Autopilot
Old January 1st 06, 07:51 PM posted to rec.aviation.piloting
Default Autopilot
Competing airline advertising themes would be "Our planes have pilots."
"Ramapriya" wrote in message
Don't ask me why such Airbuses aren't certified for pilotless flight;
union pressures, perhaps )
Ramapriya
Old January 1st 06, 07:52 PM posted to rec.aviation.piloting
Default Autopilot
"Ramapriya" wrote in message oups.com...
Tim923 wrote:
I don't have an aviation background. Can autopilot do the takeoff and landing?
Of course. You can program any Airbus A320/330/340/380 to fly itself,
using its FMGS. All you need to do manually is taxi it to the edge of
the runway, and taxi it away again after completion of the landing
roll. The entire flight can be pilotless.
Ramapriya
The 747 has been capable of this for years, since ~69 or so. The pilot does have to advance the throttles though...
Old January 1st 06, 09:13 PM posted to rec.aviation.piloting
Default Autopilot
rote
I know this isn't a flight-simulator group, but I've got a
question for all the real pilots out the In general, how much
do commercial aviation pilots use their auto-pilot?
Bryan, you have used a term that may have confused many of those
who have responded to your question.
By "commercial aviation pilot", did you mean an airline pilot who
is actually an Airline Transport Pilot (ATP)or...a real Commercial
Pilot (CP) who usually flies smaller business aircraft? As you have
seen, you received a lot of BS answers from Private Pilots and even
Non-Pilots without a clue.
A Commercial Pilot (CP) certificate is simply a grade (level) of
pilot certificate and does not necessarily mean the the holder is
actually employed to fly an airplane. He may fly the same small
airplane types without an autopilot as a Private Pilot (PP).
Autopilot use by a Commercial Pilot (CP) really depends upon the
size and type of airplane that he is flying and the conditions under
which he is operating.
Now...if you really meant an airline pilot flying a jetliner, the
answer is much easier. They probably use the autopilot 95 percent of
the time. During my 25 years as an airline pilot, the autopilot
would be engaged at about 2,000' after takeoff and remain on until
2,000' above the airport prior to landing.
Bob Moore
ATP B-707 B-727
PanAm (retired)
Old January 1st 06, 09:39 PM posted to rec.aviation.piloting
Default Autopilot
Mortimer Schnerd, RN wrote:
If I'm in an aircraft with an autopilot, I use it constantly for the cruise
portion of the flight on cross countries. I always hand fly climbouts and
approaches.
I concurr with this philosophy and probably the majority of pilots do this.
My airplane does not have a coupled auto-pilot so I need to fly instrument
approaches by hand, which I don't mind because I don't do it multiple times
a day. If I did, then I would most definately want to have (and use) a
coupled auto pilot for the approaches as well. Of course I would occasionally
hand fly them just to break the monotony and maintain proficiency.
Old January 1st 06, 10:48 PM posted to rec.aviation.piloting
Default Autopilot
With the 744, I don't believe VNAV kicks in until 400 ft AGL. Below
400', you've got LNAV/FD/autothrottles.
-Dan
Old January 2nd 06, 03:50 AM posted to rec.aviation.piloting
Default Autopilot
"You have flight controls?" "Yep"
"Takeoff power set"
After about 90% of the takeoff roll: "V1" (or "Go")
3 secs later: "Rotate"
5 secs later: "Gear up"
10 secs later: "Retract all flaps"
SET THURST............. V1, Rotate, V2, posite rate, gear up, set speed
mode, set heading mode........... autopilot on (passing 500'). allow plane
to climb to "accelleration altidue" roughly 1200 agl, then transition from
initial climb speed of 190 to 250 on the autopilot, managing the transition
with vertical speed mode to keep the plane from diving for the airspeed
(changing airspeed setting changes climb rate, the CRJ does not have auto
throttles), when passing V2+20 flaps 8, V2+20 Flaps up, all done under
autopilot. Kick it off when you hear GPWS call out "100" on a precision
approach, handfly the last 80feet (bout where you will be by the time your
finger pushes the disconnect button) to touchdown, kick off and handfly when
inbound FAF and have field in sight on a nonprecision approach. Fly raw
data approaches from time to time for practice (no flight director no
autopilot, just HSI, airspeed, and altitude). CRJ actually has "footrests"
on the panel to keep the nonflying pilot from putting scuffmarks on the PFDs
and MFDs. Even single engine flying is done with autopilot, tho u need to
keep a watch out that it doesnt' take the rudder to the disconnect limit,
and if it does be ready to handfly the sucker.
Old January 2nd 06, 04:21 AM posted to rec.aviation.piloting
Default Autopilot
...how much do commercial
In both the 727 and 747, my general rule of thumb was that I would take-off
and hand fly to FL250; on approach, I would disengage at 10K and hand fly
the rest of the way. Of course, weather, crew fatigue, and regulation would
take precedence.
Old January 2nd 06, 02:00 PM posted to rec.aviation.piloting
Default Autopilot
would take-off and hand fly to FL250; on approach, I would
disengage at 10K and hand fly the rest of the way. Of course,
weather, crew fatigue, and regulation would take precedence.
Gee, John, that didn't leave much time to eat and read
the newspaper did it? :-)
Bob Moore
Old January 2nd 06, 03:20 PM posted to rec.aviation.piloting
Default Autopilot
"Bob Moore" wrote in message
Of course, all plans are amendable. ;-) In the 747, there was time for
newspaper, dinner, coffee, a nice nap, and breakfast. That plane carries
too damned much fuel!!
KAP140 autopilot and a KLN94 GPS question STICKMONKE Instrument Flight Rules 5 November 12th 05 04:06 AM
mitchell autopilot dave Owning 1 May 5th 04 06:11 PM
IMC without an autopilot Jon Kraus Instrument Flight Rules 101 April 18th 04 07:17 PM
Chelton AP-3C autopilot Kyler Laird Owning 0 April 2nd 04 03:08 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
