Landing Check Lists
Old December 27th 05, 10:48 PM posted to rec.aviation.soaring
Default Landing Check Lists
I was taught TOWARD
T - Traffic
O - Obstacles
W - Wind
A - Airspeed
R - Retracts
D - Dive Brakes
I still use it but I've added "gear down and locked" to my radio call.
If I start flying with ballast, I'll most likely need to change it
though.
Ray Warshaw
Old December 28th 05, 03:15 PM posted to rec.aviation.soaring
You have received quite a few replies but so far I don't think anyone
has has distinguished between written check lists as recommended by FAA
and mnemonics usually favored by glider pilots.
I use a written checklist to ensure that I have done everything
required to prepare myself and the glider for flight. That is
completed before grid time and rechecked before the contest launch
starts. After that I use no written checklists. I shudder to think
how those that can't extent the gear on short final would cope with the
task of finding, reading, executing, and stowing a checklist. I'd
rather have my eyes outside.
Mnemonic CBIFTCB covers everything I need for takeoff. I use WUFST
(water, undercarriage, flaps, speed, trim) for landing.
Andy
Old December 28th 05, 05:17 PM posted to rec.aviation.soaring
Thanks to all who have replied. My interest comes
from instructing students and giving them a consistent
procedure. Several answers were from pilots with lots
of experience and with very short checklists, which
is fine, of course. I wanted to see how many different
lists were in use. My own procedure is
W water dump
U undercarriage down
F flap setting
S pattern speed
T trim
A air brakes test
R radio
E enter pattern
I seldom fly with water, and rarely fly a flapped glider,
but by running this list through my head every time
I fly, I will have a ready reminder to save me from
embarrassment. I fly fixed gear, mostly, with students.
Without doing this it is likely that I might not lower
the gear in my own glider.
I insist on doing it all before entering the pattern
so as to have eyes outside only at that point. I'm
also in close enough, and with enough altitude, that
if the airbrakes jammed open I could still get to
the runway.
Critique, if you like. I intend to take down all these
lists and offer them up for discussion at one of our
club meetings.
don't think anyone
recommended by FAA
everything
That is
contest launch
shudder to think
would cope with the
checklist. I'd
I use WUFST
Andy
  #24
Old December 29th 05, 03:46 AM posted to rec.aviation.soaring
Nyal,
No critique, this is a good discussion, and buried in it seems to be
the concensus by experienced pilots that the checks, in whatever form,
should be done before pattern entry and not while in the pattern
actively in the process of landing.
Cheers!
Kirk
  #25
Old December 31st 05, 12:49 AM posted to rec.aviation.soaring
Nyal,
I use TOWARD . Traffic, Obstacles, Wind(direction and speed),
Airspeed, Retractable gear(down), Dive brakes(check). Not as good as
GUMP for power flying, but easy to remember.
Dean Chantiles "GO"
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
question about instrument proficiency check Sylvain Instrument Flight Rules 14 October 20th 05 09:11 AM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
Slip to landing on PPG practical test Roger Worden Soaring 56 November 11th 04 09:38 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
