I'm wondering if there's a simple or straightforward way to test an SLA
battery for general condition. Or a device I can buy that sucks a charge out of a battery over a few hours and reports its actual amp-hour capacity? ~ted/2NO |
Google ELK and battery tester. Elk makes one that measures the internal
conductance of the battery in mhoes. My company uses them to test customer's batteries with good results (alarm company). bumper wrote in message ups.com... I'm wondering if there's a simple or straightforward way to test an SLA battery for general condition. Or a device I can buy that sucks a charge out of a battery over a few hours and reports its actual amp-hour capacity? ~ted/2NO |
The cheapest way to measure the battery health is to put a load similar to
what you will be using and time how long the voltage is adequate to operate your equipment. you do not have to be a techie to do this - just a simple understanding of ohms law. Depending upon the size of the battery and the battery current you wish to draw, an example that we will use would be a Radio Shack 20 watt, 8 ohm resistor catalog number 271-120. Current draw is calculated by using ohms law: I (current in amperes+ = E (voltage) / R (resistance). In our example, I = 12 / 8 = 1.5 amps. Power consumed would be P = EI = 12 x 1.5 = 18 watts. That means the load resistor will get hot under test, so keep it away from things that will melt. Make sure there is good circulation around it. Take a cheap digital voltmeter (expensive ones will work) and monitor the voltage from time to time. Be sure to note the time you start the test. Stop the test when the voltage gets down to the lowest voltage you can use in your aircraft. Let us say you start the test and 4 hours later the voltage gets down to 10.25 volts and you terminate the test. You will have drawn 6 amps out, so you now have a 6 amp battery. Often batteries are rated to go down to a lower voltage than you wish to operate them at, so the new amp rating may not be as much as advertised. If you are really cheap, you can use an automobile headlamp or taillamp and hang it on the battery and just watch how long it stays bright. You will have to know how much current is drawn, which you can sometimes look up in a database, or measure with an ammeter. When doing tests like this, a little math gets you a long ways. This is a somewhat simplified explanation, since the actual current drawn depends upon the voltage and as the voltage drops down, the current draw will decrease - but that is the same thing that will happen in your aircraft. Colin N12HS |
I did a lot of battery testing years ago. My PC was set up to sample
and plot voltage and current as the battery discharged into a resitive load. It was easy to see a battery was good. It was easy to see a battery was bad. It did not help me predict when a good battery would become a bad one. Try searching this group, it's been discussed before. Andy |
Atthough I mentioned a simplified method of battery test, once you
understand the procedure, you can measure the battery voltage under load and after the initial few seconds, you can plot the discharge voltage vs time. So, if in five minutes, the voltage drops .03 volts, we know the voltage drop is linear, so in 60 minutes the voltage will drop 12 x .03 or .36 volts. As Andy mentioned, it can be computerized. Interestingly, the ability to hold a charge also means the resistance to change. So, if you see a battery on the shelf and put a charger to it and the voltage soars instantly to full voltage, it is bad. Once you understand what is happening, you can usually tell if a battery is good within a few seconds, and know the projected life in a minute or less - all with minimum equipment. A lttle knowledge gets you a long way. In fact, you can often hang a auto lamp across the battery with a digital voltmeter and watch the voltage drop. The less drop, the better the battery. Colin |
I have had been very happy with the CBAII computerized battery analyzer
from Westmountainradio.com. Click the RC Model Products button on the left of the page. It runs abou $100 and hooks to a PC to plot discharge curves. They also offer the whatthour meter which provides load information. More expensive solutions than some others suggested here, but very convenient and easy to use. |
"COLIN LAMB" wrote in message ink.net... In fact, you can often hang a auto lamp across the battery with a digital voltmeter and watch the voltage drop. The less drop, the better the battery. That is exactly how I have been doing it for years, and I have never found a need for anything more fancy. For small gel cells, (as are used in gliders) I use a digital voltmeter and a 50-watt sealed beam light. For larger batteries, I use a commercial load tester that you can buy at NAPA or any similar auto parts store for about $50.00 US. Vaughn |
Vaughn wrote:
"COLIN LAMB" wrote in message ink.net... In fact, you can often hang a auto lamp across the battery with a digital voltmeter and watch the voltage drop. The less drop, the better the battery. That is exactly how I have been doing it for years, and I have never found a need for anything more fancy. For small gel cells, (as are used in gliders) I use a digital voltmeter and a 50-watt sealed beam light. For larger batteries, I use a commercial load tester that you can buy at NAPA or any similar auto parts store for about $50.00 US. It sounds like you are effectively doing an internal resistance measurement. Do you have chart of volt drop, load, and good/ok/bad decision for various size batteries? I've not seen that sort of thing in battery data sheets, so I assume you have to develop the numbers empirically. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| Battery Question | [email protected] | Soaring | 19 | September 15th 05 02:38 AM |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| 14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 02:37 AM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 07:32 PM |
