Coming back from KCOS to 00V today several aircraft were in the
pattern for runway 33 and some people wanted runway 15 since the winds were at the changeover point. With one or two at the runup area for runway 15 I just went east until the fiasco was sorted out (I made several position reports since people were all over). Once that happened I announced my intentions (enter left downwind for 15) about 7-8 miles out and not long after that a Cirrus announced he was 10 miles out. When I was on left downwind the Cirrus pilot broadcast that he was on about 4 mile base for 15. I "assumed" he meant downwind. Then when I was about to turn base he called out four mile FINAL for 15. I saw a plane in that area and turned base (calling it out by radio of course) He asked if I was cutting in front of him and I stated "Looks like it." Soon thereafter I decided that I was too fast so went around then when on downwind again stated that his (Cirrus "pilot") pattern entry was bad. His response was "I called it out." I told him that it was not good when other planes are using a standard pattern. Had he been the only one around I would not have cared. Thus my assessment is that Cirrus pilots have too much money and inadequate pilot skills/common sense. Other fatal crashes just add to this perception. Ron Lee |
Ron Lee wrote:
Thus my assessment is that Cirrus pilots have too much money and inadequate pilot skills/common sense. Other fatal crashes just add to this perception. A problem with your extrapolation from this single data point is that I know someone that has similarly poor pattern behavior but who is a 182 owner. - Andrew |
"Ron Lee" wrote in message ... Coming back from KCOS to 00V today several aircraft were in the pattern for runway 33 and some people... major deletion ...ey and inadequate pilot skills/common sense. Other fatal crashes just add to this perception. Ron Lee ...and you, of course, did nothing wrong???? |
"Ron Lee" wrote in message ... /////// He asked if I was cutting in front of him and I stated "Looks like it." Proper response: 'Using recommended proocedure.' Ron Lee |
Ron, a serious question here. I appreciate good judgement when you
chose to go around being too fast somewhere on final, but would you say a few words as to what might have set up that circumstance? Was it a short runway, or was someone slow getting off the active, or did you just come in too hot to put enough spacing between you and the Cirrus? |
"Ron Lee" wrote in message ... Coming back from KCOS to 00V today several aircraft were in the pattern for runway 33 and some people wanted runway 15 since the winds were at the changeover point. With one or two at the runup area for runway 15 I just went east until the fiasco was sorted out (I made several position reports since people were all over). Once that happened I announced my intentions (enter left downwind for 15) about 7-8 miles out and not long after that a Cirrus announced he was 10 miles out. When I was on left downwind the Cirrus pilot broadcast that he was on about 4 mile base for 15. I "assumed" he meant downwind. Then when I was about to turn base he called out four mile FINAL for 15. I saw a plane in that area and turned base (calling it out by radio of course) He asked if I was cutting in front of him and I stated "Looks like it." Soon thereafter I decided that I was too fast so went around then when on downwind again stated that his (Cirrus "pilot") pattern entry was bad. His response was "I called it out." I told him that it was not good when other planes are using a standard pattern. Had he been the only one around I would not have cared. Thus my assessment is that Cirrus pilots have too much money and inadequate pilot skills/common sense. Other fatal crashes just add to this perception. Ron Lee Few things bother me more than someone who comes barreling through the pattern, expecting the sky to miraculously clear before him. My home field is fairly busy on weekends and there is *always* someone who thinks his time is more valuable than everyone else's and pulls this kind of stunt. Unfortunately, there isn't much you can do, unless you want to call the other guy out on the radio or do something really stupid like genuinely crowd him in the pattern... Beyond that, we get our share of turbine traffic. It appears that part of the training for flying a kerosene burner is that you are *required* to land straight in, no matter how many airplanes are in the pattern. KB |
Kyle Boatright wrote:
It appears that part of the training for flying a kerosene burner is that you are *required* to land straight in, no matter how many airplanes are in the pattern. Well, they pretty much are required to do that. It's safer to come straight in than to try to land using the large pattern they would have to fly. You sure can't fly the same pattern in a Citation that I can in a Maule. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
I got landing clearance once, 'Cessna 1234Z clear to land, short approach,
Hawker traffic five mile final'. 'Unable, continuing downwind' sure, could have cut the throttle, dropped the flaps and swooped in real tight, but it really isn't worth the minute or two saved to get bunched up. Just relax and watch the jet traffic go by. "George Patterson" wrote in message news:dtjyf.12314$sq.10452@trnddc01... Well, they pretty much are required to do that. It's safer to come straight in than to try to land using the large pattern they would have to fly. You sure can't fly the same pattern in a Citation that I can in a Maule. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
inadequate pilot skills/common sense. Other fatal crashes just add to this perception. What you are seeing isn't anything specific to the Cirrus. Jerks are jerks. Rich jerks with high performance planes are dangerous. Rich jerks flying high performance planes too infrequently are disasters waiting to happen. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Sort of like SUV owners. I once had a plane fly under me and land when
I was a mile from touch down at Bader, Atlantic City. Just turned to the left and went around again. Homo sapiens is generally a very foolish species. |
| Lancaster California: Another Fatal Cirrus Crash | Larry Dighera | Piloting | 63 | March 31st 06 10:34 AM |
| Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 06:58 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| Another Cirrus crash | James L. Freeman | Piloting | 42 | April 25th 04 12:21 AM |
| Cirrus SR20 Fatal Crash in SC | Richard Kaplan | Piloting | 24 | April 22nd 04 11:47 AM |
