#51
Morgans wrote:
If you go too long with pain and numbness in your foot, or any other part, even if the surgery is done and is successful, the pain and numbness can become a permanent thing. Thanks for that info. My numbness is erratic, and I can usually hold it at bay with my exercises. I wondered at times if I was running some risks of damage elsewhere. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#52
What did you teach Vince?
I taught courses on the economics of communications, in the College of Communications. Occasionally a course for the economics department, when it was short-handed. vince norris |
#53
![]() "Matt Whiting" wrote The artificial disk unit has essentially a partial titanium vertebrate on each side of the polymer disk. This is glued (maybe also screwed, I don't know) to the OEM bone vertebrate much the way artificial hips and knees are put in. That sounds like a new technology disc, than the ones I looked at a couple of years ago; they just sat in there, held in by the surrounding soft tissue. That isn't surprising; medical tech move at a very fast rate. In this scenario, I'm not sure why they couldn't break apart a fused area, but maybe it is simply too aggressive a procedure to do with the spinal cord in the middle. I would think the amount of bone added in the fusion is the biggest factor. Basically, all the space that the normal disc occupied, is filled with bone, now. That would be a lot to remove, especially like you said, right next to the spinal chord. -- Jim in NC |
#54
Gentlemen~
Listening to you folks is like reading my diary! Numb right foot with exteme tingling, pain from the butt to the big toe (but no back pain) and one surgery that did very little to remedy the situation. The next recommended step is fusion. I'm not biting! Just missed a segment on TV describing a non-invasive new treatment for the situation! I haven't found it yet but will continue to look. Best of luck, Vince |
#55
I'm just a 3350 guy (AC-119K).
--Walt Weaver Bozeman, Montana |
#56
A few years ago I toured the Garber Facility in DC. They were in the middle
of restoring an original Newport that Cole Palen had donated after using it for years at Rhinebeck. When they cut off the fabric, the entire tail fell off! The fabric was all that was keeping it on. Must have been really interesting there in the early days. -- Bob (Chief Pilot, White Knuckle Airways) "Dudley Henriques" wrote in message ink.net... The old days at Rhinebeck when the Cole Palen crowd were there are remembered by many who frequented the place. The nostalgia of that operation during those days ranks right up there with Pancho's out at Edwards. Both places bring back some of the finest "just hanging out" moments in aviation history in the United States. I seem to remember some trouble going on there a few years back concerning the running of the operation by a new board of directors at the museum but I don't have a real handle on what it was all about. Propping a Le' Rhone might have been a job for Arnold Swartzenegger at that :-))) Dudley "George Patterson" wrote in message news:TISzf.1495$id.1100@trnddc04... Dudley Henriques wrote: Are you kidding George? A saw some guys try to start a Camel once at Rhinebeck. They went through the rigamarole of pulling it through and then Hercules (we'll call him) started flipping the prop. It wouldn't even backfire. The poor guy rocked that prop through about 20 times or so. When he was worn out, another fellow came up to try his luck. He rocked up on one leg and whipped the prop down and the engine fired right up. Hercules was ready to beat the guy to death! George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
#57
In article .com,
" wrote: I'm just a 3350 guy (AC-119K). Walt, tell us some stories! |
#58
Dudley
Guess you never flew the P-80 A/B? The boost pump was the main fuel pump from the P-59. Was a monster that pulled something like 20+ amps. Once you got an indication of TPT you used both hands and pulled the throttle back just into edge of idle cut off and then pushed out to the idle position. This cycling let you keep the TPT from exceeding limits as engine spooled up to idle. As the RPM rose you reached a point where the starter dropped out and the TPT kept staying in limits without cycling the throttle and as RPM stabilized in idle you also had the idle TPT. Flying that early small engine (3850 lbs thrust), if you had to go around in the pattern it took over 20 seconds from idle to full power. Really had to stay ahead of bird in pattern. Lot of 51/47 jocks checking out had trouble with this. Shut down was easy. Let idle for a minute or two to stabilize temps and then go to idle cut off and clean cockpit up. At Willie (first jet school) we had the 'Captive Air'. This was a P-80A mounted on supports (concrete/steel) with gear not touching ground. This trainer let us put a student in cockpit and standing on wing talk him through an engine start and simulated flight. (Start engine and then cycle gear and flaps like would happen on a real flight.) Last time I was at Willie for a reunion (they then had T-38's) the Captive Air facility across the field had been torn down and not saved for posterity ![]() Been a long time since I thought about the early jets. We killed at least one student a month and a instructor every quarter at Willie when we started student jet training for Korea. Big John `````````````````````````````````````````````````` ````````````````````` On Thu, 19 Jan 2006 16:29:53 GMT, "Dudley Henriques" wrote: "Big John" wrote in message .. . Dudley Those were the good old days but we only realize it now ![]() The biggest I fired up was the R2800 (P-47D). Looking back I think I remember it sounded like a 'Harly Hog' today for those who haven't heard one start and run. Hundreds of hours behind a R1340. Big John I have a few hours in the Jug (N) and some time in the Bearcat. Preferred the 51 for show work, but the cat was a real ride coming off the deck with some excess power to convert :-)) Never flew the 4360, but I had a friend who had one in his Corsair. He used to laugh like hell when he told me that it sometimes took him more time to get it started than it did to make the flight he started it for. I've always wondered what the hell everybody thought was so damn hard about flying the jets. That little list of humor you posted is just about right on. In the T38, you climb in; push the start buttons and watch the temps rise, then you point it where you want it to go and hang on. (of course it helps if you actually HAVE it pointed where you want it to go when you hit the burners :-). You can fly the T38 all day long without touching the rudder pedals, and that includes aerobatics!! It's great to be able to look back on all that fun. :-))) Dudley |
#59
Hi John;
Never flew the P80, but I remember those early days during the transition period from props to jets quite well. The loss rates were high as a kite as you have stated. But I'll bet you'll agree that in spite of it all, Willie and Luke were the places to be in those days.:-)) Starting those early jets J33's, J47's etc really kept you guys on your toes balancing throttle and temps. Phrases like "bringing it around the horn" and "hot start" were quite commonly heard on the flight line back then and hardly heard any more. By contrast, the T38 is a "push to start" "go fast" buggy. :-) Putting a bird on a stand and running it was a great idea, although I remember the day Scott Crossfield blew the tail off the X15 at Edwards doing an engine testbed ground test on the XLR99 engine. He said it was quite funny really. They put him in the bird and everybody else went into the blockhouse. They called it "developing the confidence of the pilot" :-) When it blew, the front half of the airplane actually flew forward off the stand about 20 feet. I always said, Crossfield should have logged the time! :-)) Dudley "Big John" wrote in message ... Dudley Guess you never flew the P-80 A/B? The boost pump was the main fuel pump from the P-59. Was a monster that pulled something like 20+ amps. Once you got an indication of TPT you used both hands and pulled the throttle back just into edge of idle cut off and then pushed out to the idle position. This cycling let you keep the TPT from exceeding limits as engine spooled up to idle. As the RPM rose you reached a point where the starter dropped out and the TPT kept staying in limits without cycling the throttle and as RPM stabilized in idle you also had the idle TPT. Flying that early small engine (3850 lbs thrust), if you had to go around in the pattern it took over 20 seconds from idle to full power. Really had to stay ahead of bird in pattern. Lot of 51/47 jocks checking out had trouble with this. Shut down was easy. Let idle for a minute or two to stabilize temps and then go to idle cut off and clean cockpit up. At Willie (first jet school) we had the 'Captive Air'. This was a P-80A mounted on supports (concrete/steel) with gear not touching ground. This trainer let us put a student in cockpit and standing on wing talk him through an engine start and simulated flight. (Start engine and then cycle gear and flaps like would happen on a real flight.) Last time I was at Willie for a reunion (they then had T-38's) the Captive Air facility across the field had been torn down and not saved for posterity ![]() Been a long time since I thought about the early jets. We killed at least one student a month and a instructor every quarter at Willie when we started student jet training for Korea. Big John `````````````````````````````````````````````````` ````````````````````` On Thu, 19 Jan 2006 16:29:53 GMT, "Dudley Henriques" wrote: "Big John" wrote in message . .. Dudley Those were the good old days but we only realize it now ![]() The biggest I fired up was the R2800 (P-47D). Looking back I think I remember it sounded like a 'Harly Hog' today for those who haven't heard one start and run. Hundreds of hours behind a R1340. Big John I have a few hours in the Jug (N) and some time in the Bearcat. Preferred the 51 for show work, but the cat was a real ride coming off the deck with some excess power to convert :-)) Never flew the 4360, but I had a friend who had one in his Corsair. He used to laugh like hell when he told me that it sometimes took him more time to get it started than it did to make the flight he started it for. I've always wondered what the hell everybody thought was so damn hard about flying the jets. That little list of humor you posted is just about right on. In the T38, you climb in; push the start buttons and watch the temps rise, then you point it where you want it to go and hang on. (of course it helps if you actually HAVE it pointed where you want it to go when you hit the burners :-). You can fly the T38 all day long without touching the rudder pedals, and that includes aerobatics!! It's great to be able to look back on all that fun. :-))) Dudley |
#60
![]() Dudley Some more on that era and Willie. The Air Cadet Class of 49C (?) graduated and in 6 months half had killed themselves in operational Squadrons. This caused the Training Command to fire everyone at Willie and bring in a new group of instructors and a new Training Group Commander (Leon "the peon" Gray). The new instructors were rotating pilots from Fighter Squadrons in Far East and Europe, about 15 from each. I came in from 8th FG in Japan and was an instructor in CIS (Central Instructor School) there until all the newbe's were checked out in back seat of T-6 and picked up students. F-80/T-33 check outs were conducted in the Training Sections (#1 and #2) after finishing the days instruction with students. My good buddy from 35th Squadron in Japan gave me half a dozen touch and goes in T bird and signed me off. I then went and said I want a F-80 and they gave me one and I went and flew it. Not like the highly supervised checkouts today. The F-80C and T Birds all had the semi automatic starting system with the 'big' engine. Much easier to start and rarely a hot start unless you started with tail pointing into a strong wind. When I hit Willie, Luke had been closed and Willie sent tower operators (mobile unit) and crash crew over when we started a new class and used it for touch and goes on student check outs to relieve traffic at Willie. Korea started and they reactivated Luke and expanded Nellis. One story about Nellis, they had a snack bar on corner of ramp nearest to Runway. A student lost control of a 51 and ran into it and destroyed it. No one got hurt in the crash which was a miracle. Didn't repair but moved it to a new building on line. On Scott and engine test. As I recall they didn't have the tail on and were just running the new BIG engine to exercise the controls and give him experience operating it. Think I saw it that way taxiing by before it blew up? Lucky to have survived (with no injuries). Some bar talk about not wanting to fly that bomb ![]() Your right about Willie and the rest of those fields. Right in the middle of things. As student flow continued and losses in Korea were less than 'progged' they backed up at Willie as Luke and Nellis couldn't accept them. I helped to set up some Air to Air camera training in T-33's to keep them busy and give them a head start on air to air combat. It was fun to put them on the perch for a high side attack. Did have one or two run into the target as happened in aerial gunnery when you pushed ![]() If I haven't said, after leaving Willie went to Hamilton and ADC, F-94C (best supersonic airplane I ever flew), F-89 (all versions after 'C') and tour with Navy VF-23 (Big Banshee, F2H3)and F-101B. Enough war stories for today. My new computer (Athlon 3300 64) is running infant morality mode and so far so good. Big John `````````````````````````````````````````````````` ``````````````````````````` On Mon, 23 Jan 2006 11:06:11 GMT, "Dudley Henriques" wrote: Hi John; Never flew the P80, but I remember those early days during the transition period from props to jets quite well. The loss rates were high as a kite as you have stated. But I'll bet you'll agree that in spite of it all, Willie and Luke were the places to be in those days.:-)) Starting those early jets J33's, J47's etc really kept you guys on your toes balancing throttle and temps. Phrases like "bringing it around the horn" and "hot start" were quite commonly heard on the flight line back then and hardly heard any more. By contrast, the T38 is a "push to start" "go fast" buggy. :-) Putting a bird on a stand and running it was a great idea, although I remember the day Scott Crossfield blew the tail off the X15 at Edwards doing an engine testbed ground test on the XLR99 engine. He said it was quite funny really. They put him in the bird and everybody else went into the blockhouse. They called it "developing the confidence of the pilot" :-) When it blew, the front half of the airplane actually flew forward off the stand about 20 feet. I always said, Crossfield should have logged the time! :-)) Dudley "Big John" wrote in message .. . Dudley Guess you never flew the P-80 A/B? The boost pump was the main fuel pump from the P-59. Was a monster that pulled something like 20+ amps. Once you got an indication of TPT you used both hands and pulled the throttle back just into edge of idle cut off and then pushed out to the idle position. This cycling let you keep the TPT from exceeding limits as engine spooled up to idle. As the RPM rose you reached a point where the starter dropped out and the TPT kept staying in limits without cycling the throttle and as RPM stabilized in idle you also had the idle TPT. Flying that early small engine (3850 lbs thrust), if you had to go around in the pattern it took over 20 seconds from idle to full power. Really had to stay ahead of bird in pattern. Lot of 51/47 jocks checking out had trouble with this. Shut down was easy. Let idle for a minute or two to stabilize temps and then go to idle cut off and clean cockpit up. At Willie (first jet school) we had the 'Captive Air'. This was a P-80A mounted on supports (concrete/steel) with gear not touching ground. This trainer let us put a student in cockpit and standing on wing talk him through an engine start and simulated flight. (Start engine and then cycle gear and flaps like would happen on a real flight.) Last time I was at Willie for a reunion (they then had T-38's) the Captive Air facility across the field had been torn down and not saved for posterity ![]() Been a long time since I thought about the early jets. We killed at least one student a month and a instructor every quarter at Willie when we started student jet training for Korea. Big John `````````````````````````````````````````````````` ````````````````````` On Thu, 19 Jan 2006 16:29:53 GMT, "Dudley Henriques" wrote: "Big John" wrote in message ... Dudley Those were the good old days but we only realize it now ![]() The biggest I fired up was the R2800 (P-47D). Looking back I think I remember it sounded like a 'Harly Hog' today for those who haven't heard one start and run. Hundreds of hours behind a R1340. Big John I have a few hours in the Jug (N) and some time in the Bearcat. Preferred the 51 for show work, but the cat was a real ride coming off the deck with some excess power to convert :-)) Never flew the 4360, but I had a friend who had one in his Corsair. He used to laugh like hell when he told me that it sometimes took him more time to get it started than it did to make the flight he started it for. I've always wondered what the hell everybody thought was so damn hard about flying the jets. That little list of humor you posted is just about right on. In the T38, you climb in; push the start buttons and watch the temps rise, then you point it where you want it to go and hang on. (of course it helps if you actually HAVE it pointed where you want it to go when you hit the burners :-). You can fly the T38 all day long without touching the rudder pedals, and that includes aerobatics!! It's great to be able to look back on all that fun. :-))) Dudley |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
