VFR GPS
Old March 25th 04, 01:39 AM
Hankal
Default VFR GPS
This is not just for controllers.
Will it help if I file in the remarks "VFR GPS"
I file 172/U
Will I get more direct to commands.
I still fly VOR to VOR but sometimes I am out of range, but still get proceed
direct.
Hank
Old March 25th 04, 01:49 AM
Steven P. McNicoll
"Hankal" wrote in message
I file 172/U
still get proceed direct.
If you want direct, file direct. If ATC can provide radar monitoring they
can clear you direct regardless what equipment suffix you use.
Old March 25th 04, 02:37 AM
What if I file direct between two VORs that are 180 miles apart, I am cleared
as filed, then while proceeding between those two VORs, ATC radar goes down?
Old March 25th 04, 02:51 AM
Steven P. McNicoll
wrote in message ...
am cleared as filed, then while proceeding between those two
Then ATC will put you on an appropriate nonradar routing, probably on
airways.
Old March 25th 04, 03:19 AM
Donald Ramsey
airways.
When radar fails, do ATC folks have at their avail the last recorded
positions of all aircraft or a computed projection (coast?), or do
all the screens just go black? :O I don't doubt that most controllers
can revert back to non-radar procedures and successfully handle traffic,
I'm just curious how the transition would occur.
--Don
Old March 25th 04, 03:42 AM
Newps
Depends on what failed. If the radar itself failed then you would still
have the coast tags. If the radar display itself failed you have your
paper strips and your memory.
A real display failure with any amount of traffic is a total goat rope.
Approach controllers don't do nonradar and if forced to do so on
zero notice it could get real ugly real fast.
Old March 25th 04, 09:41 AM
Centers these days don't do real well at non-radar, either, compared to the
"good old days." This is particularly so where they provide non-radar
terminal services, such as at a place like Jackson Hole, Wyoming.
Old March 26th 04, 04:25 AM
Andrew Sarangan
Our problem is the opposite. When we file using airways we almost
always get a direct via radar vectors. This messes things up if it
happens to be a training flight. We end up having to renegotiate an
airway clearance. If I include "training flight" in the remarks box I
have had better luck with getting the route I want.
"Steven P. McNicoll" wrote in message ink.net...
I file 172/U
Old March 26th 04, 01:21 PM
tscottme
Newps wrote in message
news:Fys8c.2523$K91.15525@attbi_s02...
rope.
So you recommend being the first aircraft to declare an emergency when
the failure happens? ;-)
Scott
Old March 26th 04, 02:52 PM
Newps
rope.
No, the first one to cancel.
