Curious incident :)
Old December 20th 05, 03:59 PM posted to rec.aviation.piloting
Default Curious incident :)
Saw an amusing incident today at the Dubai Airport; hadn't ever seen
such a thing earlier.
A Dragonair 747 taxied on to the east-west aligned runway at the
western end. Although the runway threshold is just east of that point,
the aircraft turned west and did a 180 at the adjoining circular tarmac
pad. Just as it centered on the runway, a FedEx MD-11 landed from above
in front of it. I noticed that the MD-11 had barely begun its turn on
the exit at the far end when smoke came off the 747 tires. The takeoff
roll had begun.
Though the runway sequence was very time-efficient, it left me feeling
that it'd have been fun had the MD-11 come slightly low in the
glideslope or encountered mild windshear )
How often does such a sequence happen where you live?
Ramapriya
Old December 20th 05, 04:18 PM posted to rec.aviation.piloting
roll had begun.
Since when does smoke come of the tires of a plane starting its takeoff
roll? I can't think of any way that could happen.
Paul Tomblin http://xcski.com/blogs/pt/
I think I have a new personal rule: Never watch anything which includes
the author's name in the title, particularly if the author is dead.
-- Andrew Dalgleish
Old December 20th 05, 04:31 PM posted to rec.aviation.piloting
In article . com,
roll had begun.
Ramapriya
Aircraft should NEVER be cleared to "position and hold" with landing
traffic on final, unless they can take off and clear the runway before
the landing traffic arrives.
It sounds like either a controller error or a Dragonair pilot error.
Remve "_" from email to reply to me personally.
Old December 20th 05, 04:56 PM posted to rec.aviation.piloting
roll had begun.
If I understood the OP correctly, the 747 was starting its takeoff roll
as an MD11 landed in front of him. The 747 probably hit the brakes
really hard.
To answer the original question (have I seen this before?): no, never. I
was once cleared into position and hold, but spotted traffic on short
final, so I held short, and told the controller about it. He apologized,
moments later a different controller replaced him.
This has happened in the USA though. You may all remember the 737 that
landed on top of a Brasilia (or some turboprop) at LAX in the late 80's.
-jav
Old December 20th 05, 05:15 PM posted to rec.aviation.piloting
Don't know about you but I've seen puffs come off aircraft tires, at
the start of the takeoff roll, often enough; it probably happens when
pilots advance the throttle a bit before releasing the brakes.
Ramapriya
Old December 20th 05, 05:22 PM posted to rec.aviation.piloting
really hard.
No, quite certain that that didn't happen. From what I saw, the 747
stood there waiting for the MD-11 to land and exit before taking off.
He probably chose to enter the runway because that portion was beyond
the threshold.
Not sure if I've conveyanced in words correctly here :\
Ah, but there's likely a difference here, as I've said above. The
aircraft in this instance was holding *beyond* the threshold.
Ramapriya
Old December 20th 05, 07:03 PM posted to rec.aviation.piloting
"Ramapriya" wrote in message
My thoughts exactly.
I've never seen that, nor even heard of it. The proposed explanation you
suggest certainly wouldn't do it. Smoke comes off the tires during
touchdown because of the speed difference between the tire and the pavement,
until the tire "catches up".
During takeoff, even if the brakes are held, and even if the tires slide a
bit (which is very unlikely...usually the locked wheels can hold the
airplane still), they wouldn't smoke. They'd just rub a bunch of rubber
onto the pavement.
If you saw smoke during the takeoff roll, it came from somewhere other than
the tires.
Pete
Old December 20th 05, 09:06 PM posted to rec.aviation.piloting
Just a stab here, but the smoke coulda been from a locked up brake
assembly. It does sound like the 747 was cleared to position and hold
in front of a landing aircraft. Unless something was lost in
translation?
Old December 20th 05, 09:09 PM posted to rec.aviation.piloting
Maybe the 747's takeoff clearance was cancelled as the controller has
to maintain runway separation and the MD was still on the runway?
Old December 20th 05, 11:30 PM posted to rec.aviation.piloting
the threshold.
I also can not imagine what could cause what you said. You said smoke left
the tires of the 747? What would cause tires of a stopped aircraft (just
beginning to roll) to smoke?
Jim in NC
The Swearingen-TEB incident: control issues with twins R.L. Piloting 72 June 8th 05 04:08 AM
British Airways 747 incident on NPR Ron Garret Piloting 3 March 9th 05 07:38 PM
Quick question about an incident which happend today Chris Piloting 46 April 1st 04 04:15 PM
Bush/Hitler creates another phony "terrorist" incident to suppressus... Ronald Gardner Home Built 4 December 29th 03 09:19 PM
Indonesian Bawean Island Incident (2 F-16B vs 5 F/A-18s) Bram U. Kusuma Naval Aviation 6 September 7th 03 06:06 PM
