How long to keep VOR check records?
Old March 30th 04, 09:53 PM
muzz
If there are more than one owner of the aircraft, you need to keep it
in a place accessable by all partners. We have a small spiral notebook
we keep in the glove compartment that we log VOR checks in.
On Tue, 30 Mar 2004 20:11:15 GMT, "John R. Copeland"
"Roger Halstead" wrote in message news
On Tue, 30 Mar 2004 05:15:08 GMT, (Ross
Oliver) wrote:
So here's a question I had never thought of until getting my
instrument rating and owning an IFR-equipped aircraft: how long
should records of VOR checks be retained? Do they need to be
retained at all? Can the FAA come to me and ask, "Remember that
IFR flight to SLO you made 2 years ago? Show us the VOR check for
that flight."
You don't have to keep them that long... Year as I remember, but why
not put them in a line in your log book instead of creating forms.
Them you'll always have them.
Just put the required information in the remarks section. It makes
the record keeping much simpler. You can still keep a formal record
if you wish. Thing is you don't have to do them every 30 days. You
only need a current check if flying IFR.
I don't bother with mine unless I have a flight coming up and then
just make sure they are current.
Roger Halstead
This came to mind because the next VOR check entry will fill up
the form I have been using, and I'll have to start a new one. So
I have to decide whether to discard the filled sheet, or save it
somewhere. Is there any value to saving these with the aircraft
maintenance records?
Happy landings,
Ross Oliver
There's no valid argument *against* keeping the VOR checks in your
pilot logbook, but I just feel my personal logbook is an inappropriate
place to keep records belonging to the airplane.
FWIW, my Apollo CNX80 and its companion SL30 NavCom
both have internal storage for their most-recent VOR-check data.
I no longer need to fill out the pencil-and-paper records I used to keep
in my supplemental flight manual.
That strikes me as a much more convenient approach to record keeping.
I expect to see that idea used more widely, if the requirement persists.
I personally feel the VOR check is a kind of dinosaur-like requirement.
---JRC---
Old March 31st 04, 01:22 AM
Bill Zaleski
I operated a certificated avionics repair station for years. When we
performed a VOR calibration, at the owners request, which qualifies
for the 30 day check, it was a maintenance function and required the
417 documentation. FAR 91.171 (a) (1) is the reference. Both the
words maintained and inspect are used there. I said that it is a
maintenance record, not maintenance, as far as a pilot performed
function. My comment only referred to the fact that it does not have
to be in the aircraft. There are actually 6 ways to perform the
"check", 5 of which can be done by the pilot.
On Tue, 30 Mar 2004 15:40:07 -0500, "Barry" wrote:
FAR 91.417 (b) (1) says you must keep the record for 1 year or until
the work is repeated. A VOR test is actually an inspection and is
considered "work". Where you keep it is up to you. It does not need
to be in any particular place or location. It does not need to be in
the aircraft either. It is a maintenance record.
This is the first time I've heard anyone claim that the VOR check is
considered maintenance. Do you have a reference for this interpretation?
If a VOR check is considered maintenance, then we're in trouble (except for
the pilots who also have an A&P), because VOR check is not on the list of
preventive maintenance items given in Part 43, Appendix A. So if it's
considered maintenance, but not preventive maintenance, most pilots would not
be authorized to perform it.
There are several other factors that indicate a VOR check is not maintenance:
- FAR 91.171(a)(2) uses the word "checked," not "inspected," for the 30-day
checks we're discussing here.
- FAR 1 defines maintenance to include "inspections", but not "checks".
- FAR 91.171(d) specifies record-keeping requirements that are different from
those in 91.417 and 43.9 (no certificate number, for example). If the VOR
check is an inspection, then you'd also have to comply with 43.11 and include
aircraft total time in service, and the statement "I certify that this
aircraft has been inspected ..."
It seems clear to me that the VOR check is not maintenance, and thus not
subject to the requirements of 91.417.
Barry
Old March 31st 04, 05:57 PM
Otis Winslow
I have pages in a notebook in the plane for VOR checks. That way I
have a record of how the VOR has been over a period of time. There's
quite a few lines on each page .. no not much space to keep them
for a while.
"Ross Oliver" wrote in message
that flight."
Happy landings,
Ross Oliver
Old April 1st 04, 03:02 AM
Ross Oliver
One of the elements required by the FARs is the signature of the person
who performed the check. How do you satisfy this requirement?
Old April 1st 04, 03:58 AM
John R. Copeland
"Ross Oliver" wrote in message =
I no longer need to fill out the pencil-and-paper records I used to =
keep
=20
=20
One of the elements required by the FARs is the signature of the =
person
=20
By entering my name in the "Name" data fields of the records.
FAR 91.171 requires the person making the operational check
to "sign the aircraft log or other record."
Evidently, the Apollo people feel that the data-entry of a name
is satisfactory in lieu of a longhand script signature.
---JRC---
Old April 1st 04, 04:27 AM
McGregor
I keep a hardbound log book (airframe) in the cockpit just for recording the
day's flight info. Before take off I write down:
Date Departing Airport Oil Level VOR checks
Makes for a nice catelogue of flights, a great way to watch oil consumption
and a handy place to put VOR checks.
that flight."
Happy landings,
Ross Oliver
Old April 1st 04, 04:52 AM
Travis Marlatte
What trend do you see? I've never had a VOR not check within specs but the
only trend I would care about is the first time it doesn't. To the avionics
shop we go...
Travis
"Otis Winslow" wrote in message
for a while.
that flight."
Happy landings,
Ross Oliver
Old April 1st 04, 12:43 PM
Dan Thompson
I can't think of a reason to keep them after they have been superceded. A
post-it note that you throw away with each new check, or fill up with 3-4
checks then start a new one, would be perfectly adequate. The record
requirement for VOR checks is kind of an anachronism, really.
for a while.
that flight."
Happy landings,
Ross Oliver
Old April 8th 04, 09:33 PM
Teacherjh
The record
How so? (I take it "anacrhonism" here means something that once was valid or
useful, and no longer is, but still must be done)
Jose
(for Email, make the obvious changes in my address)
Old April 9th 04, 03:31 AM
Dan Thompson
Well, since practically everybody uses GPS, and radar coverage is
essentially nationwide now, making sure your VOR is accurate within a couple
of degrees every 30 days, and also keeping a detailed record of that, seems
a bit out of date. Kind of like making sure your buggy whip is in good
condition every 30 days.
"Teacherjh" wrote in message
The record
or
Jose
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
Simpy One of Many Stories of a Time Not So Long Ago Badwater Bill Home Built 40 March 16th 04 06:35 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
