#101
Thomas Borchert wrote:
Jose, Is the fuel lighter, or does it use less fuel per mile or per hour (for the same power)? Diesel has more energy per weight than Avgas. And the modern diesel engines use less fuel for the same power. Much less. But the engines, at least the ones certificated, are not lighter. Some are heavier than comparable Avgas engines. The thermal energy per weight unit is roughly the same for all hydro-carbon liquids, AVGAS and JET-A1 (used by aviation diesels) included. What makes for the better fuel economy of a Diesel engine (compared to the gasoline engine Otto process) is from two sources: - the greater compression ratio makes an ideal thermal engine (Carnot process) work with better efficiency, - the long combustion in a Diesel engine makes the process approximate the ideal process better (constant pressure). -- Tauno Voipio tauno voipio (at) iki fi |
#102
Jim Macklin wrote:
Maybe, but you have to live near where I'll live. You also have to be an NRA Life member for at least 5 years. NRA ten plus, but I think I didn't pay my last due. Have plenty of toys that go Bang! :^) The Monk |
#103
![]() "Thomas Borchert" wrote And the modern diesel engines use less fuel for the same power. Much less. But the engines, at least the ones certificated, are not lighter. Some are heavier than comparable Avgas engines. It can be argued that an aviation diesel can be much smaller than an aviation gas engine, displacement wise, and still perform the same. The superior torque of a diesel, plus the longer duration of the power stroke just seems to turn a prop better. Thus, you can come closer with the weight comparison. -- Jim in NC |
#104
I would certainly think so. However, I wasn't consulted. I assume it
came down to money. |
#105
Life member since 1968, don't have to pay every year that
way. Bought my boys and wife life memberships too. Don't have many toys today, will buy that Legend Cub someday. The odds of winning the lottery are about 160 million to 1, damn near a sure thing. Can't afford the new AOPA life member option until I win that lottery, but I am also EAA Life with a fairly low number. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Flyingmonk" wrote in message ups.com... | Jim Macklin wrote: | Maybe, but you have to live near where I'll live. You also | have to be an NRA Life member for at least 5 years. | | NRA ten plus, but I think I didn't pay my last due. Have plenty of | toys that go Bang! :^) | | The Monk | |
#106
number. What was that? You're an EAA low life? ![]() Jose -- You can choose whom to befriend, but you cannot choose whom to love. for Email, make the obvious change in the address. |
Fuel selector or two check valves? | Rob Turk | Home Built | 13 | July 1st 05 12:21 AM |
Changes in Instrument Proficiency Check Requirements | Richard Kaplan | Instrument Flight Rules | 71 | June 10th 04 08:02 PM |
Use of hand-held GPS on FAA check ride | Barry | Rotorcraft | 1 | August 30th 03 01:24 AM |
Use of hand-held GPS on FAA check ride | Barry | Piloting | 3 | August 9th 03 10:14 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
