Nasa Icing courses
Old January 9th 06, 08:13 AM posted to rec.aviation.ifr,rec.aviation.owning
Default Engine Making Metal (Was: Nasa Icing courses)
With the low rpm, air flow in the manifold is not smooth or
steady. A carb meters fuel based on volume and the engine
burns fuel by mass. Getting balanced and safe fuel mixture
in each cylinder with a carb is not easy, they tend to meter
a little extra at all power settings. Aircraft injection is
usually constant flow port injection, but it is more precise
and the fuel is dumped into the intake manifold just at the
intake valve. The automotive and newer aircraft systems
have controlled injectors which only squirt fuel as needed,
making even more accurate distribution.
Diesel and the big radial engines late in WWII/until the
1950's had direct injection into the combustion chamber.
[Most radials used a pressure carb [fuel injection with the
nozzle in the throttle body] or port injection.]
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"George Patterson" wrote in message
news:Volwf.18567$em5.10846@trnddc05...
| Stan Prevost wrote:
| "Jim Macklin"
| news:Wgcwf.40975$QW2.5751@dukeread08...
| point and then pull the mixture to shut it down. That
| should show a slight 25-50 rpm increase just as it shuts
| down since idle should be a little rich.
| For my TIO540-S1AD, Lycoming says five rpm, not more
than ten.
| The mixture on injected engines typically is not as rich
at idle as carburetted
| engines, so the rpm increase should not be as great.
| George Patterson
| Coffee is only a way of stealing time that should by
rights belong to
| your slightly older self.
  #72
Old January 9th 06, 11:50 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
It makes me wish that
all cams had a direct spray oil system, and that there was an electric oil pump that could be used to lubricate the
engine prior to startup.
Paul Missman
You can add a pre-oiler, (at least to some aircraft).
http://www.aircraftspruce.com/catalo...s/proluber.php
I've read of engine modifications for spray nozzles as well but don't have time to find a link right now.
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
  #73
Old January 9th 06, 11:52 AM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
In article .com,
"Jay Honeck" wrote:
I was told ground runs is one of the worst things you can do to an airplane
engine, as it was designed for sustained high RPM operations, not ground
run RPMS.
You know, I've heard that since Day One of ownership, too, but ya just
gotta wonder if it's not yet another "old wive's tale", like so many of
these "tried and true" things. How does the engine know the
difference between ground runs at, say 2000 RPM (run-up speed on our
plane) and an extended descent? Is *that* "bad" for the engine, too?
consider the difference in cooling air.
Bob Noel
New NHL? what a joke
  #74
Old January 9th 06, 02:13 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Ground running does not scavenge the vapors since the vent
system depends on airspeed.
James H. Macklin
ATP,CFI,A&P
some support
"Jay Honeck" wrote in message
do to an airplane
| run RPMS.
but ya just
like so many of
speed on our
engine, too?
| Doesn't running it for 30 minutes on the ground circulate
the oil, and
| prevent corrosion? Can't you get oil temps up to 150 or
better (I
| know, 180 is optimal, but...) with a ground run? Isn't
that better
| than letting it sit and rot till spring?
| I fly too often for this to really matter, but I always
wonder if it's
| a real issue or not? Kinda like "shock cooling" and
"pulling the prop
| through" before starting on a cold day... And Marvel
Mystery oil,
| while we're at it...
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
| www.AlexisParkInn.com
| "Your Aviation Destination"
  #75
Old January 9th 06, 02:30 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
: Your bad lobe is one of the cam lobes that operates two lifters, so it,
: or its companion will be the first to go in a marginal lubrication
: situation. The lobes depend on oil thrown from the crankshaft cheeks -
: some thing that I don't think happens for a couple of minutes after a
: cool start - especially with a cold engine.
: It isn't a question of how quickly does the oil pump get oil get to the
: cam bearings as journal bearings will retain enough oil to allow them
: to be starved for a minute or two and oil gets there in a few seconds
: anyway.
It's quite unfortunate that the regulations make adding an oil
accumulator/pre-oiler cost-prohibitive for most. Pushing 60-80psi oil from the last
run into the system 30-60 seconds before hitting the starer would help a lot of this.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
  #76
Old January 9th 06, 04:07 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Jay Honeck wrote:
Running the engine too slow at startup. Apparently, the cams in some
engines get lubrication mainly from the oil splashing around inside the
case. In some engines, 1000 RPM may not be sufficient for full
lubrication after startup. My A&P suggested 1100 - 1200 RPM.
Isn't that a stitch? Your A&P says 1000 RPM is too *slow* for proper
lubrication. Jim Macklin (and many others) says it may be too *fast* to
run your engine before proper lubrication has occurred. Who is right?
And my A&P says 1000 RPM or slower, primarily to save your prop on loose
rocks but also to ensure long engine life.
Argh. Wouldn't you think there would be SOME science to this?
You'd think so, and maybe there is, but if so it hasn't penetrated the pilot
community. Most of what you read is superstition, collective wisdom, common
sense, anecdotal reports, opinion, experiments run with small sample sizes.
Seems the best you can do is to read all the recommendations and try to do the
things that make sense to you. It's frustrating.
Dave
  #77
Old January 9th 06, 04:10 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
I've wondered that myself. The only big difference that I can think of is that
the circulation of cooling air will be different. As far as long descents is
concerned, I've seen statements that this is harmful due to excessive cooling
and possible plug fouling. Never seen a claim that oil circulation suffers, though.
Doesn't running it for 30 minutes on the ground circulate the oil, and
prevent corrosion? Can't you get oil temps up to 150 or better (I
know, 180 is optimal, but...) with a ground run? Isn't that better
As several others have pointed out, circulation of the oil isn't the problem
with the cam lobes. Those are lubricated by splash from the crank. I've never
seen any claims that this differs much from splash while in flight, though.
What I've read is that you really can't get the oil temperature high enough by
running it on the ground. The claim is that ground running adds water and acids
to the oil (flying also does this) and never gets the oil hot enough to vaporize
these. Crankcase ventilation through the breather is also very poor on the
ground; as a result, vapors that do form never leave the crankcase. As another
poster suggested, some form of positive crankcase ventilation would probably
help that.
If the only real issue proves to be the buildup of pollutants in the oil from
ground running, then changing the oil after every other run would take care of
the problem; however, given a choice between this and simply flying the plane
for a few hours, I'd be in the air.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
  #78
Old January 9th 06, 04:40 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
I'm guessing, but in an extended descent, the engine was already running
full bore for a while and is nice and hot and happy. In a ground run,
the engine probably started out cold and never got hot and happy.
Jose
Money: what you need when you run out of brains.
  #79
Old January 9th 06, 05:34 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Default Nasa Icing courses
Pete,
I have read and participate in r.a.s for the last few years. The
newsgroup is not 'restricted' to primary students. There are many
instrument/comercial etc. students there as well and IMHO, the
learnings are never stopped for all pilots.
The website link which Jim provided has section on ground icing as
well. The information benefits all pilots and not just IFR rated
pilots.
Again, IMHO, there are no such things as too much information when
it comes to safety issues. Weather is totally unpredictable, VFR
pilots can encounter icing unintentionally. I had posted the account
of my first encounter with freezing rain about this time last year (not
in weather forecast, we were not in the cloud). What happened to us
could have happened to many pilots including primary students on a
solo VFR flight.
Any perceived problem with cross postings of on-topic subject is
quite insignificant in comparison to the numerous off topic, thread
hijacking branching out to politic and religious discussions seen at
rec.avatiation newgroups!
Hai Longworth
  #80
Old January 9th 06, 05:50 PM posted to rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
On Sun, 08 Jan 2006 05:02:33 GMT, George Patterson
In the absence of some catastrophe, such as a bent pushrod, this is generally
caused by not flying enough. The layer of hardened steel on a camshaft is fairly
thin. Let the plane sit long enough, and rust will form. When the engine starts
again, the rust is worn away, making the thin layer of hardened steel thinner.
The worst wear points, of course, are the tips of the lobes. Once the hardened
steel wears through, the softer steel underneath goes pretty rapidly.
The automotive world tried out roller lifters a long time ago. They
would work fine in aircraft engines too. I've heard that some of the
engines built for the homebuilt market can and do incorporate roller
lifters. I even thought I read that at least one company was
intending to certify such an engine.
Corky Scott
Nasa Icing courses Jim Burns Piloting 96 February 1st 06 04:16 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
NASA Icing Course [email protected] Piloting 3 December 28th 04 05:18 PM
About Acellerated Courses for Private Dudley Henriques Piloting 137 July 22nd 04 04:21 AM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
