PC flight sim for training?
Old January 16th 06, 08:21 PM posted to rec.aviation.ifr
Default PC flight sim for training?
On 01/16/2006 12:10 PM, Denny wrote:
This is an old thread I stumbled across... Wanted to mention ASA's, ON
TOP, IFR proficiency simulator... I also have FS2004Pro, but I prefer
the instrument panel that ON TOP has...
Besides, this is IFR practice, why are we rating sims on how realistic
the scenery is?
Anyway, I fly IFR in an old Apache, which is not on either sim, so I
simply dial up a Bonanza or a Baron and use that... And I do not have a
yoke, just use a joy stick... I do not notice the differences when
getting in the real airplane... My reflexes are geared to accomodate
the cockpit I'm in at themoment... It is procedures that need
repetition, not power settings, joy stick versus yoke, etc...
cheers ... denny
The problem I have with the simulators (I use MS FS 2004) is that
the yoke doesn't really represent the trimmed-out speed of the airplane
(in that if you let go of the yoke/stick, the airplane will do what it
is trimmed to do).
As a result, I spend a lot of time getting the trim set to the point
where the attitude will remain relatively constant. This can be really
irritating when changing configuration (like when entering a holding
pattern after cruise flight).
I wonder if there is a way to tell the simulator to manage the trim
a little better? I've looked some ... need to look more.
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old January 16th 06, 08:45 PM posted to rec.aviation.ifr
On 1/16/2006 2:21 PM, Mark Hansen wrote the following:
ASA's IP Trainer does not do it. Elite doesn't do it. PFC yokes do feel pretty
reak-world, though, unlike the cheapies.
I have had some time in a Frasca and in it, too, pitch control was a PITA. I've
been told that pretty much all simulators are bad at this.
Old January 16th 06, 08:47 PM posted to rec.aviation.ifr
the scenery is?
Because at some point you pop below the layer and land visually? ;-)
Peter
Old January 16th 06, 08:59 PM posted to rec.aviation.ifr
"Mitty" wrote in message ...
Yes.
I've logged time in the old WW2-era, vacuum-driven Link Trainers.
They were easy to hate, too, for the same reason.
Old January 16th 06, 09:03 PM posted to rec.aviation.ifr
Simulators are designed to not fully trim to a stable
a/s-heading, the design parameter is to make the pilots fly.
If you can fly a simulator, whether it is a basic PC based
software job or a $10,000,000 full motion, full visual state
of the art jet, the airplane will be easy.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Mark Hansen" wrote in message
mention ASA's, ON
how realistic
| the scenery is?
either sim, so I
I do not have a
differences when
to accomodate
need
etc...
| cheers ... denny
is that
the airplane
will do what it
| is trimmed to do).
the point
can be really
a holding
the trim
| Sacramento, CA
Old January 16th 06, 09:04 PM posted to rec.aviation.ifr
That makes them better trainers, you have to scan and fly
all the time.
manage the trim
Old January 16th 06, 11:51 PM posted to rec.aviation.ifr
the scenery is?
cheers ... denny
is trimmed to do).
It's been a while since I've used my copy of On Top but there is a
feature called 'auto trim' that I map to one of the buttons on the
joystick. (That's the way I remember it, anyway.) I put the nose where
I want it, press the button, and it's trimmed. Let's me focus on the
things that I need to practice.
Tom
Old January 17th 06, 05:21 PM posted to rec.aviation.ifr
is trimmed to do).
I prefer a simple gamepad-style controller for my IFR sim. The left
thumb is the joystick for elevator and aileron. The right thumb uses
the four buttons which are set for throttle-increment,
throttle-decrement, elevator-trim-increment, and
elevator-trim-decrement.
This works well for me in MSFS and X-Plane. Doesn't work in OnTop or
IPTrainer because they use their idiotic non-standard drivers which are
not nearly as flexible nor reliable.
Turn turbulence way up to improve your scan. Add thunderstorms for
pretty visual effects.
Cheers,
John Clonts
Temple, Texas
N7NZ
Old January 19th 06, 05:27 AM posted to rec.aviation.ifr
I've got over 30 hours in the Frasca and have never had problems
setting the trim. In fact one of the instructors (I've taken the
courses at the local college) used to chide me for flying entire
practice sequences (45 minutes) with nothing but the trim for
everything other than the takeoff.
We've got 4 ATPs (is that the right company?) but I haven't
had a chance to use those yet. They're for the multi students.
I've got FS2002 and have never been able to get trim to work
properly.
Old January 29th 06, 09:54 PM posted to rec.aviation.ifr
pretty
I've
f0r MS FS2004 take a look at the following from NG
alt.games.microsoft.flight-sim
It's not real but it seems to vastly improve the time it takes to trim.
RealTrim 0.9
http://library.avsim.net/search.php?SearchTerm=realtrim-0-9.zip
RealTrim is a Microsoft Flight Simulator 2004(tm) Module. Activated via
key-press it converts the current elevator deflection into trim as the
sim-pilot moves the yoke forward or backwards. This maps closely to
trimming an airplane in real-life where pressure on the elevator felt
through the yoke is trimmed out by the pilot operating a trim wheel. As
the sim-pilot smoothly moves the joystick into neutral position,
RealTrim automatically adjusts the elevator trim so the airplane stays
in its current pitch configuration. This mechanism is superior to
moving the joystick into neutral while tapping a trim-key or moving a
trim-axis. That's because moving the joystick's axis and modifying trim
are not linked to each other and especially difficult in the case of
tapping a trim-key.
Filename: realtrim-0-9.zip
License: Freeware, limited distribution
Added: 24th January 2006
Author: Nils Meier
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 07:47 AM
