Shock Mounting Gyros
Old December 26th 05, 04:30 PM posted to rec.aviation.homebuilt
Default Shock Mounting Gyros
I am starting the planning of my panel and wondering how many people have
shock-mounted their gyros. Please also comment if you have NOT done so, and
weather or not you think it actually helped. I am working with limited
panel space (aren't we all) and the shock mounts will take up valuable real
estate. I am considering using the smaller lord mounts but would also like
to hear of other solutions people have found to accomplish the mission using
minimal extra panel space.
Thanks
Old December 28th 05, 10:42 PM posted to rec.aviation.homebuilt
Thanks
How about shock mounting the entire instrument panel?
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old December 30th 05, 03:16 AM posted to rec.aviation.homebuilt
I considered this, however as doing the whole panel is a heavier item to
isolate, you end up using more/larger mounts and it becomes something of a
wash
D
"JKimmel" wrote in message
et...
have
and
real
like
using
Thanks
J Kimmel
Old December 30th 05, 03:39 AM posted to rec.aviation.homebuilt
"Doug Palmer" wrote in message
ink.net...
wash
Yes, but......
As the whole panel is heavier, if it is isolated as a whole, the weight is
more, it will be less likely to vibrate, since the resonate frequency will
be lower.
Pros and cons both ways. Another pro is, if the whole panel is isolated,
all of the other instruments will possibly last longer, too.
Jim in NC
Old December 30th 05, 06:21 AM posted to rec.aviation.homebuilt
Consider a subpanel of the gyro instruments.
Modern gyros are much lighter than the one of the WWII generation!
Cessna use a 3/8" dia with 10-32 double stud. Granger carries a double
stud of 10-32 1/2 diameter
which is rated for about 17 pound in shear.
Numbers off the top of my head, need to actually look in the catalog.
Any type of vibration isolation will benenfit.
Kent Felkins
Tulsa
et...
have
and
real
like
using
Thanks
J Kimmel
Old December 30th 05, 09:24 AM posted to rec.aviation.homebuilt
On Mon, 26 Dec 2005 16:30:07 GMT, "Doug Palmer"
Just bolt 'em in.
Old panels used to be isolated, then the gyros. I don't think the
modern panels do at all. Besides a few unusual attitudes without
caging is probably harder on them than the vibration.
www.rogerhalstead.com
Thanks
Old December 30th 05, 09:50 AM posted to rec.aviation.homebuilt
On Fri, 30 Dec 2005 04:24:35 -0500, Roger
Just bolt 'em in.
Thanks
my panel has no vibration mounts.
instruments are still all serviceable after 20 years and 550hours.
the key to success is to make sure the prop and spinner are balanced
and to rebalance them if any vibration seems to be starting.
oh, that and keeping the exhaust pipes off the frames.
Stealth Pilot
Old December 30th 05, 06:22 PM posted to rec.aviation.homebuilt
Hi, I don't understand, are you building a Classic type of plane? If not,
why use 1930 and 1940 technology? I'm not to the point of building my panel
yet, but I'm going glass.
If you are rebuilding a panel, it's not cost effective, but if your going
from scatch.... I priced the GRT's EFIS & full engine monitor for the same
price as a vacumm system. You get a lot more than a Six pack system for the
same price. If you haven't purchased parts of your system, you may want to
check the features.
david
k.net...
and
real
like
using
Thanks
Old January 1st 06, 01:08 AM posted to rec.aviation.homebuilt
On Fri, 30 Dec 2005 12:22:14 -0600, "David Koehler"
For a *basic* VFR panel you can't beat a few mechanical gages for cost
and return.
OTOH my G-III if I ever get it done will be full, dual, redundant
glass with the required mechanical backups.
Engine monitor?
Even in the Deb I only have one CHT and one EGT probe.
Again on the G-III everything will be monitored complete with trends.
check the features.
david
nk.net...
and
real
like
using
Thanks
Old January 4th 06, 08:38 PM posted to rec.aviation.homebuilt
I used 4 AN-1000-8's (IIRC) on the red parasol.
It worked well, for a small panel (under 10 pounds).
I also found a steel cup washer that fit the AN-1000's and used
a couple of them to "tune" the panel response rate a little higher.
For the Tailwind I woas gonna do the panel in sections using the
same tricks....
Richard
ink.net...
wash
Yes, but......
be lower.
Jim in NC
Gyro Mounting flyhighdave(at)aol(dot)com Home Built 4 September 7th 05 08:40 PM
C150 Wheel Fairing mounting plates Robert Zrim Owning 17 June 16th 05 07:37 AM
Shock Chord Rings smjmitchell Home Built 1 September 9th 04 07:41 AM
Avoiding Shock Cooling in Quick Descent O. Sami Saydjari Owning 32 January 21st 04 04:32 AM
Citabria with gyros Bob Esser Piloting 6 July 9th 03 12:03 AM
