airplane on and hear him finish his
transmission.
Most of the time they will broadcast on all the freqs they are working, but not
always.
-John
*You are nothing until you have flown a Douglas, Lockheed, Grumman or North
American*
"cleared to ... when direct ..." John Harper Instrument Flight Rules 21 February 11th 04 04:00 PM
Practical IFR Question (for centre controllers) David Megginson Instrument Flight Rules 10 December 4th 03 11:26 PM
AOPA and ATC Privatization Chip Jones Instrument Flight Rules 139 November 12th 03 08:26 PM
Follow up Alright, All You Dashing, Swaggering Bush Pilots wmbjk Home Built 135 September 8th 03 06:09 AM
Riddle me this, pilots Chip Jones Instrument Flight Rules 137 August 30th 03 04:02 AM
