![]() "pgbnh" wrote in message ... The installation of the GNS530 is complete. The learning is just begun. But since I now have equipment which allows it, what is the likelihood of receiving 'cleared as filed' if I file direct to a destination a few hundred miles away? The likelihood of that was not changed by the installation of the GNS530. Whether or not a direct clearance of a few hundred miles distance is available depends on ATC radar coverage and what lies between your departure point and destination. If there's a busy terminal or some SUA in the way you'll have to go around them. If radar monitoring cannot be provided by ATC you'll be on airways. |
Interesting. I THOUGHT that the possibility of 'Direct' was improved if I
had an on-board IFR-approved capability to fly direct. So that ARTC would not have to be directly involved issuing a series of vectors (or at least monitoring that I was slying the vector assigned) You are saying that the likelihood of receiving Direct is solely dependent on airspace to be crossed and radar availability? "Steven P. McNicoll" wrote in message nk.net... "pgbnh" wrote in message ... The installation of the GNS530 is complete. The learning is just begun. But since I now have equipment which allows it, what is the likelihood of receiving 'cleared as filed' if I file direct to a destination a few hundred miles away? The likelihood of that was not changed by the installation of the GNS530. Whether or not a direct clearance of a few hundred miles distance is available depends on ATC radar coverage and what lies between your departure point and destination. If there's a busy terminal or some SUA in the way you'll have to go around them. If radar monitoring cannot be provided by ATC you'll be on airways. |
![]() "pgbnh" wrote in message ... Interesting. I THOUGHT that the possibility of 'Direct' was improved if I had an on-board IFR-approved capability to fly direct. So that ARTC would not have to be directly involved issuing a series of vectors (or at least monitoring that I was slying the vector assigned) ATC must provide radar monitoring to aircraft on vectors as well as to aircraft on their own off-airways navigation, even aircraft that have filed /E, /F, /G or /R. You are saying that the likelihood of receiving Direct is solely dependent on airspace to be crossed and radar availability? Yup. See paragraphs 4-1-1 and 4-1-2 at the link below: http://www.faa.gov/atpubs/ATC/Chp4/atc0401.html |
Limited exerience filing IFR here, but out of Denver class B, one
usually gets direct routing. Even when I've filed DPs and airways, departure will typically change it to direct shortly after departure (assuming you've filed /G). -Brian |
Last week, both Ft. Worth and Houston centers said "radar contact lost,
report X miles from Y" while I was cleared direct (not on airways) with /G equipment - in Texas, going west into large headwinds at 4000. On that trip - from central TX to KSAV and back, there were 6 legs. On the first leg, I filed a few fixes and soon after handoff to ZHU was asked "would you like direct HEZ". Next leg, while filing on phone, when I got to route FSS said "direct"? And I said yes, and that was the clearance when I picked it up. Same on next leg, and next, etc. So 5 out of 6 I filed that way and got and on the other, they suggested right away. No transits through Class B, though. I'm sure YMMV in other parts of the country, but from this I learned: 1) file that way and 2) even if radar contact lost, sometimes they won't send you directly to an airway. DL "Steven P. McNicoll" wrote in message nk.net... The likelihood of that was not changed by the installation of the GNS530. Whether or not a direct clearance of a few hundred miles distance is available depends on ATC radar coverage and what lies between your departure point and destination. If there's a busy terminal or some SUA in the way you'll have to go around them. If radar monitoring cannot be provided by ATC you'll be on airways. |
![]() "DL" wrote in message nk.net... Last week, both Ft. Worth and Houston centers said "radar contact lost, report X miles from Y" while I was cleared direct (not on airways) with /G equipment - in Texas, going west into large headwinds at 4000. Cleared direct to where and how far from it were you when radar contact was lost? I'm sure YMMV in other parts of the country, but from this I learned: 1) file that way and 2) even if radar contact lost, sometimes they won't send you directly to an airway. You don't necessarily have to be on an airway, but if you aren't you have to be proceeding direct to a navaid and be within the usable distance. |
![]() DL wrote: Last week, both Ft. Worth and Houston centers said "radar contact lost, report X miles from Y" while I was cleared direct (not on airways) with /G equipment - in Texas, going west into large headwinds at 4000. That's how Salt Lake does it also. It's common to get direct and lose radar coverage for a portion of the flight. As long as you're above the controllers MIA you're good to go. I'm sure YMMV in other parts of the country, but from this I learned: 1) file that way and 2) even if radar contact lost, sometimes they won't send you directly to an airway. An airway may not be anywhere near you're route of flight either, which is the case here. |
![]() "Newps" wrote in message ... That's how Salt Lake does it also. It's common to get direct and lose radar coverage for a portion of the flight. As long as you're above the controllers MIA you're good to go. No, you're not good to go, you're just working with a poorly trained controller. An airway may not be anywhere near you're route of flight either, which is the case here. Where? |
![]() "Steven P. McNicoll" wrote in message ink.net... "DL" wrote in message nk.net... Last week, both Ft. Worth and Houston centers said "radar contact lost, report X miles from Y" while I was cleared direct (not on airways) with /G equipment - in Texas, going west into large headwinds at 4000. Cleared direct to where and how far from it were you when radar contact was lost? Cleared direct to an AIRPORT (with NDB as only navaid there). Radar contact lost 196 miles out. Was requested to report 175 miles from K---. Was asked distance out a couple of times before reaching 175 miles. Then handed to next Center. Was asked to report 125 miles from K--- and asked a time or two range a time or two before reaching that. Then before reaching 125 miles, Center reported "radar contact". I'm sure YMMV in other parts of the country, but from this I learned: 1) file that way and 2) even if radar contact lost, sometimes they won't send you directly to an airway. You don't necessarily have to be on an airway, but if you aren't you have to be proceeding direct to a navaid and be within the usable distance. I also had a similar experience with only one of these two Centers, several years ago and with /A equipment then. When they reported "radar contact lost" I proactively asked if I needed to proceed to the nearest airway and they said no - to continue. I e-mailed a controller in another Center (who frequently posted to this newsgroup) about that experience and was told it "was done". Steven, you may be able to speak to the "letter and verse" of the rules, but you may not know every practice in every center, as seems to be suggested here. |
![]() DL wrote: Cleared direct to an AIRPORT (with NDB as only navaid there). Radar contact lost 196 miles out. Was requested to report 175 miles from K---. Was asked distance out a couple of times before reaching 175 miles. Then handed to next Center. Was asked to report 125 miles from K--- and asked a time or two range a time or two before reaching that. Then before reaching 125 miles, Center reported "radar contact". That's exactly how Salt Lake does it. Going north from here(BIL) ZLC loses radar below about 9500. Since you're not in the mountains anymore 6-7000 are commonly used altitudes. After I ship you to the center often ther first response is "radar contact lost report xxx." There's another center radar antenna up near the Canadian border and they will pick you back up in a 100-150 miles or so. Same thing inbound to BIL. They will coordinate with me that a particular aircraft is nonradar. I will see them as my radar is closer. There are no airways going north out of BIL, only NW and NE and we don't make you go that way to get where you're going. |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Direct To a waypoint in flightplan on Garmin 430 | Andrew Gideon | Instrument Flight Rules | 21 | February 18th 04 01:31 AM |
"cleared to ... when direct ..." | John Harper | Instrument Flight Rules | 21 | February 11th 04 04:00 PM |
"Direct when able" | Mitchell Gossman | Instrument Flight Rules | 18 | October 21st 03 01:19 AM |
Filing direct | John Harper | Instrument Flight Rules | 10 | October 9th 03 10:23 AM |
