Aspen at night
Old January 4th 06, 08:32 PM posted to rec.aviation.ifr
Default Aspen at night
FYI
For those of you not familiar with the Aspen airport or haven't
seen a chart --- think of it as a U shape, opening to the NW, and
the rest of the U is 12-14K foot mountains. A small single can
physically take off to the SW and make the turn to get out to the
NW but not too many other aircraft (other than helicopter). Landings
are to the SE, takeoffs to the NW with an immediate turn N for the
missed.
No, I've never flown into Aspen, but I live in Colorado and drive out
there to ski (well, I used to. No more skiing -- gotta pay for the
airplane)
(just to help everyone else visualize what's going on)
  #32
Old January 4th 06, 08:54 PM posted to rec.aviation.ifr
"Blanche" wrote in message ...
.... A small single can
missed.
You are technically correct, Blanche, but don't take off to the SW
without observing this note from the KASE Airport Information Chart:
"Take-off not authorized on Rwy 15 without written permission
from airport manager."
Though I'm not certain, I think noise issues affect that operation, too.
BTW, Blanche, have you ever visited the huge localizer antenna array
up at the top of Ajax, near the restaurant?
Impressive, isn't it?
  #33
Old January 4th 06, 08:58 PM posted to rec.aviation.ifr
: VFR is 1,000 foot ceiling, the MDA on many mountain
: approaches is as high as 2,000 feet above the runway.
: OK. I cannot imagine flying VFR under a 1,000 foot ceiling in the
: mountains, where peaks extend well into the ceiling.
In many places, that type of operation is S.O.P. Southeast Alaska comes to
mind. People who live and fly there generally don't get into trouble... the
statistics are generally people from Outside flying in.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
  #34
Old January 4th 06, 09:07 PM posted to rec.aviation.ifr
Jim Macklin wrote:
All missed approach gradients are based on engine out climb,
which is very weak because jets climb at high speed and thus
have a lower gradient.
Nothing in TERPs, including missed approach procedures, consider engine
out climb.
  #35
Old January 4th 06, 09:12 PM posted to rec.aviation.ifr
Yes, bush pilots are an incredible lot. I was thinking of your standard
issue GA pilot, which includes me.
There was a good book I read last year describing the life and times of an
Adirondack Mountains (NY State, USA) bush pilot. In it are stories about
spotting a hole in the clouds and confidentially dropping through that hole
to land his floatplane on a lake, discharging his passengers, then taking
off and circling back up through the hole.
Peter
  #36
Old January 4th 06, 09:36 PM posted to rec.aviation.ifr
Me neither, when I fly into the mountains, I want to be VFR
1,000 above the peaks. But so far I've been lucky, my trips
to Aspen and Angel Fire have been in widely scattered
cirrus.
James H. Macklin
ATP,CFI,A&P
"Peter R." wrote in message
ceiling in the
| Peter
  #37
Old January 4th 06, 09:42 PM posted to rec.aviation.ifr
Standard climb gradients are based on 150'/ NM (if I
remember correctly) and if a departure is greater than that,
it will be noted on the chart. FAR 135 and 121 require that
the most adverse performance be considered when operating,
gross weight must be reduced to meet the performance
requirement. Often you will see airliners with half the
seats empty because the airplane can't meet the take-off
requirements.
I did not say it very well the first time.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
news:3NWuf.6579$V.94@fed1read04...
climb,
thus
consider engine
| out climb.
  #38
Old January 4th 06, 11:20 PM posted to rec.aviation.ifr
requirements.
Departures are standard if they do not exceed 200 feet per mile.
Missed approach surfaces are 40:1, which is 152 feet per mile. That is
probably the 150 per mile you're thinking of. The current FAA thinking
is that a missed approach requires 200 feet per mile, and the AIM so
states. (AIM 5-4-20 b)
One-engine climb gradient requirements apply on the commercial
operators. (121.189 for air carriers). But, the air carrier, under
121.189, is not required to look at the missed approach procedure's
entire area of protected airspace. If the carrier finds that will not
penalize them they are free to simply accept the missed approach as a
missed-approach OEI flight path.
As you know, the 121.189 issues are far more pronounced on departure
than they are on the typical missed approach.
  #39
Old January 5th 06, 12:36 AM posted to rec.aviation.ifr
KISS WAG SWAG PDC
150/152 even 200 ft/nm is shallow, but most light aircraft
and many jets with an engine out can't do it at altitudes
above 5,000 feet.
James H. Macklin
ATP,CFI,A&P
news:AJYuf.6585$V.412@fed1read04...
that,
that
operating,
| requirements.
mile.
mile. That is
FAA thinking
the AIM so
commercial
carrier, under
procedure's
that will not
approach as a
departure
  #40
Old January 5th 06, 12:54 AM posted to rec.aviation.ifr
Jim Macklin wrote:
KISS WAG SWAG PDC
above 5,000 feet.
Then, there are the high-end biz jets that can do 700 feet per mile (SL,
standard day) with OEI.
FAA PPL night flight requirement - does it have to be DUAL? Peter Clark Piloting 21 January 6th 05 12:38 AM
Night solo XC? G. Burkhart Piloting 51 October 14th 04 03:11 PM
Night of the bombers - the most daring special mission of Finnishbombers in WW2 Jukka O. Kauppinen Military Aviation 4 March 22nd 04 11:19 PM
