Radio / microphone question.
Old January 25th 06, 09:43 PM posted to rec.aviation.homebuilt
Default Radio / microphone question.
Hi All
I have a King KY195B TSO radio. It uses a Telex 66T , amplified dynamic Microphone.
It works well, but I want to change the microphone to a boom mic. (This is in a
sailplane)
The question is whether an electret mic will work.
Any suggestions?
Bruce Greeff
Std Cirrus #57
I'm no-T at the address above.
Old January 26th 06, 06:22 PM posted to rec.aviation.homebuilt
Only if you've got the little amplifier with it that converts the electret
mic to the aviation standard.
"Bruce" wrote in message
Hi All
Microphone.
in a sailplane)
Any suggestions?
Bruce Greeff
Std Cirrus #57
Old January 29th 06, 03:15 AM posted to rec.aviation.homebuilt
Speaking of amplified microphones...I was over at your web site and saw
the article from Oct. 1985 on using a transformer to convert a
commercial headset into one compatible for use in a plane.
(KP85OCT.PDF) I was thinking of doing this with a cheap active noise
cancelling headset.
The boom mike is the issue. Is there one available? I was looking for
something cheap to be used as a spare headset, or to be used by an extra
passenger in the plane.
Thanks,
Paul
Old January 29th 06, 05:58 PM posted to rec.aviation.homebuilt
The earphones have never been the problem; the microphones always a problem.
"Paul Dowgewicz (Remove Caps in Address)" wrote in
message news:FrWCf.327844$0l5.277087@dukeread06...
Radio Connector Question Slick Soaring 1 May 10th 04 11:06 AM
Vertex VXA-150 Pro V handheld radio question Alan Meyer Soaring 2 April 24th 04 01:42 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 12:05 AM
Radio Question Wizardo General Aviation 4 July 25th 03 01:24 PM
