Derek Copeland wrote:
For all landings, my pre-landing check is: W- Water jettisoned. U - Undercarriage down and locked. L - Loose objects stowed away and, considering myself as a potential loose object, straps tight. F - Flaps set as appropriate. I don't include "Straps" or "Loose Objects" in my check list because loose anything in the cockpit can become problematic at any point in a flight. Is this a regional item? Shawn |
At 22:36 26 December 2005, Shawn wrote:
Derek Copeland wrote: For all landings, my pre-landing check is: W- Water jettisoned. U - Undercarriage down and locked. L - Loose objects stowed away and, considering myself as a potential loose object, straps tight. F - Flaps set as appropriate. I don't include 'Straps' or 'Loose Objects' in my check list because loose anything in the cockpit can become problematic at any point in a flight. Is this a regional item? The basic pre-landing checklist I use is the one recommended by the BGA in the UK. Loose items and loose straps are more likely to become an issue when flying in the turbulent air close to the ground, and during the ground run in a bumpy field. Derek Copeland |
For an out landing I use: Wild Woman Seek Sex, WWSS Wind,
Wires,Slope,Speed. Tom Hubbard |
![]() Nyal Williams wrote: I wonder how many different landing checklists are in use. If the list you use is not USTALL, (Undercarriage, Speed, Trim, Airbrakes, Look out for Traffic, Land), please post here and label the items. BFUBBS WATT Ballast - dumped Flaps - Landing configuration Undercarriage - down and locked Brakes - Deploy spoilers and check operation Brakes - Verify brake control either on spoiler or stick (esp. if flying various ships) Straps - Tight Wind - Direction, speed, gusts Airspeed - Appropriate for Terrain and Wind Traffic - Look and Listen Transmit - Announce IP and other locations as appropriate |
A checklist should only be used for actions that are not routinely done
during flight, and are essential to the procedure (landing, in this case). So really, the only thing needed for most glider landings, is making sure the gear is down (if it's retractable in the first place). Everything else listed in the common Before Landing "checklists" are just reminders. Note that the same logic applies to before takoff checklists - they should only cover items that are critical to the maneuver about to be accomplished - takeoff and flight in this case. Some of the actions listed are a joke. Airspeed? Especially in gliders, we are always adjusting our airspeed to the phase of flight we are in - cruising, thermalling, pattern, landing. No checklist needed. Trim? Ditto - and pretty obvious if not done. Flaps? Sure, when appropriate - but depends on winds, etc.. and you've been playing with them since takeoff anyway, haven't you? Traffic? YGTBSM! When in flight can you not be looking for traffic! So - reminders are fine - but don't get hung up in the pattern trying to remember what the second L in WUFSTALLLLSWAFTWTFO means. By all means prepare yourself for landing by getting ready and analyzing the environment; but fundamentally landing is no different from entering or leaving a thermal! Do you have a pre-thermalling and a post-thermalling checklist? The classic old power plane/military GUMP (Gas Undercarriage Mixture Propeller) check was created to ensure that the critical, life-or-death (or at least -damage) items were checked in the pattern prior to landing. Since we glider pilots don't usually have any G, or an M or P to worry about, only the U would seem to be useful for that small percentage of the gliding community fortunate enough to be able to land gear up. And when we are blessed to be tooling around the pattern in a 2-33 or a K-13 or whatever - tell the front seat stick actuator to quit yakking about "wufstall" or "swafts" (whatever they are) and just land the darn thing! As slow as possible! Preferably on the runway! Kirk 66 Oh, and a nice loud "Shut up and look out the window!" is almost always called for...especially when there are nice shiny gadgets on the panel to look at... |
I'm told George Lee used
W-ind W-ater W-heels |
M B wrote: I despise long checklists. The chance of landing with the gear UP is directly proportional to the length of the checklist followed. The more checklist items you follow, the less time spent doing something important. Here in New Zealand the standard pre-landing checklist is Straps, Undercarriage, Flaps, Brakes, which is pretty short. You could argue that Straps is unnecessary, but I think it proabbly is a good reminder that in some of the conditions we fly in it can get a lot bumpier as you drop below 1000 ft or so. But the big reason to tighten straps is in case of a sudden stop, right? I've never quite known what to do for flaps at that point. No problem if you don't have them of course, but in the one flapped ship I fly, landing flap is about half as effective as the airbrakes (i.e. about 1/3 of the total drag available) and I do not generally want to have that deployed all the way along downwind unless I'm worried about possible 1000+ fpm sink in the circuit and starting high and doing a Stuka circuit. So I just make a plan (and announce if it there's someone in the back seat) which is generally along the lines of "I'll fly clean (or in +6) until on base (or turning final), when I'll put in landing flap. Brakes: just open and close them to make sure they deploy and are symmetrical. If they're not going to deploy (whether for mechanical fault or due to icing) then best to find out before you're on finals. Conversely, if they're not going to close properly after you test them then best to be somewhere where you can get to the airfield with full brake. Which argues for this being a downwind check rather than something you might do too much earlier. A very real exception, however, is the airspeed. Might be a useful item for those who fly a lot of different aircraft, or at different weights. But even then it ***might*** be ignored if the runway is long enough ![]() I can understand how pilots of powered aircraft might have trouble with speed, since they generally have to slow down to speeds they'd never otherwise use. But it seems to me that most gliders should be approached at a little bit over min sink in calm conditions, to a little bit over best L/D when it's blowing and those are speeds and attitudes and stick positions that you're going to know very well. Takeoff checklist seems to be another matter entirely. I look carefully through the fatal accident reports and prioritize my checklist by what killed the most pilots in type. Do THAT stuff at the beginnning AND the end of the checklist... Right. There can be a lot of thngs that might prevent a sucessful transition from not-flying to flying. Switching from flying to not-flying is pretty fail-safe as long as you don't do it by hitting something or stopping flying while too high off the ground. -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- |
At 10:06 27 December 2005, Keith Morgan wrote:
I'm told George Lee used W-ind W-ater W-heels I kind of like the WWW. Leave off the first two Ws and add F. (flare) at the end. Ofcourse I'm the guy that landed with his spoilers taped shut. Chuck |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
question about instrument proficiency check | Sylvain | Instrument Flight Rules | 14 | October 20th 05 09:11 AM |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
Slip to landing on PPG practical test | Roger Worden | Soaring | 56 | November 11th 04 09:38 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
