#71
How does the engine know the
difference between ground runs at, say 2000 RPM (run-up speed on our plane) and an extended descent? Is *that* "bad" for the engine, too? I'm guessing, but in an extended descent, the engine was already running full bore for a while and is nice and hot and happy. In a ground run, the engine probably started out cold and never got hot and happy. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#72
Pete,
I have read and participate in r.a.s for the last few years. The newsgroup is not 'restricted' to primary students. There are many instrument/comercial etc. students there as well and IMHO, the learnings are never stopped for all pilots. The website link which Jim provided has section on ground icing as well. The information benefits all pilots and not just IFR rated pilots. Again, IMHO, there are no such things as too much information when it comes to safety issues. Weather is totally unpredictable, VFR pilots can encounter icing unintentionally. I had posted the account of my first encounter with freezing rain about this time last year (not in weather forecast, we were not in the cloud). What happened to us could have happened to many pilots including primary students on a solo VFR flight. Any perceived problem with cross postings of on-topic subject is quite insignificant in comparison to the numerous off topic, thread hijacking branching out to politic and religious discussions seen at rec.avatiation newgroups! Hai Longworth |
#73
On Sun, 08 Jan 2006 05:02:33 GMT, George Patterson
wrote: In the absence of some catastrophe, such as a bent pushrod, this is generally caused by not flying enough. The layer of hardened steel on a camshaft is fairly thin. Let the plane sit long enough, and rust will form. When the engine starts again, the rust is worn away, making the thin layer of hardened steel thinner. The worst wear points, of course, are the tips of the lobes. Once the hardened steel wears through, the softer steel underneath goes pretty rapidly. The automotive world tried out roller lifters a long time ago. They would work fine in aircraft engines too. I've heard that some of the engines built for the homebuilt market can and do incorporate roller lifters. I even thought I read that at least one company was intending to certify such an engine. Corky Scott |
#74
wrote in message news ![]() On Sun, 08 Jan 2006 05:02:33 GMT, George Patterson wrote: In the absence of some catastrophe, such as a bent pushrod, this is generally caused by not flying enough. The layer of hardened steel on a camshaft is fairly thin. Let the plane sit long enough, and rust will form. When the engine starts again, the rust is worn away, making the thin layer of hardened steel thinner. The worst wear points, of course, are the tips of the lobes. Once the hardened steel wears through, the softer steel underneath goes pretty rapidly. The automotive world tried out roller lifters a long time ago. They would work fine in aircraft engines too. I've heard that some of the engines built for the homebuilt market can and do incorporate roller lifters. I even thought I read that at least one company was intending to certify such an engine. Corky Scott It is not uncommon to see roller rockers on round engines. |
#75
#76
"Longworth" wrote in message
ups.com... Pete, I have read and participate in r.a.s for the last few years. The newsgroup is not 'restricted' to primary students. I never said it was. Please don't put words in my mouth. It does nothing to support your point, and makes you look dishonest. [...] Any perceived problem with cross postings of on-topic subject is quite insignificant in comparison to the numerous off topic, thread hijacking branching out to politic and religious discussions seen at rec.avatiation newgroups! Your statement is quite ironic, given how this thread got hijacked into a r.a.owning issue ("engine making metal"). IMHO, that's a perfect illustration why excessive cross-posting is such a problem (never mind the divergent threads that wouldn't be on-topic in any rec.aviation.* newsgroup). Your other statements are classic slippery-slope logic. The fact is, lots of topics would be of possible interest to many if not all of the people who frequent the various rec.aviation.* newsgroups. Unfortunately for your argument, that's not justification for posting messages on those topics. Pete |
#77
Pete,
My post is in reference to several points that you made below. Regarding thread hijacking, I don't have problems with thread branching out to other topics. Using google, at least the branch was labeled Engine making metal. It is not the same as branching or hijacking to non-aviation related discussions on politics and religions. I think I have sufficiently expressed my opinion on cross postings and off-topic subject and do not wish to engage in any further discussions here to conserve bandwidth. Hai Longworth ================================================== ========================= Weather is taught to VFR primary students, why not icing? Because they have enough to learn already? Seriously though, a primary student's knowledge of icing need not extend much further than "don't fly when freezing rain is forecast". For extra credit, a short discussion of what causes freezing rain might be called for. Most icing occurs inside a cloud, and VFR pilots should not have to worry about that, or anything else that might happen inside a cloud. But more importantly (and more to the point) the r.a.student newsgroup is more about the process of learning to fly, and especially as it applies to primary students ..... Pete |
#78
Pete,
I do not wish to engage in any disputes with you. I use single quotation mark around the word 'restricted' and not double quotation mark. According to this website http://www.grammartips.homestead.com...ationmark.html " single quotation marks for words that are not actual quotations but that are being set off for some other reason" I just simply expressed my opinion that Jim's post is appropriate in rec.aviation.student group. Hai Longworth |
#79
oups.com... Pete, I do not wish to engage in any disputes with you. That clearly is false. I use single quotation mark around the word 'restricted' and not double quotation mark. Well, if there were some official specification that prohibited the use of single quotation marks for quotation here on Usenet, that might make a difference. In any case, whether you are literally quoting or simply mischaracterizing what I wrote, it's "putting words into my mouth". According to this website http://www.grammartips.homestead.com...ationmark.html " single quotation marks for words that are not actual quotations but that are being set off for some other reason" Wonderful. When you get that standard to be the official policy on Usenet, you let me know. I just simply expressed my opinion that Jim's post is appropriate in rec.aviation.student group. No, you did more than that. Pete |
#80
Nice tap dance there Pete, but she's got you cold on that one!
Suggest you stop blaming her for your misinterpretation of what she wrote. -- Cheers, John Clonts Temple, Texas N7NZ |
| Thread Tools | |
| Display Modes | |
| ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 06:20 PM |
| NASA chokes again | Jay Honeck | Piloting | 20 | May 2nd 05 02:43 AM |
| NASA Icing Course | [email protected] | Piloting | 3 | December 28th 04 06:18 PM |
| About Acellerated Courses for Private | Dudley Henriques | Piloting | 137 | July 22nd 04 05:21 AM |
| FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 08:44 PM |
