Winch Launch Stresses on Vintage Gliders
Old January 27th 06, 10:12 PM posted to rec.aviation.soaring
Default Winch Launch Stresses on Vintage Gliders
It is standard practice to use two weak links in parallel. One has slotted
holes, so there is no strain on it unless the primary weak link fails. If
there is a true overload, both weak links fail. However, if the primary
weak link fails due to fatigue, but the actual forces are below the weak
link limits, the secondary weak link does not fail, preventing an
unnecessary launch failure.
However, if you screw up and use two identical weak links (either both with
regular holes, or both with slotted holes) you have the problem you alluded
to, which is that you effectively have a single weak link with double the
intended strength.
Mike Schumann
Old January 27th 06, 10:26 PM posted to rec.aviation.soaring
Agreed, however we have found that gust loads that break one, generally
break two, and we've taken to a policy of using only one TOST dog bone
at a time. Recently at the beginning of the day we found someone had
assembled a TOST assembly with two dog bones. The chief instructor
took it apart and found two round holed links. We think a single dog
bone of the proper rating is sufficient.
Frank Whiteley
Old January 28th 06, 12:04 PM posted to rec.aviation.soaring
Derek Copeland wrote:
Re the wing bending thing, almost the same happens
with ASW20's, which only have a 15 m wingspan. Neatly
demonstrates the forces involved.
I know - I had one - and winching is my preferred launch method.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old January 29th 06, 02:54 PM posted to rec.aviation.soaring
Is it possible to see that one is slotted and one round holed when the
cable is ready to be hooked up to the glider? Surely the pilot must
be given the opportunity to inspect the links before accepting the
cable. It's a while since I winched and we used rope weak links then.
Andy
Old January 29th 06, 03:35 PM posted to rec.aviation.soaring
Andy, that's a good question. Actually, as far as I know, there isn't a way
to visually inspect then once they are assembled into the protective case.
One wonders why.
It would be easy to dip one end of the slotted links in, say, tan paint.
Seeing a link assembly with two white dogbones but with one showing a tan
end would indicate that the link had been assembled correctly.
Bill Daniels
"Andy" wrote in message
Andy
Old January 29th 06, 04:22 PM posted to rec.aviation.soaring
We use a system where the weak link is held in an H channel with one end
hole drilled and the other slotted so that the end bolt is supported but
can pull out when the link breaks.
This gives a good protection to the link. We found that the metal
shrouds bent and also you couldn't see the link colour. With the H
channel you can see the whole link.
Robin
In message , Bill Daniels
writes
One wonders why.
Bill Daniels
roups.com...
Andy
Robin Birch
Old January 29th 06, 05:41 PM posted to rec.aviation.soaring
Easy: Pull at both ends. If everything is correct, then one link is now
fixed while the other can be moved freely.
And that's the idea of the arrangement: Over time, the weak link will
stretch, even when used within its load limit, and therefore weaken. In
other words, after some time, the link will be weaker than advertised.
The second link however will keep his strengh, as it never takes load.
So when the first link breaks prematurely, the second will still hold
the advertized load.
When you pull at both ends and one link can't be moved freely under the
load, then the first link has stretched and must be changed.
Stefan
  #28
Old January 30th 06, 08:49 AM posted to rec.aviation.soaring
We use a very similar system except the fitting is
L shaped, enough to protect the link but allowing easy
inspection. It is important to remember that the weak
link only works at it's rated value when new and the
force required to break it reduces over the number
of launches. Having the L shape protector allows easy
inspection of the link for necking or elongation of
the holes, both indicate a 'worn' link.
In practice links are used until they break, which
they inevitably will do if not changed.
that the metal
With the H
Robin
writes
One wonders why.
in, say, tan paint.
correctly.
Bill Daniels
'Andy' wrote in message
groups.com...
the pilot must
accepting the
weak links then.
Andy
Robin Birch
  #29
Old January 30th 06, 01:00 PM posted to rec.aviation.soaring
I don't disagree that they'll eventually break, but we've made many
hundreds of launches before a fatigue. When we have broken two at a
time due to a gust load, we replaced them with two new ones. Next
launch we broke both again. We were launching into strong winds with a
shear about 500ft. Over time we have broken the wire much more often
than a weak link failure. Since we train for the proper response to a
launch failure, it no longer makes much sense to use up two at a time.
It does eliminate the potential for mis-assembly.
Frank
  #30
Old January 30th 06, 09:21 PM posted to rec.aviation.soaring
On Wed, 25 Jan 2006 04:26:23 UTC, "Bill Daniels"
: If you examine glider handbooks, the strength of the recommended weak link
: for winch launch is usually about 1.2 to 1.4 times the gliders gross weight
: but sometimes it's less.
As I recall, the Tost weak link system specifies 1.4 times the
all-up-weight for gliders without a recommended colour - normally
rarities.
Ian
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
I need winch launch videos Bill Daniels Soaring 21 December 1st 04 06:41 PM
Aerotow with Diesel engine? Olfert Cleveringa Soaring 44 November 2nd 04 10:22 AM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 06:52 AM
Underwater Gliders Burt Compton Soaring 6 November 25th 03 04:43 AM
