Delorme Earthmate GPS for Aviation?
Old January 20th 06, 05:17 PM posted to rec.aviation.piloting
Default Delorme Earthmate GPS for Aviation?
I recently bought the Delorme Earthmate GPS and mapping (street map)
software for $100 and was tremendously satisfied with its capability.
It runs on a laptop and has all kinds of functions useful for driving.
I was wondering if there is a compatible software for aviation use.
Old January 20th 06, 05:32 PM posted to rec.aviation.piloting
On 20 Jan 2006 08:17:35 -0800, "Andrew Sarangan"
wrote in om::
http://www.gpspilot.com/products/fly.shtml
Fly: Dynamic pre and in-flight navigation tools $69.95 BUY NOW
Aviation enthusiasts, prepare dynamic multi leg flight plans and use
them while flying. Make flight plans based on POIs -airports,
navaids, cities,... - and get automatic calculation of headings,
winds, time and fuel!
In the air, connect a GPS and follow your course on maps and legs with
automatic recalculation of heading, destination,...
Minimum : Palm OS 3.5 minimum (high resolution screen support)
For GPS navigation assistance: NMEA GPS support (Build in, Blue tooth,
Compact Flash, Memory stick, Clip-on, or external devices)
For on-line cartography: Smartphone, wireless connection, land modem
or PC-Internet gateway (MocchaPPP, SoftickPPP)
http://www.teletype.com/pages/suppor...rme_compat.htm
Can I use DeLorme Tripmate and Earthmate GPS receivers?
Yes, but these receivers are not recommended. We don't recommend
DeLorme receivers since they have no backup battery they often take
long periods of time to lock in. We especially discourage the use of
DeLorme receivers for use in aviation. See specific information below
on how to initialize the DeLorme receivers.
Old January 21st 06, 03:02 AM posted to rec.aviation.piloting
works great. used the blue logger and the earthmate without problems.
Michelle
NavGPS Pro + PC EFIS.
Old January 21st 06, 03:44 AM posted to rec.aviation.piloting
And you can create and download POI databases at
http://navaid.com/GPSPilot/
Paul Tomblin http://xcski.com/blogs/pt/
I forsee one of those "open your wallet and repeat after me,
_help yourself_" moments in your local friendly workshop.
-- Tanuki
Old January 21st 06, 02:44 PM posted to rec.aviation.piloting
We've tried using it in our plane, but discarded the notion simply because
the lap-top was too big to put anywhere. It ended up on the co-pilots lap,
which is NOT a very handy place.
Our Compaq's screen was not sunlight-readable, either.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 22nd 06, 11:42 AM posted to rec.aviation.piloting
"Jay Honeck" wrote in message news:gVqAf.722239$_o.395653@attbi_s71...
lap,
When I'm flying alone (which is most of the time), I use Delorme Street
Atlas hooked to a non-aviation 12-channel GPS... Works great... Although I
have newer version of Street Atlas, I prefer an older version (v6, I
believe) because it has a cleaner interface... It seems to have all the
airports in it, even the smaller private strips... If I'm really wanting to
fly an accurate path, I'll use it to draw a line on the map and then zoom in
quite a bit so that the path is actually acting like a CDI... I have Street
Atlas log my path to a file and I then input that into the logbook program
that I wrote...
If Grace is flying with me, she usually like having the laptop in her lap
since it acts as a lap warmer... She's a bit cold natured, I guess...
That's a problem with my laptop also... If I have it on external (AC) power,
the display is brighter, but it's still difficult to read in bright
sunlight... At night, it needs dimming, but that's not possible so I just
close the cover and only open it every few minutes...
I've had bad luck over the years running a DC-AC inverter in my aircraft --
it tends to run the battery down... So, if I'm going to be on a flight
longer than the battery time on my laptop, I'll bring a small deep cycle
battery with me and just run it off of that instead...
GPS BlueTooth w datalogger (Earthmate Blue-Logger by DeLorme) Jeffrey Banks Soaring 0 November 17th 05 02:30 AM
