Twin Comanche comparisons
Old January 28th 06, 03:14 PM posted to rec.aviation.owning
Default Twin Comanche comparisons
Hello There,
I am wondering if someone can point me to a site or give me information
on the cabin sizes between the early Twin Comanches and the later
models that have the extra window. I'm curious as to the leg room a
back seat passenger may have. ie: would someone 6'5" and 250lbs be
comfortable back there?
Thank you,
Dico
Old January 28th 06, 04:35 PM posted to rec.aviation.owning
I did all of my early multi time in the Twin Comanche and I'd have to
say that someone that large is not going to be comfortable in the back
seat of either the early models or the later CR models. You probably
need to be looking at an Aztec if you want to stay with the Piper line.
I don't think they'd like the Seneca model either.
-----Original Message-----
Posted At: Saturday, January 28, 2006 9:15 AM
Posted To: rec.aviation.owning
Conversation: Twin Comanche comparisons
Subject: Twin Comanche comparisons
Hello There,
information
Thank you,
Dico
Old January 28th 06, 04:56 PM posted to rec.aviation.owning
There is no difference in the measurements, although the later models
appear to be larger. The limiting factor is the main spar crossing the
cabin. The front of the spar is at the front of the second seats.
There is a myth that the later Comanches were stretched. They were not.
The overall length (excluding the prop extensions on the "C" model
singles) changed only fractions of an inch among the various models.
Adding the third set of windows only made the inside seem larger.
As to comfort of the second seat, at six feet one inch and 230 pounds, I
have been quite comfortable in the back seat of my 1959 single the few
times I have ridden back there. There was plenty of head room for a few
more inches of height. I can only assume that later models were no worse.
There is no practical difference between the cabins of the single and
twin Comanches of the same year.
Hank
Henry A. Spellman
Comanche N5903P
Dico wrote:
Hello There,
Thank you,
Dico
Old January 28th 06, 05:12 PM posted to rec.aviation.owning
This is a fact. The cabin dimentions for all Comanches never changed,
other than to ad 5/6th seats to the later singles and twins.
Personally I think the back seat/seats are actually rather spacious
in Comanches. The hard part is actually climbing in and out.
Old January 28th 06, 11:29 PM posted to rec.aviation.owning
The main determinant as to rear seat LEGroom in a Comanche (and in most
modern 4-seat GA airplanes for than matter) is how far back the front seat
is located. If the front seat occupant is relatively short and thus draws
his/her seat forward, the rear seat legroom becomes quite spacious.
-Elliott Drucker
Old January 29th 06, 02:43 AM posted to rec.aviation.owning
I'm also remembering that there wasn't a whole lot of headroom left for
anyone over about 6'2". Unless this guy has long legs and a shorter than
normal trunk for a person 6' 5" tall, I suspect headroom will also be an
issue. He only weighed in at 250 so he might "be all legs", but I'd sure
want to check it out before setting off on a long cross-country.
Posted At: Saturday, January 28, 2006 5:29 PM
pounds, I
few
few
worse.
most
seat
draws
-Elliott Drucker
Old January 30th 06, 06:00 PM posted to rec.aviation.owning
Henry Spellman was exactly right about Comanche cabins. I have a 1965
single, and at 6'4" I can sit comfortably behind the pilot seat in its
rearmost position. There's not a large gap between the back of the
front seat and the front edge of the rear bench (which is over the spar)
but the rear bench is very deep. In my plane the back seat may be more
comfortable than the front! But it probably has a lot fewer person-hours,
too.
Ben Jackson
http://www.ben.com/
Comanche accident averted last evening [email protected] Piloting 23 April 13th 05 10:02 AM
AOPA Twin Comanche Rosspilot Piloting 79 December 8th 04 07:23 PM
twin tail questions Kevin Horton Home Built 12 January 2nd 04 03:21 PM
Comanche 260 - 1965 Sami Saydjari Owning 5 December 8th 03 12:24 AM
True costs of a light twin... Captain Wubba Owning 20 November 20th 03 02:32 AM
