Happened at my local airport. Listened to the whole thing online and the
archives are available at LiveATC.net (Jan 28th, KFRG, around 9AM). Apparently a hydraulic failure. You need to be a Cablevision customer for the news site so hopefully this direct link will work for everyone. http://ondemand1.cv.net/news12/GLIEMELT.asx Marco Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
"Marco Leon" mmleon(at)yahoo.com wrote in message ... Happened at my local airport. Listened to the whole thing online and the archives are available at LiveATC.net (Jan 28th, KFRG, around 9AM). Apparently a hydraulic failure. You need to be a Cablevision customer for the news site so hopefully this direct link will work for everyone. http://ondemand1.cv.net/news12/GLIEMELT.asx \ It looked to me, like he got the engine stopped, just before touchdown, also. -- Jim in NC |
Gear up landings are no big deal for a typical GA plane. When I worked
in operations at a regional airport I was a trained ARFF responder and none of the wheels-up landings I ever responded to involved any fire. We'd just roll out the trucks into position and wait for the plane to land and skid to a stop. But it still sucks for that guy with the 210 - I guess the gear hand pump was inop? Engine teardown, new prop, belly skins.. ouch.. Not to mention the loss of the airplane for X months for repair. Truly a bad day, but could have been worse. |
I guess the gear hand pump was inop? If the hydraulic fluid has been lost, the gear hand pump does you no good.... -- Cheers, John Clonts Temple, Texas N7NZ (C210M) |
So if there is a system failure in the airplane (like this example), is it
the pilots responsibility for paying the repairs? Or is it the FBO who should have been maintaining the aircraft? This is a serious question, because I really dont know that answer and Im curious. -- John Huthmaker PPL-SEL P-28-161 http://www.cogentnetworking.com "John Clonts" wrote in message ups.com... land and skid to a stop. But it still sucks for that guy with the 210 - I guess the gear hand pump was inop? If the hydraulic fluid has been lost, the gear hand pump does you no good.... -- Cheers, John Clonts Temple, Texas N7NZ (C210M) |
"John Huthmaker" wrote in message
nk.net... So if there is a system failure in the airplane (like this example), is it the pilots responsibility for paying the repairs? Or is it the FBO who should have been maintaining the aircraft? This is a serious question, because I really dont know that answer and Im curious. The plane is owned by a doctor and I believed leased back to an operator. I believe the insurance of the owner pays as long as the pilot is qualified under the policy. In this case, I think it was the son of the FBO owner flying. If the insurance $ is not enough to cover all the expenses, then I think the owner can sue the pilot for the rest. Given the obvious equipment malfunction however, that wouldn't make much sense Marco Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
I guess the gear hand pump was inop? Engine teardown, new prop, belly skins.. ouch.. Not to mention the loss of the airplane for X months for repair. Truly a bad day, but could have been worse. I'm not convinced that he is going to need a new prop and engine teardown. It sure looked like he stopped the prop before touchdown. -- Jim in NC |
ups.com... Gear up landings are no big deal for a typical GA plane. ... In a Navion, you wreck the prop and grind the ends off the inboard flap hinges. No damage to the skin - assuming a reasonable paved surface. (The nose wheel hangs down a couple inches even when retracted.) -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
Capt. Geoffrey Thorpe wrote:
wrote in message ups.com... Gear up landings are no big deal for a typical GA plane. ... In a Navion, you wreck the prop and grind the ends off the inboard flap hinges. No damage to the skin - assuming a reasonable paved surface. (The nose wheel hangs down a couple inches even when retracted.) You break the step off. Mine has a weld in the middle of it from some previous owner's escapade. You also loose your antennas. There were pictures from the "belly landing contest" at one of the fly-ins, get a few guys to lift up a wing, prop some straw bales under it, drop the gear, and you can roll it away. |
Not sure why he ran away from the plane so fast. If it were my plane
I'd be right there, making sure an overzealous firefighter didn't do anything stupid, like spray it with a high pressure hose. -Robert |
| Saratoga Gear Retract Problem | Yahoo! News | Owning | 16 | November 30th 05 12:17 AM |
| Jet engines vs. leaf blowers | 01-- Zero One | Soaring | 6 | September 8th 05 02:59 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
