Advice on landing lights?
Old January 13th 06, 04:15 PM posted to rec.aviation.homebuilt
Default Advice on landing lights?
We're looking at installing landing lights on our Rans S6S. The ones offered
by Aircraft Spruce are a bit big, about 5" diameter. I'm trying to find
something a bit smaller but equally effective. Does anyone here know what
(if any) requirements a landing light has, such as beam angle, width,
brightness etc??
The Hella Micro DE Xenon looks like a really interesting option. Less than
3" diameter, low power (35W) but very high light output and resilient to
vibration. See:
http://www.hella.com/produktion/Hell...o_DE_Xenon.jsp
Anyone used this? Good or bad? Any alternatives that are equally small and
effective?
Thanks!
Rob
Old January 14th 06, 04:23 AM posted to rec.aviation.homebuilt
I know that the XV-36 light offered by XeVision at
http://www.aerovisions.com/pic/XV-36-SL-new.jpg will meet the FAA
requirements for brightness and light pattern. It uses the D1S bulb xenon
arc bulb which is better than the D2S commonly used in automobiles since it
has the starting ballast integrated into the base of the bulb. This means
that you don't have to run the 20kV starting pulses through cables from the
power supply to the lamb. It uses the PAR36 (parabolic reflector) design
form which is a 4 5/16" diameter bulb. Thhis is the same as the common
GE4509 type incandescent bulb used in many, many aircraft. There is a
35watt and a 50watt version available. The 35watt is plenty, and will put
out many times the useful light of a PAR36 incandescent bulb. The bulb will
run much cooler than an incandescent, to boot! Actually, the 35watt and the
50watt both use the same bulb. They just drive it with more power for the
50watt version. This will obviously shorten bulb life. They advertise 2000
hours of bulb life with the 35watt version. This should last for years and
years in the typical aircraft in which the landing light is not used
continously. But with this long lift I would use it all the time for
enhanced collision avoidance. They also offer the XV-23 which is only 2.3
inches high and is rectangular, also 35 or 50 watt. All of there light come
in both landing light pattern or taxi light pattern. The landing light
pattern is a more narrow beam and the taxi light is spread out for a wider
illumination area. These lights are not cheap, about $550 through places
like Aircraft Spruce, but you get what you pay for. I think I saw a xenon
arc light offered by Chief Aircraft for about $350 but found out that the
lens and reflector is plastic. The Xevision light has a "real" glass lens
and a metal reflector. I spoke with the guy that makes the lights and
distributes them through XeVision, Aircraft Spruce, etc. He knows his
stuff. He also is a Glasair pilot. The usual disclaimer: I have nothing
to do with the sale of this light. I am just offering information about
what I found to be the best non-incandescent lamp available for aircraft.
"Rob Turk" wrote in message
news:AmQxf.3664$zc1.3603@amstwist00...
offered by Aircraft Spruce are a bit big, about 5" diameter. I'm trying to
find something a bit smaller but equally effective. Does anyone here know
what (if any) requirements a landing light has, such as beam angle, width,
brightness etc??
vibration. See:
effective?
Thanks!
Rob
Old January 14th 06, 05:39 PM posted to rec.aviation.homebuilt
"Harvey Spencer" wrote in message
news:%0%xf.6967$CV.2345@dukeread03...
Who is the actual manufacturer of the bulb itself? The person or company
that actually fabricates them from raw materials and sells them in box lots?
Old January 14th 06, 06:08 PM posted to rec.aviation.homebuilt
A potentially new vendor adds his voice! "-))
Old January 14th 06, 06:23 PM posted to rec.aviation.homebuilt
Why not? $500 a bulb sounds a bit like a rip-off to me.
"john smith" wrote in message
lots?
Old January 14th 06, 08:30 PM posted to rec.aviation.homebuilt
"RST Engineering" wrote in message
lots?
One of the vendors for this is Philips. See:
http://www.eur.lighting.philips.com/...cts_xenon.html
Rob
Old January 14th 06, 08:33 PM posted to rec.aviation.homebuilt
[SNIP]
These lights are not cheap, about $550 through places like Aircraft Spruce,
but you get what you pay for. I think I saw a xenon arc light offered by
Chief Aircraft for about $350 but found out that the lens and reflector is
plastic.
Thanks for all the details, Harvey. I had looked at XeVision but found the
price kinda steep. The Hella ones sell for about $350 each and are a bit
smaller. Unfortunately they are usually offered in pairs ($699) for car
owners.
Rob
Old January 14th 06, 08:41 PM posted to rec.aviation.homebuilt
lots?
Another one is General Electric (www.gelighting.com). A search on Google
also turns up many manufacturers in the Pacific Rim area...
Rob
Old January 14th 06, 08:57 PM posted to rec.aviation.homebuilt
This is for a HID with the starting ballast and power supply built into the
bulb, so you don't have any expensive power supply to buy, right? If you
can hook a 12 volt line to the bulb, and take off, then that sounds like a
bargain. (if that is all you need)
Jim in NC
Old January 14th 06, 11:11 PM posted to rec.aviation.homebuilt
"Morgans" wrote in message
bulb, so you don't have any expensive power supply to buy, right? If you can
Since you must effectively buy a brand new ballast and power supply every
time you need a new bulb, it somehow seems (to me at least) to fail the
"bargain" test.
Vaughn
Landing Light SOP kristoffer-m20j Piloting 94 November 4th 05 03:36 AM
"bush flying" in the suburbs? [email protected] Home Built 85 December 28th 04 11:04 PM
Slip to landing on PPG practical test Roger Worden Soaring 56 November 11th 04 09:38 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
Landing Gear Lights-Need Wiring Help BG Home Built 2 August 16th 03 11:21 PM
