Resource for choosing a plane?
Old January 5th 06, 04:38 PM posted to rec.aviation.owning
Default Resource for choosing a plane?
"Scott Skylane" wrote:
For one thing, the TCM IO/TSIO-360 is a *six* cylinder powerplant, that
puts out the same 200 horses that Lycoming's *four* cylinder IO-360 does.
So, no, "overworking" is not an issue.
What's the number of cylinders got to do with it?
Dan
C-172RG at BFM
Old January 5th 06, 09:00 PM posted to rec.aviation.owning
The PA28-235 is a great plane, but is this true in Colorado Springs?
In the summer?
Actually, yes.
My Cherokee 180 serves as a wonderful 2-place in the Midwest, but when
I visited Boulder in the summer, takeoff and climbout were less than
spectacular, and I was 200lbs under gross.
Did you lean the engine for departure?
There is a DRAMATIC difference between taking off with a properly
leaned engine (above 3000 MSL) and an engine running full rich.
Yes, I teach mountain flying in the Cherokee-180 in the Colorado
Rockys.
The Colorado Pilots Association will present the mountain flying
course in May an August this year at Centennial Airport (APA), south
of Denver.
I am available for mountain flight instruction (your airplane or
mine) any time, at your convenience.
Best regards,
Jer/ "Flight instruction/mountain flying are my vocation!" Eberhard
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jeratfrii.com http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 235 Young Eagles!
Old January 5th 06, 09:48 PM posted to rec.aviation.owning
Dan,
Absolutely nothing, which was my point in responding to Honeck's
assertion that the TCM 360 is a *four* cylinder engine with a reputation
of being "pushed too hard"(his words).
Happy Flying!
Scott Skylane
N92054
Old January 6th 06, 01:58 AM posted to rec.aviation.owning
Regardless of the number of cylinders, Jay said it is pushed too hard in
comparison to the O-540. Which puts out 235 hp.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 6th 06, 04:04 AM posted to rec.aviation.owning
On 4-Jan-2006, "Jay Honeck" wrote:
It's common to think that the Turbo Dakota used a turbo-charged version of
the six-cylinder O-540 that is standard in all other PA28-235/236s.
Unfortunately, Piper opted to use the Continental TSIO-360 -- a
four-cylinder engine -- and it has been much maligned as being an engine
that is "pushed too hard" and thus doesn't last long.
Actually, the Continental TSIO-360 is a 6 cyl engine. Otherwise, I think
Jay's comments are accurate. The Turbo Dakota is really much more a fixed
gear version of the Turbo Arrow. (Same engine, airframe, similar useful
load, but quite a bit slower due to the fixed gear.)
From the OP's list of desired characteristics, I'd have to say that a Turbo
Arrow might be the "obvious" choice. Other models might fit the mission
(and his body size/shape) better, but not within his $100K budget. Some
owners have had issues with the TSIO-360, but it works better on the T-Arrow
than the T-Dakota because of better cooling (due to higher airspeed).
Another factor is that T-Dakotas are rare, but T-Arrows were built in large
numbers in the 1977-80 time frame, and are quite plentiful on the used
market.
As to questions of added costs associated with retractable gear and CS prop:
RG will probably end up costing $200-300 extra per year for hull insurance.
Based on our experience (normally aspirated 1979 Arrow IV) extra
maintenance averages about $250/year. However, we save about $1500 per year
in fuel costs (flying 150 hrs), compared to similar performance FG aircraft
(e.g. C-182, Dakota). The CS prop probably costs about $1.50-2.00/hr in
extra maintenance costs (largely the cost of overhaul). However, it is a
must for turbocharged aircraft.
-Elliott Drucker
Old January 6th 06, 04:12 AM posted to rec.aviation.owning
Whoops. I was mistaking it for the Lycoming O-360.
My bad.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 6th 06, 04:13 AM posted to rec.aviation.owning
Actually, I was repeating what the Cherokee 235/236 user's group says about
that bird. I've got no personal experience with the Turbo Dakota.
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #28
Old January 6th 06, 05:50 AM posted to rec.aviation.owning
I have that book on backorder from Amazon! Should have it in a week or two
(so they say)....
Thanks!
Doug
"Where am I to go/Now that I've gone too far?" -- Golden Earring, "Twilight
Zone"
(my email is spam-proofed; read the address and make the appropriate change
to contact me)
"George Patterson" wrote in message
news:QuIuf.2936$If.451@trnddc05...
Douglas Paterson wrote:
What I'd really like to find is some sort of direct comparison tool--like
you find in an auto magazine, say--such as a table with columns listing
features, with added commentary on each model's pros and cons. From
reading this group, I've found a couple of browsing tools, but nothing
that really hits the mark. Suggestions?
I know of nothing out there. What I did when I was shopping for my first
aircraft was to buy a copy of Bill Clarke's "The Illustrated Buyer's Guide
to Used Airplanes" and make lists of possible candidates. You should be
able to throw together a table or spreadsheet of possibilities. There
won't be too many singles that fit all of your conditions.
George Patterson
  #29
Old January 6th 06, 05:54 AM posted to rec.aviation.owning
Combining my response to several posters, all with great information. I'm
"new" here, yet this group is already giving me a mile when I asked for an
inch--thanks everyone for the advice! I've responded individually to a
couple of posters who touched on some points I have a specific follow-up
about, but I appreciate ALL of the responses.
Careful--you guys keep being nice to me, I may stick around....
Doug
Zone"
to contact me)
wrote in message ...
In the summer?
Actually, yes.
Rockys.
of Denver.
Best regards,
  #30
Old January 6th 06, 06:01 AM posted to rec.aviation.owning
"Nathan Young" wrote in message
[snip]
You are correct to be more concerned about op costs than acquisition
costs. Minus cost of money, you will get your acquisition costs back
when you sell.
My thoughts exactly--that's why my $100K figure is "soft," more of a comfort
number than anything else.
Factoryengines.com lists an
overhaul on a TIO540 engine (for the Turbo Lance) at $40k.
Now there's a number that kinda scares me--that's at least twice the amount
of any overhaul estimates I've seen in my (admittedly limited) reading. Is
that a function of the turbo??
As I said, my "requirements" are all written in Jell-O. I'm *just* getting
started--really, this discussion is the most in-depth I've gotten so far.
If turbo is the only way I can get the heavy lift I want from my
high-altitude location, but it's prohibitively expensive, well, I may have
to revise my requirements.... That goes for everything I listed in my
original post.... That Cherokee 140 for $25K is looking better and better
at this point!!
Doug
Zone"
to contact me)
Passenger crash-lands plane after pilot suffers heart attack R.L. Piloting 7 May 7th 05 11:17 PM
Navy sues man for plane he recovered in swamp marc Owning 6 March 29th 04 12:06 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
