G1000 Check out
Old January 1st 06, 06:40 PM posted to rec.aviation.piloting
Default G1000 Check out
The KAP140 Pilots Guide in PDF format, is on the Internet.
"Michelle" wrote in message
k.net...
The Auto-pilot is another story.
The HDG,NAV and APR button work as one would expect. However altitude
navigation is confusing. I am still not sure i have it all figured out.
The ALT button toggles between alt hold and Vertical speed modes but not
all the time.
The auto-pilot seems like it is on but is really in standby mode. It
should indicate it is in standby mode but it does not. I started pushing
buttons and nothing happened.
Old January 1st 06, 08:37 PM posted to rec.aviation.piloting
"John Clonts" wrote
No, I was inquiring of NW_PILOT. I was just mildly curious what in the
WORLD he meant when he wrote "Plase I went to just put you under the hood
solved & the problem of to much time inside the cockpit".
What he was trying to say, in his own illiterate way, is that by going under
a hood, you will have a safety pilot, and you can concentrate on the
instruments, and learning how to find what you need to interpret.
Jim in NC
Old January 1st 06, 09:02 PM posted to rec.aviation.piloting
"Michelle" wrote
Lap room is limited. I could not put my Jepp book in my lap and fly the
plane.
What was limiting the lap room? Too close to the panel?
Jim in NC
Old January 1st 06, 09:04 PM posted to rec.aviation.piloting
https://www3.bendixking.com/static/d...p?pageid=/Tech
Pubs/servlet/TechPubsIndexServlet?acctno=WEBTEST&moduleName=TP& topnav=/st
atic/dealerhome/dealer-topnav.jsp
Hey dumbass if you cannot think & interpolate for a typo, maybe you should
not be flying airplanes "Place"
went to just put you under the hood solved & the problem of to much time
inside the cockpit". Or whether
perhaps he is a descendant of James Joyce
Happy new year,
John Clonts
Temple, Texas
N7NZ
Old January 1st 06, 09:14 PM posted to rec.aviation.piloting
I cannot get there. It appears to be a dealer only page.
Michelle
Old January 1st 06, 09:23 PM posted to rec.aviation.piloting
you're right. requires a login.
Aunt google was very friendly (as usual), try this one:
http://www.uofmflyers.org/pdfs/KAP140Manual.pdf
Michelle
HTH,
#m
If you prick us, do we not bleed? If you tickle us, do we not laugh?
If you poison us, do we not die? And if you wrong us, shall we not revenge?
W. Shakespeare, The Merchant of Venice, Act III, scene I
  #28
Old January 1st 06, 11:19 PM posted to rec.aviation.piloting
Michelle
HTH,
#m
I found it just after I posted the message. I should have looked and I
could have saved you the posting.
Thanks for the info. I am going to read it throughly.
Michelle
  #29
Old January 2nd 06, 12:54 AM posted to rec.aviation.piloting
Ok, thanks for that "correction".
"NW_PILOT" wrote in message ...
Happy new year,
John Clonts
Temple, Texas
N7NZ
  #30
Old January 2nd 06, 01:09 AM posted to rec.aviation.piloting
In article et,
That's interesting.
I am going to the BK site
Click on SUPPORT at the top of the page
Click on TECHNICAL PUBLICATIONS
Click on PILOT GUIDES
Type in the name or model of guide your are looking for
Fuel selector or two check valves? Rob Turk Home Built 13 July 1st 05 12:21 AM
Changes in Instrument Proficiency Check Requirements Richard Kaplan Instrument Flight Rules 71 June 10th 04 08:02 PM
Use of hand-held GPS on FAA check ride Barry Rotorcraft 1 August 30th 03 01:24 AM
Use of hand-held GPS on FAA check ride Barry Piloting 3 August 9th 03 10:14 PM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 09:25 PM
