Y'All,
A friend of mine wanted to get his plane from Concord CA to Auburn CA a bit early for his annual to avoid a series of storms shortly to arrive in Northern CA. He called me at 9 A. M and we were ready to depart at 11AM. We planned to make separate departures using ATC radar advisories while monitoring 122.85 if something came up. I got started out first and waited in the runup areas until my friend appeared to make my departure. We had agreed to fly below 3000' AGL. He flew at 2700 and I flew at 2900 AGL We did not tell ATC that we were together. At one point I was quired by ATC as to why I chose to fly at 2900. My response was that not very many pilots make a practice of flying such an altitude. and it becamse apparent as we encountered any number of other aircraft flying at 2000;.500 and 3000. It soon became apparent that our altlitude selection was a good idea. Between Sacramento and Auburn there was a bank of cumulus what got in the way. Since I was in front I made the choice of flying over insead of below the clouds even though the one-minute-weather out of Auburn gave bases of 1500. My choice was based upon the probability of greater turbulence below the clouds while flying into rising terrain. My friend, a few miles behind made the same choice. He had GPS while I was strickly pilotage. Things did not get much better so I advised ATC that I would descend in VFR and my friend behind did likewise. The GPS made it possible for him to do so right over Auburn but I was about three miles away to the North. Now we come to the point of my contribution. In my descent I became totally disoriented as to where to find Auburn. I immediately advised ATC that I would require vectors on descent below the clouds. I was giving a heading of 264-degrees. Usually a vector is not so precise so I quired for a repeat. He was right on. With excellent visibility 10-15 miles too low to see the airport runway but I did see the buildings, I continued on that heading. Almost immediately ATC gave me a terrain alert and a collision alert. I was at about 500'AGL and in conflict with my friend who was on downwind. I did not see him until I came out of the ATC recommended left climbing turn for avoidance. When I came out of my turn I was on left base for 25 and my friend was on final. We both proceeded to land with no problem What I am getting at is that a major block facing most pilots who get into problem situation is not knowing how or when to ask for and get help. My friend with his GPS had no problem. Pilotage alone was not going to work for me under the low ceilings so I used ATC as my 'GPS' and had no problem either. We met at the restaurant, had lunch and did the planning for the annual soon to depart back to Concord in my plane. I let him fly right seat for the experience. We probably saved him a week's delay in getting his annual. Moral: You don't need to know everything or to solve all flying problems on your own. The more you know the more willing you will be to ask for help. Gene Whitt |
Wow! Certainly goes to show that weather is something that should be
respected! I have a copy of the movie, "The Perfect Storm". I've watched it several times and am fascinated at how insignificant we can be when weather and/or the sea, in this case, decides to open up a can of whoop-@$$ on us! No matter how indestructable we think we are at times, we don't stand a chance against some of the blows mother-nature can deal. Best Regards, Todd |
your own. The more you know the more willing you will be to ask for help. Absolutely! I'm also coming to the realization that the more I learn, the more I know that I don't know anything!!! ;-) Thanks for sharing your experience! Best Regards, Todd |
"three-eight-hotel" wrote in message
oups.com... I popped up to 3,000 ft and was amazed at how hazey it was towards the west. I stayed at 3,000, and always had visual reference to the ground, although it was very hazey and I really couldn't see much at a slant-distance. Having flown this dozens of times, I knew right where I was going [...] I continued on, always making sure I could see down, and having the out to turn around as I mentioned before. It sounds like you're describing a VFR flight in IMC. Or have I misunderstood you? --Gary |
I don't think it would have been considered VFR in IMC... There were
absolutely no clouds (although clouds aren't what constitute IMC), and at 3,000 feet I had constant visual reference with the ground and never had to depend on my instruments for navigation or situational awareness. I probably had visibility of 2-3 miles through the haze, but definitely couldn't see major landmarks like Pilot Hill or Folsom lake at a distance of greater than 4 or 5 miles. To be honest, the main reason for posting was because I had finally had my first chance to fly, in several weeks, and I was stoked about getting up again, if only for a 10 minute jaunt down the street! ;-) What struck me though and gave me a more meaningful reason to post was walking outside after dinner and seeing an entirely different weather picture than I had seen only an hour ago, when I landed. There was some pretty ugly, and low clouds hiding behind that haze, meaning in a worst case scenario, It could have been 4 to 5 miles away from where I was, and I wouldn't have seen it. Best Regards, Todd |
ups.com... I don't think it would have been considered VFR in IMC... There were absolutely no clouds (although clouds aren't what constitute IMC), and at 3,000 feet I had constant visual reference with the ground and never had to depend on my instruments for navigation or situational awareness. I probably had visibility of 2-3 miles through the haze, But as you know, less than 3 sm visibility is IMC (except in Class G during the day at 1200' AGL or less), so VFR flight in those conditions is unsafe and illegal. You described being able to see things "down" but not "at a slant" in haze at 3000'. At that altitude, if you can't see prominent objects 11 degrees below horizontal, you have less than 3 sm visibility (and if you can't see prominent objects 35 degrees below horizontal--still nowhere near "down"--you have less than 1sm visibility). Even if you can manage to aviate and navigate without instruments while flying VFR in IMC, you don't have adequate means to see and avoid anyone who's legally flying IFR near you. So you're betting their lives that you won't happen to collide with them. reason to post was walking outside after dinner and seeing an entirely different weather picture than I had seen only an hour ago, when I landed. I appreciate your motivation for posting, but I think you've overlooked a far more important lesson than the one you had in mind. Regards, Gary |
Gary Drescher wrote:
: oups.com... : I popped up to 3,000 ft and was amazed : at how hazey it was towards the west. I stayed at 3,000, and always : had visual reference to the ground, although it was very hazey and I : really couldn't see much at a slant-distance. Having flown this dozens : of times, I knew right where I was going [...] : I continued on, always making sure I could see : down, and having the out to turn around as I mentioned before. : It sounds like you're describing a VFR flight in IMC. Or have I : misunderstood you? Might be, might not be. Playing the legal card here isn't helpful. As anyone who's flown in the haze can attest, the visibility of 2.9 miles vs. 3.1 miles is not something that is easily determined in flight. One is illegal, one is legal, and they are both indeterminable in flight. Was it MVFR? Sure. Was it IMC? Possibly. Remember that it's also very possibly to legally fly under VFR in legal VMC and still require instruments to control the aircraft (night, OTT with strange clouds below, etc). Unlike ceilings, visibilities are not as clear-cut in determining when the conditions are IMC vs. VMC. Chill. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
the day at 1200' AGL or less), so VFR flight in those conditions is unsafe and illegal. Agreed. You described being able to see things "down" but not "at a slant" in haze at 3000'. At that altitude, if you can't see prominent objects 11 degrees below horizontal, you have less than 3 sm visibility (and if you can't see prominent objects 35 degrees below horizontal--still nowhere near "down"--you have less than 1sm visibility). Any typical day in the Sacramento Valley is going to involve haze, except for those perfect days. I am certain that I have flown in conditions of 10, 20+, to almost unlimited visibility, where I couldn't see Mt. Diable, 90ish miles away, at an altitude that probably put it at 11 degrees below horizontal. Standing on the ground at the departure and destination airports, I can comfortably say that there was 5 sm visibility, as I was amazed at how different things could look from the ground and in the air. An un-intentionally omitted fact was that the flight occured around 4:30 p.m., which added another parameter, being the setting sun. The setting sun and haze could have likely made for poorer visibility, as I was flying East to West??? Another fact that I will humbly admit to, is that my gauge of distance probably leaves a lot to be desired. I welcome any and all comments to how people best gauge distance. I would like to know that when I report a 5 mile final, it isn't actually a 7 mile final, which I suspect I might be guilty of. I'm certainly not trying to be argumentative and appreciate your post, nor am I looking to get flamed for flying VFR into IMC, which I assure you, I would not be comfortable doing or be happy about, if I had let it occur. Even if you can manage to aviate and navigate without instruments while flying VFR in IMC, you don't have adequate means to see and avoid anyone who's legally flying IFR near you. So you're betting their lives that you won't happen to collide with them. As I said above, the visibilty on the ground, after arrival, I would comfortably call 5 miles. Although I'd feel better about stating that, if I could see a copy of the METAR for that time. Is there any way of finding METAR information for a previous day??? It would be nice to see a copy for peace of mind... I appreciate your motivation for posting, but I think you've overlooked a far more important lesson than the one you had in mind. Thanks Gary! Your point is taken! I "did" take a 10 minute flight for granted, and will no longer depend on a forecast and a pop-up and see how it feels report for current weather. I will "always" get a breifing at least one hour prior to departure. The other point in that, is that there could have been a situation where a temporary TFR was introduced since the original briefing... Best Regards, Todd |
"three-eight-hotel" wrote in message ups.com...
if I could see a copy of the METAR for that time. Is there any way of finding METAR information for a previous day??? It would be nice to see a copy for peace of mind... Todd http://adds.aviationweather.gov/metars/ Enter the aerodrome identifier, and select the time period, up to 36 hours, from the drop-down box. |
ups.com... You described being able to see things "down" but not "at a slant" in haze at 3000'. At that altitude, if you can't see prominent objects 11 degrees below horizontal, you have less than 3 sm visibility (and if you can't see prominent objects 35 degrees below horizontal--still nowhere near "down"--you have less than 1sm visibility). Any typical day in the Sacramento Valley is going to involve haze, except for those perfect days. I am certain that I have flown in conditions of 10, 20+, to almost unlimited visibility, where I couldn't see Mt. Diable, 90ish miles away, at an altitude that probably put it at 11 degrees below horizontal. Of course--it varies with altitude. At 3000', 11 degrees below horizontal gives you just under 3 sm slant distance. At a much higher altitude, 11 degrees below horizontal gives a much greater slant distance. Standing on the ground at the departure and destination airports, I can comfortably say that there was 5 sm visibility, as I was amazed at how different things could look from the ground and in the air. An un-intentionally omitted fact was that the flight occured around 4:30 p.m., which added another parameter, being the setting sun. The setting sun and haze could have likely made for poorer visibility, as I was flying East to West??? Quite likely. But flight visibility is defined by how far you can see, regardless of the factors that contribute to limiting that distance. And the VMC/IMC visibility distinction is defined with regard to *flight* visibility, not ground visibility. Another fact that I will humbly admit to, is that my gauge of distance probably leaves a lot to be desired. I welcome any and all comments to how people best gauge distance. Yup, it's hard to judge distance, especially when the air is very hazy. Calculating the slant distances that correspond to various altitudes and viewing angles can be helpful. An obvious easy one to remember is that at 30 degrees below horizontal, the slant distance is twice your altitude (neglecting earth curvature). I'm certainly not trying to be argumentative and appreciate your post, nor am I looking to get flamed for flying VFR into IMC, which I assure you, I would not be comfortable doing or be happy about, if I had let it occur. I believe you. But with no flame intended, and with all due respect, your description (seeing things in the down direction, but not at much of a slant, from 3000') makes it seem likely that your flight visibility was *nowhere near* VMC. In fact, if you couldn't see prominent objects from your altitude 35 degrees below horizontal, the conditions were not only IFR but LIFR! (Of course, all this applies when you are *in* the haze rather than *above* the haze.) Even if you can manage to aviate and navigate without instruments while flying VFR in IMC, you don't have adequate means to see and avoid anyone who's legally flying IFR near you. So you're betting their lives that you won't happen to collide with them. As I said above, the visibilty on the ground, after arrival, I would comfortably call 5 miles. But that's what not defines the difference between VMC and IMC. What matters is *flight* visibility, which (as your story vividly illustrates) can be much less than ground visibility. And it makes sense that the rules refer to flight visibility, because a primary reason not to be VFR in IMC is the need to see and avoid other aircraft--and that ability depends on your flight visibility. (Again, my intent here is not to criticize, but to constructively point out a vital distinction that you and perhaps other pilots here may have forgotten.) Thanks Gary! Your point is taken! I "did" take a 10 minute flight for granted, and will no longer depend on a forecast and a pop-up and see how it feels report for current weather. I will "always" get a breifing at least one hour prior to departure. That's a good idea too, but the same situation could well have arisen even with a more up-to-date briefing. Once you take off and discover sub-VMC flight visibility, the briefing becomes moot. You might want to file an ASRS report on this flight--not only for your legal protection (most likely no one noticed anyway), but also because this is exactly the sort of event that NASA hopes to learn from in order to improve aviation safety. As do the readers of this newsgroup, so thanks for your post! ![]() Regards, Gary |
Procedure turn required? | Peter Duniho | Instrument Flight Rules | 80 | July 6th 05 08:12 PM |
What's considered a steep turn by the airlines? | Bob Chilcoat | Piloting | 3 | June 23rd 05 03:59 PM |
IFR in the 1930's | Del Rawlins | Owning | 33 | September 11th 03 07:42 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
