Airplane design.
Old January 30th 06, 03:02 AM posted to rec.aviation.homebuilt
Default Airplane design.
Just as a friendly challenge to anyone foolish enough...
Design an airplane within the 254 pound weight limit.
IFR or not? Does it have to be able to fly into known icing?
Ben Hallert
PP-ASEL - http://hallert.net/cozy/
Old January 30th 06, 03:31 AM posted to rec.aviation.homebuilt
Ben Hallert
Uh, no.
And day VFR seams more reasonable.
Although I do love flying at night...
Old January 30th 06, 07:01 AM posted to rec.aviation.homebuilt
("Richard Lamb" wrote)
Clean sheet of paper.
254 pounds empty weight.
Your choice of engines, design, materials.
Where would you start?
Cri-Cri type
Twin diesels - torque, torque, torque
Wings that rock - "control wing" "free wing"
http://www.flyingflea.org/docs/SprattControlwing.htm
http://www.airandspacemagazine.com/ASM/Mag/Index/1995/DJ/ssfw.html
Original CriCri's weighed approx 150lbs, that included two 9hp engines. 150
lbs - total!
150 lbs - (15# engine + 15# engine) = 120 lbs - 20 lbs other stuff = 100 lbs
of plane building material.
So I'm thinking ...how much would (guessing) 60lbs of Titanium cost?
Montblackium
Old January 30th 06, 01:03 PM posted to rec.aviation.homebuilt
In article . net, Richard Lamb
says...
I for one have done it www.cgsaviation.com/hawkultra.htm and so have
others.Mine not also meets the 254 # but the stall speed and top speed criteria
set by the feds in part 103-7. Although I don't think this is the style of plane
the original questioner had in mind. Weight is relative and on this end of the
spectrum alum sheet gets heavy as a build material.Especially if it's over .020.
The Hummel plane is all alum and can carry a 200# guy has a fairly good sized
wing, so it's not a rocket at landing.But it still tips the scales at almost
300# empty.
It's an interesting challenge something us Ultralight guys have had to work with
for about 25 years. One thing I did was to not design to the 170# FAA pilot
since most pilots I know and and those I see at airshows haven't been 170# since
8th grade ,that includes me as well :-)So your design should use 200# -220# for
the design criteria. Good luck.
See ya
Chuck S
Old January 30th 06, 05:03 PM posted to rec.aviation.homebuilt
says...
300# empty.
See ya
Chuck S
Hey Chuck,
I've seen those around. There are two or three at Kitty Hawk.
Guess I'll go visit and see how they fly!
Richard
Old January 31st 06, 02:37 AM posted to rec.aviation.homebuilt
In article . net,
Richard Lamb
says...
criteria
style of plane
end of the
over .020.
good sized
almost
300# empty.
work with
pilot
170# since
-220# for
See ya
Chuck S
Hey Chuck,
Richard
There's a volcanolgist in Iceland that has been flying one over some
pretty dangerous ground for for the past few years. By all accounts it
a good plane but he but have titanium balls to fly any ultralight over a
volcano...
Old January 31st 06, 05:06 PM posted to rec.aviation.homebuilt
LOL! Pressurized? Retractable gear?
Old January 31st 06, 07:24 PM posted to rec.aviation.homebuilt
The only thing stopping me from hanging tricycle gear and a pair of
JetCat 200 turbojets off my Wright machine is the $10k+ cost of the
engines. Supose I could just use a pair of chainsaw motors... or even
6 model airplane engines, but that wouldn't be nearly as cool. By
Wilbur's calcs, the 1902 glider only requires 6 hp at 30 kts cruise.
Stall is at 14, and Vne is about 50 kts. Of course it'll still fly
like crap compared to a modern UL, but then the design is 104 years
old.
Harry
Old February 1st 06, 06:54 PM posted to rec.aviation.homebuilt
Marc J. Zeitlin wrote:
Stuart Grey wrote:
So, what's the deal with Raymer's book? Does it have an excessive
margin of safty, or was I doing something wrong?
After playing with the spreadsheet for about 15 minutes, it looks as
though the weight calcs are VERY sensitive to a few parameters that
aren't well explained in the spreadsheet. Unless you know exactly what
those parameters are, I don't think you should trust the weight #'s that
you get. Maybe the book has in-depth explanations of what the
parameters are and how to set them.
Yes, I needed to understand the parameters, and they were explained
better later in the book.. The book is kind of pricy for the number of
pages, but on the other hand, it gets to the core of what you need to
know without a lot of (unnecessary) theory and explaination, so you're
getting good bang for the buck. I can relate to that.
My problem came from the parameter "a". The book gives 1.19 for a single
engine, metal design - and this is the paramter I used. Way in the back
of the book, on page 135 (yeah, it's not a thick book) it shows how the
parameter a is calculated. You should find similar planes to the one you
want to build, and find the ratio of their empty weight to fully loaded
weight, and graph that on a chart against the fully loaded weight.
Among home built planes, there is a large cluster near 0.6-0.65 for
We/Wo, resulting in an a of over 1.2. However, there is another cluster
near 0.45 to 0.59 that result in an a closer to an a of 1.0 or below. I
think the airplane I want to build is in this grouping and not the
other. I suspect the difference is the smaller grouping is a high wing
with struts, while the other grouping is a low strutless wing.
It appears to be worthwhile to read the entire book. :-) Doh!
Old February 1st 06, 07:04 PM posted to rec.aviation.homebuilt
Gerry Caron wrote:
"Stuart Grey" wrote in message
I put into Raymer's spreadsheet a few things like 619 mile range, max
speed 160 mph, payload weight of 1190 lbs, wing taper ratio 1.0 and I get
a whopping gross weight of 4322 pounds, not the 3000 pounds of the Murphy
Moose. The engine suggested by the spreadsheet was also huge.
Well, that's a bit of a disconnect. I got similar disconnects when I put
in sizing data from other airplanes. The Raymer spreadsheet gives much
heavier designs. What's with that?
Q1) Is this because the Raymer book recommends overbuilding so that the
typical home designer doesn't have the engineering skill to make it
lighter?
Q2) Are there any better books out there?
Please be kind. I'm a very sensitive fellow. (HA!)
I've only given Raymer's book a cursory look, but I wouldn't say he's overly
conservative. I do believe he assumes an effort to meet the intent, if not
the letter, of Part 23. That could introduce significantly more
"conservatism" than some kit makers have put into their designs. Would that
make up the difference you cite? Maybe, but probably not.
I expect a big factor in the difference is the basic assumptions made
regarding manufacturing materials and design. Aircraft design is a lesson
in compromise. Change one thing and it ripples thru affecting a dozen other
things. The fact is most a/c designs start out too heavy, too slow, and not
enough payload or performance.
Then the real work starts. Find a few little things to reduce drag. That
can give you a few extra knots or let you cut a few HP. Cut that HP and you
save structure and engine weight. With less to haul around, you can reduce
your fuel tanks and save some more weight or trade it for payload, and so
on...
I'd consider Raymer's numbers a starting point. The Murphy is one possible
end point. Give the same starting point to a Van or a Rutan, and you'll
have a different end point.
There are other books out there. They're different. Better is a very
subjective term.
Gerry
It's interesting in that the methods used are based on existing designs
for a rough estimate. If you use the wrong class of airplanes for your
parameter selection, you don't get the numbers you expect. My problem
was that I used a parameter that was not close to the type of plane I
was targeting.
Aircraft design seems to be an iterative process; you guess the weight,
design to a given weight, look at how much the structure weighs, and
then try again. You can't design the structure without knowing the
weight, you don't know how much the structure weighs until you design
it. Chicken and egg thing. For this reason, they use regression analysis
of existing working designs.
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
