see four-point sockets
Old January 5th 06, 01:47 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
Default see 5-point sockets
Flyingmonk wrote:
What're BF, BFH and LF?
The Monk
Well B is big, F is not for polite conversation, H is hammer, L is
little. Hope this (F) helps
  #32
Old January 5th 06, 04:22 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
On Wed, 04 Jan 2006 11:46:06 -0500, Brent Philion
Andy Dingley wrote:
On Wed, 04 Jan 2006 05:53:00 GMT, "Stephen H"
Looked real hard at the nut... I'll be dammed a 5-point nut.
Where the hell did that come from.
Fire hydrant ?
Leatherman Multitools
My wave has a 5 point security bit
5-point bolt heads (and other strange and wonderful fastener
designs) are often found holding things closed that they don't want
the average induhvidual off the street to get into, the Leatherman
Tools are one good example They'll fix it for you for free if you
send it back for service, so you don't need the special 5-point Tamper
Torx driver. Controls unauthorized mods that could cause injuries.
Or things that aren't supposed to come apart at that point, like
those motor mounts. Sounds like that's for the 'backup bolt' on the
mount, meant to keep the engine from falling totally out of the car if
the rubber mount fails - and there's always some fool who will remove
the bolt "To save weight" and then act surprised when the engine falls
on the freeway at speed...
(And then they'll sue the manufacturer of the 'defective' motor
mount - and win. Look up "Chutzpah" in the dictionary.)
Things like the lids of Power Utility manholes and handholes, where
there are seriously hazardous voltages lurking inside... Which is the
reason I need to get a few of those 5-point sockets, so when I get
called out on an outage I can confirm whether or not it's dead in
there. And secure the lid properly if someone else didn't.
It's one of those "Kids, Don't Try This At Home!" things.
Occasionally (two small associations we service) they tap HOA owned
streetlight poles straight from the Edison handhole with a simple
inline fuseholder and pay a flat-rate for the power - which is cheaper
than installing a meter pedestal and paying the monthly minimum for a
meter. And I very occasionally need to get in there and pull the fuse
so I can work on the pole without the ahem excitement factor.
I do my darnedest to make sparks only when I'm welding. On purpose
type welding. With a MIG torch in my hand. Oh heck, you get it... ;-P
-- Bruce --
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
  #33
Old January 5th 06, 04:47 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
It sure (F) cleared things up for me :^)
The Monk
  #34
Old January 5th 06, 06:02 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
You weren't trying to loosen the hood ornament were you? ;-)
Working on Dodge caravan the other day, couldn't get my 19mm to fit and the
20 was too large. Went to the sae set, nothing would fit.. Looked real hard
Stephen W. Hansen
ASE Certified Master Automobile Technician
ASE Automobile Advanced Engine Performance
ASE Undercar Specialist
http://autorepair.about.com/cs/troub...l_obd_main.htm
http://www.troublecodes.net/technical/
roups.com...
four point (square) sockets (and/or wrenches)
who makes them, who retails 'em?
  #36
Old January 5th 06, 08:56 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
Default see four-point sockets
MOP CAP wrote:
This has been going on for so long that I can't resist a "tool gloat".
Two years ago I picked up at a fles market 3 new old stock 9 piece 1/2"
drive 8 popint socket sets for $25. Don't bother they are all gone
except for the one I kept.
Chuck P.
I ended up with a complete set of (as in every 8 point socket Craftsman
makes) many years ago now. I have them all together on one of those
'socket rail' gimmicks hanging way up on the back edge of the peg board.
I probably on average have a use for any of them every other year or so,
but can recall them 'saving the day' a few times... mostly dealing with
old square head lag bolts, and turning big 1/2" easy outs doing plumbing
work. A good friend/neighbor had borrowed and used them more than I
have, but doing the same kind of things. They're probably at least 30
plus years old now, and still look new...
The 'lead in chamfers' are a bit excessive on most of them... seems
every time I do use them I think I'd like to do something about that.
Erik
  #37
Old January 6th 06, 05:33 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
That Makes sense.
Steve
"Bruce L. Bergman" wrote in message
Fire hydrant ?
-- Bruce --
  #38
Old January 6th 06, 07:16 AM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
the other thing about specialist tools is a bit of a liability issue
you CAN work around them but unless you know where and how to find the
right tool to tear apart something that shouldnt be tampered with odds
are you shouldnt be tampering with it
you CAN rig up a manhole Lidlifter for example but there is a reason
manholes are not easy to lift
12 feet underground in a flooded area that just been pumped with high
voltage is not a friendly place for untrained people and thats just a
telecom manhole let alone a sewer or hydro one.
Stephen H wrote:
That Makes sense.
Steve
Fire hydrant ?
-- Bruce --
  #40
Old January 6th 06, 04:51 PM posted to rec.crafts.metalworking,rec.autos.tech,rec.aviation.homebuilt
On Fri, 06 Jan 2006 02:16:09 -0500, Brent Philion
you CAN rig up a manhole Lid lifter for example but there is a reason
Yeah - cause they're also really hard on your toes if you drop them.
It's like a Rigger, you have to keep your feet out of the "No Zone".
And steel-toes don't help at all if it's your ankle in the way.
Actually, voltage concerns are not a big problem with telecom
manholes - everything down there is Class 2 Current Limited. Some of
the carrier circuits have 300V or more on them, but most is -48V DC.
Bad air from oxygen depletion or hydrogen sulphide and explosive
vapors are a much more imminent hazard, and all you need to do to get
killed by them is climb inside without testing and ventilating the
space first. I was a construction splicer for 8 years.
Everything involved with telephones is bonded and grounded 47 ways
from Sunday. The only holes we had to worry about power were ones
located directly under the path of a high-tension transmission line,
and they simply wanted us to keep the bonding straps connected at each
cable end at all times, and hook up temporary grounds to the racking
(instead of leaving them open for the day) and setup our work
positions sitting on a rubber blanket with HV Lineman Gloves at the
ready "just in case" we had to bail out in an emergency.
-- Bruce --
Adding a lifting point. [email protected] Home Built 1 March 8th 05 03:05 PM
A Question For Real Airline Pilots Blue Simulators 34 September 6th 04 01:55 AM
flight training - 100nm night flight requirement Jonathan Piloting 36 May 11th 04 07:34 PM
How fast should an ADF point? Ben Jackson Instrument Flight Rules 6 November 21st 03 03:50 AM
Reaming needed on aft wing attach point. Boelkowj Home Built 0 November 7th 03 01:30 AM
